Drivetrain Mtf
Old Dec 19, 2004 | 04:08 PM
kapps's Avatar
kapps
Mtf
Hi all. I just received Bentley's MINI Service manual and it says that the manual transmission fluid is a "lifetime fluid" and never needs changing . Well I definitely do not trust that info unless the lifetime is 100k miles and double clutching is used religiously. I've got 35k miles on my '02 and, while I know it doesn't need it soon, would like to know what interval I should be changing it. Also, I'm keen to Redline MTL and would like to know which one would work better (70w-85 or 75w-90). It says the fluid in the MINI is MTF 94.
Old Dec 20, 2004 | 09:43 AM
apexer's Avatar
apexer
The people I have spoken with that are using Redline in their trans all use MTF. Although I have been using Redline 5W30 in engine, I have not yet done anything with the transmission (only 10K miles), however, I have used MTF in several Honda Trans. with no problems.
Old Dec 20, 2004 | 12:56 PM
vagt6's Avatar
vagt6
Hey Kapps, I hope this isn't an obvious question but doesn't the Bentley Manual indicate a spec for the gearbox oil?
If not, maybe we could check with the gearbox manufacturer.
Thanks for posting, good question.
Old Dec 20, 2004 | 01:13 PM
kapps's Avatar
kapps
All it says is BMW longlife MTF 94 which I assume is ~94 weight when hot. I'll try searching around getrag...
Old Dec 20, 2004 | 01:14 PM
early_apex
I would ask Redline:
http://www.redlineoil.com/tech_requests.asp
Red Line Synthetic Oil Corporation
6100 Egret Court
Benicia, CA 94510
PHONE: (707) 745-6100 or (800) 624-7958
FAX: (707) 745-3214
Old Dec 20, 2004 | 02:25 PM
kapps's Avatar
kapps
Good idea. I did some searching and it turns out MTF 94 is really 75w-80. I'll definitely check with Redline before I do the change. Thanks.
Old Jul 31, 2005 | 05:36 PM
barnhillld's Avatar
barnhillld
Did you get a response from Redline?
I'm in the middle of a clutch change and need to know what to put back in the transmission. I've already purchased some Mobile 1 synthetic gear lube, but after reading things online, I'm not sure this is the right thing to be using.
I've just sent a request to Redline using the link above, but rather than wait for them, was curious if you already had the answer. Should I pick up some Redline MTL ?
Old Jul 31, 2005 | 07:09 PM
dragonwang's Avatar
dragonwang
I have heard various users using Royal Purple with better results than Redline. RP seems to shift better than Redline. http://www.rpmoil.com
Old Jul 31, 2005 | 08:12 PM
BigBrownDog's Avatar
BigBrownDog
Amsoil has their "MTF" product as well, according to my distributor it is a suitable replacement for the MTF-94 used in the MINI gearbox....
http://www.amsoil.com/storefront/mtf.aspx
Old Jul 31, 2005 | 11:54 PM
BFG9000's Avatar
BFG9000
I see lots of posts from other boards where people claim synthetics like Redline MTL, etc greatly improves shiftability, esp in cold weather. Can anyone confirm this for the MCS, or is factory fill good enough?
Old Aug 1, 2005 | 12:00 PM
RECOOP's Avatar
RECOOP
I have a lighter flywheel (15#) that generates "clatter" at idle speeds. I changed the factory transmission fluid from the stock to Redline MTL, and the magnitude of the chatter has decreased substantially. It's hard to say if shifting is easier, but I'd like to think so
Old Aug 1, 2005 | 06:55 PM
minilites's Avatar
minilites
LSD compatability
Evening all, since we're on the subject of MTL . is Redline compatible with
the MCS gearbox with the factory LSD? is BMW using a additive to the lifetime gear oil for the box's with LSD? Thanks awaiting
comments.
bimpower
Nov 26, 2021 07:18 PM
jc8825
Jul 5, 2015 09:16 PM
nap220
Factory JCW Talk (2009+)
Feb 12, 2014 07:18 AM
coopersjcw871
Feb 7, 2011 07:41 PM
martinb
Feb 4, 2010 01:08 PM
