Drivetrain Getting hesitation at wide open throttle
Old Apr 30, 2018 | 08:21 AM
Brainpp's Avatar
Brainpp
just got finished with turbo upgrade and tune and now I’m experiencing a problem every time I give it wot it hesitates as if going into boost cut if I ease into the boost then give it wot then It runs better. It’s as if it doesn’t want to go into boost.not sure on what could be the problem I’ve been trying to figure this out for the last few days I need help
Old Apr 30, 2018 | 09:07 AM
BigBoost's Avatar
BigBoost
What’s your supporting mods , tune , plugs , turbo , etc.
Throwing any codes
Old Apr 30, 2018 | 09:14 AM
Brainpp's Avatar
Brainpp
Got a front mount intercooler catless down pipe jcw intake mamba turbo manic stage 3 tune colder plugs . For the life of me I cannot figure this out 🤔 I’m getting p0420 p0128
Old Apr 30, 2018 | 09:19 AM
BigBoost's Avatar
BigBoost
Well manic stage 3 requires you to run either 100 octane or race fuel or meth , or both !
I would run ILKR8E6 1422,
An if that doesn’t work I would start looking at your fuel pumps in tank & hpfp along with filter’ when’s the last time you had the valve walnut blasterd
Old Apr 30, 2018 | 09:52 AM
Brainpp's Avatar
Brainpp
i was under the impression it was optional to run 100 octane would that cause my problems also I’m running autolite xp071 plugs didn’t have ngk 1422 and was told that these where exactly the same much thanks for the help
Old Apr 30, 2018 | 09:59 AM
BigBoost's Avatar
BigBoost
Yeah it’s definitely not an option ‘ don’t feel too bad though not the only one that got suckered into that ‘ find yourself some race fuel a and run it through and see what happens !
& as far as the autolites xp071 I have absolutely no idea : I’ve only ran the NGK 1422
Old Apr 30, 2018 | 10:34 AM
BigBoost's Avatar
BigBoost
The p0128 is Coolant “Temp Below Thermostat Regulating Temperature”
A common problem with the thermostat. It might be going bad or the sensor is bad
Usually people start to realize that the thermostat or sensor is bad’ when they flash a tune on because it changes temperature settings ‘
The P0420 is catalyst efficiency below threshold
When you want with the catless pipe did you plug your Secondary o2 back in,
The tune doesn’t require it But it needs to be plugged in or’ needs some kind of type of resistor in to close the loop
Old Apr 30, 2018 | 10:41 AM
Brainpp's Avatar
Brainpp
I’ll make sure to put better gas in and get back to you. hmm 🤔 I replaced the thermostat sensor and housing not to long ago and yes I still have the secondary o2 sensor installed would it be better to just delete it ? I was also told to mix 91 octane with e85 to increase fuel safe
Old Apr 30, 2018 | 11:00 AM
BigBoost's Avatar
BigBoost
Yeh’ I’ve tryed the 91 mix an it doesn’t work ‘ at least it didn’t work for me !
I’m pretty positive that the rear O2 is deleted from the new MAP, but it still needs the Signal from the plug , ecm needs it for the other crap ! Am Kind of at the point where I kind of understand it but then again I don’t ,
And as far as the thermostat housing goes’ I want though two of them before getting one that wasn’t defective ‘
Old Apr 30, 2018 | 07:43 PM
Brainpp's Avatar
Brainpp
just did e85 mix and feel likes it’s running better but the boost still cuts out 😑
Old May 1, 2018 | 10:58 AM
BigBoost's Avatar
BigBoost
Yeh’ I had the same problem with mixing’ try out some 100 plus fuel & see what happens ,
Old May 2, 2018 | 03:49 PM
weaverpsu's Avatar
weaverpsu
may or may not help
I had this issue for a completely stock Countryman All4. It was misfiring according to the dealer and they said the ignition coils were faulty and they replaced them as well as the spark plugs.
Old May 2, 2018 | 04:45 PM
Brainpp's Avatar
Brainpp
Update I checked ignition coil packs and they do seem to be working properly found that spark plugs weren’t gapped properly and gapped to spec runs better now. I can actually boost up to 15 but not the full 21 pounds so I’m wondering if anyone would be able to tell me if coked valves would cause this because that’s the only thing I can think of car hasn’t had valves cleaned ever I think 😬 and also if anyone knows of a shop or someone that can walnut blast my valves I would appreciate it thanks 🙏
Old May 8, 2018 | 12:18 PM
BigBoost's Avatar
BigBoost
Do it your self , Bavauto sells a walnut blaster kid ! 275
Replace your plugs ! With NGK 1422
Old May 30, 2018 | 03:48 PM
rromeo_f's Avatar
rromeo_f
Check your PCV valve system, you have 2 main failure points, the first one is the diaphragm in the top left corner, remove carefully the cap and see the diaphragm isnt broken. The second one is the check valve in the lower right corner, disconnect the hose that goes to the intake tube and try to blow air in it should not let you blow in but you should be able to breathe in. If any of those are busted you should replace the whole valve cover and tap the the PCV ports while you are at it: https://www.northamericanmotoring.co...arbon-fix.html
MNMLST
Apr 12, 2015 02:48 PM
t0ad
Jan 30, 2015 02:12 PM
d6-mcs
Tires, Wheels, & Brakes
171
Feb 12, 2014 05:37 AM
isthar
R55 :: Clubman Talk (2008+)
24
Jan 6, 2012 01:40 PM
cthatcher5
14
Jul 31, 2004 09:04 AM
