Drivetrain Early Crank Pulley Out, Facelift Crank Pulley In.
Old Sep 27, 2009 | 07:29 PM
jhiggs26's Avatar
jhiggs26
I just swapped out my early model crank pulley for a late model 2005-2006 crank pulley. The swap went routine except for pressing on the late model pulley with install tool.
The pulley encountered lots of friction the last 1/8" going on the crank snout. The increased friction resulted in my install tool cracking right at where shoulder and course M12-1.75 threads start. I was probably torquing the install nut-and it's fine threads-at about 70 ft-lbs when it let loose. I was able to twist out the broken off install tool nub easily and carrry on. The special tool's M12-1.75 thread length should really be another inch or so to help the tool from being overloaded and breaking in the crank!
Anyways, to carry on the task of pressing the crank pulley home, I used a M12-1.75 X 80mm bolt with 4 shimming washers well lubed torqued to about 60 ft-lbs in the crank. With the M12 bolt in the crank and mildly torqued I brought out the BFH and 2X4 chuck of wood. So it went BFH, re-torque M12 bolt, BFH, re-torque M12 bolt(you get the idea) for about 20 minutes until the crank pulley was seated home on crank snout.
The crank pulley lined up lovely with it's new 535 drive belt and passed it's idle test. After that I and took her for a 30 mile test drive. She worked well and my clutch chatter seems to be somewhat muted compared to the stock early model crank pulley!
Jeremy
Stock pulley removed.
Stock pulley left and facelift pulley right. Bolts at top are as follows: M12-1.75 X 80mm bolt grade 8.8, stock M12-1.75 75mm crank pulley bolt grade 10.9, pulley install tool grade duff.
Side shot comparison.
Halfway through thread restoring the crank pulley bolt. New Blue Loctite went on it for install!
Facelift crank pulley and it's new home!
Old Sep 27, 2009 | 09:10 PM
Longboard Mini's Avatar
Longboard Mini
Nothing like BFH to get the job done.
LB
Old Sep 27, 2009 | 11:25 PM
k-huevo's Avatar
k-huevo
The original crankshaft bolt should not be reused, aftermarket threadlocker will loose its bond after repeated head cycles. I've seen reused crankshaft bolts back-out.
Old Sep 28, 2009 | 07:15 AM
jhiggs26's Avatar
jhiggs26
That's right Bryan! BFH for the win! Ask any woman that.
I got a note from K-huevo stating that he's seen a few re-used crank bolts back out. I'll order a new bolt from MINI(it may come with pre-applied thread locker). When I replace it I'll post the torque value that the re-used bolt let go at.
Jeremy
Old Sep 28, 2009 | 07:28 AM
Bigshot's Avatar
Bigshot
Did you consider the new alternative dampered crank pully?
Old Sep 28, 2009 | 07:43 AM
jhiggs26's Avatar
jhiggs26
Yes I've considered it Bigshot. The later model pulley should hold up well for me and definitely better than my stock pulley. Are you spinning the new ATI fluid Damper Bigshot?
My work shut down at the end of August so my MINI doesn't do Mon-Fri duty steady anymore. I must find work so I can continue to beat back my mortgage and drive my MINI more!
Jeremy
Old Sep 28, 2009 | 03:57 PM
bean's Avatar
bean
Jeremy
jeremy: did you change your pulley because it failed or because you preferred the facelift pulley? the reason that i ask is that two of my track-rat friends, driving 06 MCS's, very recently had crank pulley failures. one had his replaced w/ oem under warranty, the other had an ATI installed. the later happened at Mickey and MINI 5, where Way just happened to have an ATI on display. Way said that this was the 7th crank pulley failure that he had seen in the last two months. i think that i see a trend....
greg
Old Sep 28, 2009 | 10:00 PM
jhiggs26's Avatar
jhiggs26
Greg I went with an 05/06 crank pulley because of odds. Pre-facelift crank pullies don't seem to stand up compared with facelift crank pullies.
However with your post it seems the facelift pullies are evening up the odds....haha. If it goes South on me I'll figure it out. Thanks!
