Drivetrain Why upgrade to colder range spark plugs?
Old Feb 6, 2005 | 05:55 PM
MiniPilo's Avatar
MiniPilo
Well, I did some testing with a 19% pulley and about 10 dyno runs with approx 1 minute between runs on the stock plugs to test longevity, here is what I found. The same test on colder plugs had no effect on the plug. This is the reason that we carry colder range plugs for people with upgraded pullies.
http://www.piloracing.com/shop/products.php?cat=23
Old Feb 6, 2005 | 06:25 PM
jlm's Avatar
jlm
actually the reason is to protect everything else; the life of the plug itself is secondary. a hotter rated plug can turn into a little glow plug which is a sure path to detonation resulting in bearing, ring and piston failure. after those dyno runs cremating those plugs it would be a good time to pull your head and pan and drop in those new pistons.
Old Feb 7, 2005 | 10:07 AM
MartyR's Avatar
MartyR
right. I'd be more concerned about the little bits o' insulator infiltrating the motor's guts than the plugs.
jlm, you and andy always find new ways to entertain me! hahaha
M
Attached Thumbnails Why upgrade to colder range spark plugs?-skidmcs-copy.jpg
Old Feb 7, 2005 | 11:14 AM
MiniPilo's Avatar
MiniPilo
There were no bits that fell into the piston area.. luckily, we caught it prior to that, and verified that all the ceramics were accounted for on the spark plug. But, these are the findings of actual tests. The plugs just got to hot.
Old Feb 7, 2005 | 12:30 PM
jlm's Avatar
jlm
for your reading pleasure: from germanmotorcars.com
The higher the specific output (HP/in3) of the engine, the greater the sensitivity to detonation. An engine that is making 0.5 HP/in3 or less can sustain moderate levels of detonation without any damage; but an engine that is making 1.5 HP/in3, if it detonates, it will probably be damaged fairly quickly, here I mean within minutes.
Detonation causes three types of failure:
1. Mechanical damage (broken ring lands, rod bearing failure)
2. Abrasion (pitting of the piston crown)
3. Overheating (scuffed piston skirts due to excess heat input or high coolant temperatures)
The high impact nature of the spike can cause fractures; it can break the spark plug electrodes, the porcelain around the plug, cause a clean fracture of the ring land and can actually cause fracture of valves-intake or exhaust. The piston ring land, either top or second depending on the piston design, is susceptible to fracture type failures. If I were to look at a piston with a second broken ring land, my immediate suspicion would be detonation
Old Feb 7, 2005 | 12:33 PM
MiniPilo's Avatar
MiniPilo
Thanks for the info. I was monitoring Knock during the runs, and did not experience any detonation.
Old Feb 7, 2005 | 12:41 PM
jlm's Avatar
jlm
FYI: the mini is about 100 cu in, so that it exceeds 1.5 hp/cu.in.
Pilo:
yes you were monitoring detonation; you obviously found this, albeit, after the fact: "...it (detonation) can break the spark plug electrodes, the porcelain around the plug..."
Old Feb 7, 2005 | 01:04 PM
Helix13mini's Avatar
Helix13mini
Monitoring knock?
I've been looking for an application that monitors knock. What do you use?
Old Feb 7, 2005 | 05:35 PM
MiniPilo's Avatar
MiniPilo
Originally Posted by Helix13mini
Monitoring knock?
The S-AFC2 allows you to monitor the signal from the Knock Sensor. While running the dyno, I can monitor the readings coming from the sensor. This allows me to get an idea of what is going on.
Old Feb 7, 2005 | 05:36 PM
MiniPilo's Avatar
MiniPilo
Pilo:
I was monitroing the knock signal, and did not see a spike or any change really in the signal that would indicate detonation, and from the way that you described it above, the signal would have an obvious change.
That was not the case.
Old Feb 7, 2005 | 06:02 PM
jlm's Avatar
jlm
i think the clear message form the plug is you can have heavy detonation regardless of this method:
"I was monitroing the knock signal, and did not see a spike or any change really in the signal that would indicate detonation, and from the way that you described it above, the signal would have an obvious change"
Old Feb 7, 2005 | 06:46 PM
macncheese's Avatar
macncheese
Pilo,
I'm not sure I follow. What broke the insulator? You elude in your original post that it was the pulley?
I think it was probably Professor Plum in the library with the candlestick.
Old Feb 7, 2005 | 10:06 PM
M7's Avatar
M7
Yes I second this opinion...I have seen plugs with excactly this type of damage
typically done from very heavy detonation.
The broken ceramic is not the only sign of detonation, also consider the metal flakes missing on the and/or deposited on the electrodes....not good.
And why 10 back to back dyno runs on an MCS, it would be a heat soak nightmare
peter
Team M7
562-608-8123
www.m7tuning.com
Old Feb 7, 2005 | 10:16 PM
El Diablito Rojo-N20Mini's Avatar
wanna see heat-soak?
Old Feb 22, 2005 | 04:51 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
I pulled my stock plugs the other day, just to check their condition after 30k pulleyed miles and they look almost brand new. I'm planning to replace them with some good ol' fashioned single electrode copper plugs in the course of normal maintenance.
Old Feb 22, 2005 | 06:20 PM
ScottinBend's Avatar
ScottinBend
You gonna stick your head in a bucket of water?
I'd pay to see that.........
Old Feb 22, 2005 | 06:26 PM
somebody edited out this....
Old Feb 22, 2005 | 06:55 PM
ScottinBend
maniacalmorgan
Jan 1, 2020 11:20 AM
HaveATank
Sep 4, 2015 08:04 AM
HaveATank
Aug 24, 2015 10:26 AM
maniacalmorgan
Aug 19, 2015 08:44 AM
yashmack
Aug 15, 2015 10:16 AM
