Which Transmission Lube????
Old Feb 2, 2010 | 03:40 PM
martinb's Avatar
martinb
After checking this and other forums and other internet related sources of information, and after checking with a number of dealers and specialty performance companies, I'm still not sure what to put in my Mini's transmission.
First off, this is what I've got:
'06 Cabriolet with full JCW package including 6 speed Getrag and limited slip.
Build date: June 30, 2006
Transmission: GS6-85BG
I've seen this several places on the web:
[FONT='Verdana','sans-serif']6 spd Getrag GS6-85 up to 7/2004 MTF-94
6 spd Getrag GS6-85 from 7/2004 MTF-LT-3
6 spd Getrag GS6-85 with limited slip from 1/2005 MTF-94
6-speed Getrag GS6-55 BG, GS6-53 BG/DG from 9/2006 MTF-LT-4[/FONT]
And from what I've learned from various dealers and private auto specialists, some say MTF-LT-3, other say MTF-94.
I've also found that some MTF-94 fluids (not BMW) are not LSD compatible. Some are. And I don't know if the BMW specific fluids are LSD compatible.
So, what do I use? I want to stick with the BMW stuff right now until my warranty is up. Then I'll probably switch to Redline MTL.
Or, since I only have 23,000 miles on the car, I may simply wait until my warranty expires this coming September and make my first transmission fluid change then.
I sure wish the information was easier to come by.
Thank much!
Old Feb 2, 2010 | 03:46 PM
Oxybluecoop's Avatar
Oxybluecoop
From the MINI TIS
1st Gen MINI Transmission Fluids.pdf
Old Feb 2, 2010 | 04:20 PM
martinb's Avatar
martinb
Hey, that seems like a copy of an actual BMW service bulletin. Thanks. So, is looks like MTF94 is what I need.
Do you know if the MTF94 is synthetic or not?
And I'm assuming that Redline's MTL would be an excellent aftermarket choice?
Old Feb 4, 2010 | 01:08 PM
martinb's Avatar
martinb
'Just a follow-up.
I was feelin' pretty sure that the MTF-94 was what to use, but decided to check with one last source. That source was Mini back in New Jersey. I emailed them my questions and left my cell number and within an hour, I got a call confirming that the MTF-94 is what you want to use in a LSD equiped 6 speed. They also confirmed that it is a synthetic blend, not a full synthetic. So, for that reason alone, I will change it out more frequently. And when I'm no longer on the factory warranty, I'll likely switch over to Redline's MTL.
Thanks all!
gknorr
Dec 26, 2016 09:38 AM
vulkandino
Oct 31, 2015 08:29 PM
SJ-R50
Oct 28, 2015 08:39 AM
Oct 1, 2015 12:13 PM
B1mm3r101
Oct 1, 2015 06:22 AM
