Drivetrain Can the PC680 from oddessy Battery be used everyday
Old Feb 14, 2005 | 07:53 AM
sright's Avatar
sright
I just bought the PC680 from oddessy battery and was wondering if it is durable enough for everyday use?
Old Feb 14, 2005 | 08:24 AM
flyboy2160's Avatar
flyboy2160
yes. i've had mine over a year. i mounted it in the stock battery box.
Old Feb 14, 2005 | 08:37 AM
aokdoug's Avatar
aokdoug
had mine for about 1 1/2 years. no problems.
Old Feb 14, 2005 | 09:09 AM
TonyB's Avatar
TonyB
From 1, to 1.5.... and for me, it's been a little over 2 years. Actually more of a problem is not every day use, but letting it sit for too long... No complaints.
Old Feb 14, 2005 | 09:52 AM
M7's Avatar
M7
Feel confident about using it daily, I used mine for well over 2 years with no
problems at all. Finaly it took a nose dive and died which was expected, as I
had the battery sitting for weeks at a time without being recharged.....
peter
Team M7
562-608-8123
www.m7tuning.com
Old Feb 14, 2005 | 10:07 AM
jinubob81's Avatar
jinubob81
any cold weather weiners with this battery?
i think it makes a difference (correct me if i'm wrong).
Old Feb 14, 2005 | 10:47 AM
TonyB's Avatar
TonyB
While I live in "sunny" CA, I'm in a canyon where the cold air settles on Winter nights. With my MCS outside seeing 30's often, 20's sometimes, and even high teens once or twice, no problem at all. These batteries don't like heat! That is why the MCS application is so cool (pun intended ) - the battery is not in the engine bay...Summit now sells a bracket for this battery for those who want to place it elsewhere...
Old Feb 14, 2005 | 01:01 PM
Helix13mini's Avatar
Helix13mini
FYI plug:
http://www.helix13.com/html/products...ew.php?p=6&h=m
Old Feb 14, 2005 | 01:27 PM
scobib's Avatar
scobib
Ooooh... a new MINI diet item... :smile:
Old Feb 14, 2005 | 04:02 PM
TonyB's Avatar
TonyB
Eric, very nice find! It's 2 pounds lighter than the one I have (Hawker at 13.5 lbs), and with more cold cranking amps. Your website says almost 40% more cca's, but I think you mean almost 30%, right (360 vs. 280, not 260)? Either way, it's notable...
The reserve capacity is about the same, but a bit less though, like 6%. The price delta is quite a bit at less than half:
http://www.gotbatteries.com/Productp...ctNum=37L105S1
It does come with the posts though. More options is a good thing!
Old Feb 14, 2005 | 04:09 PM
scobib's Avatar
scobib
My only issue with the Hawker is:
"For motorsports applications use the Odyssey battery. The Odyssey was designed for rugged vibration sensitive applications with thicker plates to prevent cracking and premature failure. The warranty on the Genesis doesn't cover motorsports installations."
Since I autocross a LOT and do 4-6 DE's a year, I'm betting the Hawker won't hold up...
Old Feb 14, 2005 | 04:16 PM
MSFITOY's Avatar
MSFITOY
A Griots' battery manager keeps me from having to retrain my ECU every other week during the winter months
Old Feb 14, 2005 | 05:27 PM
TonyB's Avatar
TonyB
scobib, I don't do any auto-x or racing of any type, so my input might not be of much value... With that said, mine has held-up very well, and it sees a lot of action in the canyon where I live. It is strapped-down (strap not shown below) with some rubber feet, like stand-offs separating it from the boot floor.
The Odyssey is only a few bucks more ($72), so probably well worth it. Not sure why I didn't get it to start with! I guess when this one craps-out...
Old Feb 14, 2005 | 06:24 PM
Helix13mini
D'oh! I spoze I should check the math before I cut and paste. What do you expect from a grease monkey.
Old Feb 14, 2005 | 06:29 PM
TonyB's Avatar
TonyB
It appears that you used 260 instead of 280... The math was otherwise fine .
Again, nice find. If I didn't already have a bracket for my current set-up, I'd strongly consider that baby! You might want to think about offering (fabricating) a custom bracket for that battery, if one is not already available...
Doc Pain
Mar 10, 2021 04:50 AM
SJ-R50
Oct 28, 2015 08:39 AM
schr5530
Oct 5, 2015 08:28 AM
MiniSMan
Sep 29, 2015 06:38 PM
jennster
Sep 28, 2015 06:19 PM
