Drivetrain 20+hp gain wiht an Ohm sensor???
Old Nov 3, 2004 | 01:15 PM
bowhunter8's Avatar
bowhunter8
[size=4]Mini Cooper Performance n/Chip 20+HP[/size]Item number: 7932094072
anyone seen this on Ebay? 20 + hp with this sensor.. and it is only 8 bucks
anyone tried it??
Old Nov 3, 2004 | 01:23 PM
xsmini's Avatar
xsmini
Yep I'm running three in series and am getting 220 hp now. Not bad for 30 bucks (had to pay shipping)
Nik
Old Nov 3, 2004 | 01:29 PM
bowhunter8's Avatar
bowhunter8
WOW..220hp.... i see you have some other improvments...
i have a 03 MC ... should i get 3 of them???
is this better than the MTH mod??
Old Nov 3, 2004 | 01:33 PM
xsmini's Avatar
xsmini
Three, four, maybe more. Its plenty fast now
Cheaper than the MTH, not better
Nik
Old Nov 3, 2004 | 05:02 PM
bowhunter8's Avatar
bowhunter8
I am going to have to try at least one..
did it effect your gas mileage?
Old Nov 3, 2004 | 05:45 PM
bodinski's Avatar
bodinski
This is a scam, bh. You're supposed to cut your temp sensor wire & splice in the $8 resistor (a 9 cent value!). This is supposed to make the computer think that the engine's cold all the time. When it's cold, the tuning parameters are somewhat different & supposedly the engine makes more power.
I predict your gains will be less than advertised, and that you'll see the "SES" light in the near future.
Just my opinion - I could be wrong..
Best - Bodinski.
Old Nov 3, 2004 | 06:18 PM
greatgro's Avatar
greatgro
bowhunter8 - nabarbieri is pulling your leg! No one has three of them! I'm sure no one has one. It is a scam...A SCAM! Sorry to break the bad news.
Old Nov 3, 2004 | 07:30 PM
bowhunter8's Avatar
bowhunter8
THANKS FOR THE HONESTY, I WILL SAVE FOR THE MTH MOD AND FORGET THE SENSOR!!!
Old Nov 3, 2004 | 07:51 PM
Ryephile's Avatar
Ryephile
yea, screwing with your sensors is basically never a good idea.
Save the ECU mods to the experts!
Old Nov 4, 2004 | 01:17 PM
goldcountrymini's Avatar
goldcountrymini
I emailed the guy and he stats that you cannot run this on Turbos, superchargers or diesel. Just thought that I would throw in this comment before someone buys it for their MCS.
Agreed that the ECU upgrade is the best bet. I think that I will just stick with bolt on mods though... for now...
Old Nov 4, 2004 | 01:45 PM
greatgro's Avatar
greatgro
Well before someone buys it for a Cooper, let me repeat...IT'S A SCAM! Plus you may very well screw up your ECU!
Old Nov 4, 2004 | 01:55 PM
xsmini's Avatar
xsmini
Originally Posted by greatgro
IT'S A SCAM!
Thats all I was saying.
Nik
Old Nov 4, 2004 | 03:06 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Umm ... don't you have a Unichip?
Old Nov 7, 2004 | 06:11 PM
Ryephile's Avatar
Ryephile
The difference between "screwing with" and knowing what you're doing can be vast. I too enjoyed the potential humorous irony of the statement, none the less
Old Nov 8, 2004 | 04:38 PM
bowhunter8's Avatar
bowhunter8
Thought i would show y'all what the deal said, I e-mailed him and asked for some proof
This is no scam, I have had one on my own car for two years, and it read a 12 HP gain on the dyno. If you deceide to buy one, follow the specifications below, and you can hook it up to a dyno machine with and without the mod, and chech for yourself. I sell alot of these and have never had acomplaint on this particular vehichle. However, you have no risk, it will not harm anything, and I offer a 100% money back promise that I stand behind. thank you for your questions.
This device attaches to the IAT sensor, working as a piggy back device to send a signal to your computer, telling the computer to increse the fuel air/air mix ratio, resulting in more HP, more torque, and more power.
As long as your vehichle meets the following requirements, it should work fine.
1.Must be fuel injected.
2.Must not be turbo, super charge,or diesel.
3.Your model must have a two wire IAT sensor (Intake Air Tempurature sensor) , for this device to work, because this is where the mod is installed. Please make sure your model has one of these. **How to find it: All vehichle's IAT sensor are in a different location so its almost impossable to know excatly where they all are, but here is the best way to find it on your engine, hope it helps you. Start at the air filter, and work your way back following the air intake system looking for the plug with only 2 wires, its probly on the intake manifold or the throdle body. If this does not help you out, you can take it by a dealership, or garadge and they and they should be able to show you where the IAT sensor is.
There is no fuel difference and if there is it wont be enough to notice. Ive had one on my car for 2 years now and i have not noticed a difference at all. And it read a 12 HP gian on the Dyno test.
Note: 2003 Chevy Avalanche does not have an IAT sensor. Will not work on this model.
Note: 2000 Ford Excursion, V10 model does not have an IAT sensor. Will not work on this model.
Note: No IAT sensor on the Mazda 323/626/929 until the year 1993. Will not work on this model.
Note: 1998 Subaru does not have an IAT sensor. Will not work on this model.
Old Nov 8, 2004 | 04:51 PM
ZAMIRZ's Avatar
ZAMIRZ
never ever use ebay as a guide to modding your car. If you haven't seen it anywhere else on the web, then it's probably not a good idea.
Old Nov 8, 2004 | 05:06 PM
D1JL's Avatar
D1JL
Just remember that OBD2 checks not only “Good” or “Bad” but rationality as well. It is NOT rational for the air charge temperature to remain always constant. This will at some point turn on the MIL.
Why would making your car run rich give you more HP? The Cooper needs more AIR, it is already too rich at WOT.
But then, what do I know?
Dave
Old Nov 8, 2004 | 06:40 PM
greatgro's Avatar
greatgro
Also keep in mind that this idiot says it works fine on the MINI Cooper S but don't use it on a supercharged car!
shorenetworks
Nov 4, 2019 06:18 PM
CRC
Dec 26, 2015 11:30 AM
muddflapp
Sep 20, 2015 03:55 PM
sempaipaul
Sep 18, 2015 03:05 PM
HogWldFLTR
Sep 8, 2015 05:25 AM
