Drivetrain Larger turbo inlet hose
Old Aug 16, 2018 | 11:05 PM
Bdibs's Avatar
Bdibs
Anyone know where to get something this size or I need to get it custom made bay a silicon manufacturer
Temporary fix at least i t works gotta love gorilla tape
Old Aug 17, 2018 | 06:58 AM
mdsbrain's Avatar
mdsbrain
Do any of the current aftermarket take tubes not work for your application?
Old Aug 17, 2018 | 10:45 AM
Looks like a big turbo, You could get the Forge or samco, but then you would have to sleeve it with a hard pipe and step it up to the turbo with another short silicone piece. From the looks the inlet of the turbo is very big and the silicone hose might not stretch that much
https://www.ecstuning.com/Mini-2007-...e/Intake_Boot/
Old Aug 17, 2018 | 10:58 AM
cornjuice's Avatar
cornjuice
just fyi - you dont need that PCV connection or the sensor.. ditch them both and just use a 90 that fits
Old Aug 17, 2018 | 11:36 AM
DneprDave's Avatar
DneprDave
That PCV connection is needed when the engine is under boost, without it you could pressurize the crankcase and cause oil leaks.
That isn't a sensor, it is a heater, to prevent ice build up in the PCV line at the turbocharge suction.
Old Aug 17, 2018 | 05:49 PM
NeonLed's Avatar
NeonLed
You could try this. It's 2.75" ID on the big side, buts it's only 2" for the turbo inlet. http://jmtcperformance.com/universal-turbo-intake/
Old Aug 27, 2018 | 12:23 PM
Dr. Spade's Avatar
Dr. Spade
How big is your turbo?
I have the 42MM Alta turbo and NM inlet works fine. Switched from K&N.
Old Aug 27, 2018 | 03:10 PM
Bdibs's Avatar
Bdibs
3 inch
Garrett gt28rs
Old Aug 28, 2018 | 07:26 PM
oldbrokenwind's Avatar
oldbrokenwind
My plumbing (originally fit GT28RS), BOV, OCC and K & N Typhoon. Custom made hose couplers can be replaced with std couplers and silicone elbows / reducers. Fittings available from ATP Turbo, TurboHoses.com, Hoses By Silicone Intakes, and probably others. My PCV heater has been disconnected and removed --- no CEL.
Hvyjetdriver
Aug 18, 2018 11:54 PM
'10JCW
Jun 28, 2014 12:58 PM
joshK
Dec 19, 2007 10:23 AM
JLLG
Dec 4, 2007 09:05 AM
mikeg4572
Nov 18, 2007 06:54 PM
