Drivetrain JCW Supercharger and Crank Pulley Info Needed
Old Feb 15, 2018 | 09:44 AM
wikdr53's Avatar
wikdr53
Have a 2006 Factory JCW and looking to upgrade the two pulleys. Which is best for back road hooliganism?
Stock JCW SC Pulley + 2% ATI Crank Pulley
17% SC Pulley + 2% ATI Crank Pulley
17% SC Pulley + ATI Crank Pulley
Seems like the last choice is best as to give better low/mid range TQ. Just figure I would ask before ordering. Thanks!
Old Feb 15, 2018 | 10:32 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
I went with the last choice on my S, 17% + ATI pulley, and also cam/injectors/4:1header/highflowcat/jcw mufflers. You can here it here..
I did not touch my JCW pulley, I autocross that car and if you put a pulley on the car it bumps you to SMF
Old Feb 15, 2018 | 11:26 AM
PariDot's Avatar
PariDot
https://www.youtube.com/watch?v=HLus2Oe8tAI
Did you replace the SC with another one with the 17% pulley? or did you pull the pulley off and replace it?
Old Feb 15, 2018 | 11:45 AM
MrBlah's Avatar
MrBlah
used a pulley remover tool and removed the stock pulley
Old Feb 15, 2018 | 12:18 PM
BlwnAway's Avatar
BlwnAway
Honestly, this is a tougher question than you would think.
The 17% / 0% is the best answer, but... JCW pulleys are notorious for being difficult to remove (esp '05 and later) so the JCW / +2% is a very good solution.
Sorry this isn't much help, but figured it should just be said anyway.
Old Feb 15, 2018 | 01:49 PM
wikdr53's Avatar
wikdr53
Indeed. The labor and parts saved on the JCW + ATI is attractive.
Old Feb 15, 2018 | 02:40 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Another alternative is leave the JCW pulley, go with Way Motor's 2% ATI over drive and install Detroit Tuned's BPV. That will get you up and possibly over 15 PSI of boost.
My friend has a 17% while I have the JCW/ATI but I also have a cam so I rev up faster but once he gets going the 17% with the extra boost makes a difference.
Old Feb 15, 2018 | 03:49 PM
wikdr53's Avatar
wikdr53
Yeah looking like the 17% is the way to go. Nice Video btw Mega!
Old Feb 16, 2018 | 08:33 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Start with just the 2% ATI as you can reuse the same belt and it is really easy to install. Then drive it and see what you think.
https://www.waymotorworks.com/super-...ulley-r53.html
Later you can add a smaller supercharger pulley to get more out of it.
ncsurfer
Jan 4, 2016 05:56 AM
cannovmj
Jul 15, 2015 01:00 PM
jhiggs26
Oct 21, 2009 07:44 PM
mdsbrain
Mar 1, 2006 06:45 AM
jonnieoh
Jun 27, 2005 07:00 AM