Jeremy
Old Sep 29, 2009 | 07:14 AM
Bigshot's Avatar
Bigshot
What caused you to get the OEM one vs the new aftermarket one?
Old Sep 29, 2009 | 07:33 AM
jhiggs26's Avatar
jhiggs26
Cost was a concern Bigshot along with application. My MINI is A to B primarily and now with limited use. See post # 5. An ATI would be nice but not necessary for me, well until I have a failure.
Randy Webb sent me a good/used for a fair price from the NAM marketplace. I figured to up reliability and shed a pound off the crank snout was not a bad thing.
Greg/bean, do you have any separation shots of failed facelift crank pullies by any chance?
Jeremy
Old Sep 29, 2009 | 08:15 AM
Bigshot's Avatar
Bigshot
I haven't priced the ATI one......how much difference in price is there?
So your OEM one wasn't failing?
Old Sep 29, 2009 | 08:20 AM
jhiggs26's Avatar
jhiggs26
No not failed yet Bigshot.
I think ATI's go for around $400+ at Way Motor Works, RMW and Werkin MINI.
Jeremy
Old Sep 29, 2009 | 08:21 AM
Bigshot's Avatar
Bigshot
Thanks for clarifying that for me!
Old Sep 29, 2009 | 05:06 PM
bean's Avatar
bean
i don't have any pics, but pedro has the part. i'll have him sent me some pics or post them.
if buying new parts, i think that it is a no-brainer. the ATI is $425 and oem is $390. i was going to sell my functioning oem pulley, but i don't think that i can sell it w/ a clear conscience.
greg
Old Sep 29, 2009 | 05:22 PM
miniconcarne's Avatar
miniconcarne
On earlier year MINIs, I've heard it's not if they fail, but when!
I'll keep my eyes open for a used '05-'06 damper.
Old Sep 29, 2009 | 05:29 PM
miniconcarne
Never mind! https://www.northamericanmotoring.co...eplacment.html
Old Sep 29, 2009 | 05:41 PM
bean's Avatar
bean
i just posted in this thread about 2 06's that had crank pulley failures and stated that i wouldn't sell my functioning pulley when i replace it. mine has been track used/abused like my two friends whose pullies failed.
Old Sep 29, 2009 | 05:51 PM
miniconcarne
I'm a little slow!!
Old Sep 29, 2009 | 07:25 PM
drsilvermini's Avatar
drsilvermini
Can you notice any difference in throttle response? Or does the car feel the same?
Old Sep 29, 2009 | 09:00 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
Glad to see you got it on there. Like Bean said I had the luck of installing one over the weekend at Mickey and MINI when Pedro's stock 05 pulley came apart. I had our new ATI damper there just to show off, hadn't planned on installing it, but to his luck I put on the ATI damper and it worked great. For anyone that is going to upgrade this is the WAY to go. It's only 3 oz's lighter than the 05/06 pulley, but a couple pounds lighter than the earlier ones. Plus it dampens better than both.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Sep 30, 2009 | 07:43 AM
jhiggs26's Avatar
jhiggs26
Feels the same to me Drsilvermini = Grrrreat!
Nice of you to do the install with your demo ATI crank pulley WAY! Hopefully you installed it late in the day so you could at least show it off to the crowd.
Jeremy
Old Sep 30, 2009 | 10:33 AM
jbkone's Avatar
jbkone
Is this a problem on Coopers as well or only S' since they have more torque? Just wondering if I need to be concerned about my R50?
Old Sep 30, 2009 | 04:39 PM
bean's Avatar
bean
way: pedro doesn't visit here often, but i would like to thank you on his behalf. he now has a better pulley/damper for his application. he had never heard of the ATI damper. i told him that this was what i planned on installing on my race MINI. he didn't hesitate. he won't be disappointed. an added bonus is being able to drive home vs. flat-bedding. thanks, way.
greg
Old Oct 1, 2009 | 06:12 AM
MiniMacPR's Avatar
MiniMacPR
my facelift damper also failed mid-lap during a DE, just to throw another one to the sampling pool. Replaced w/oem. Once it fails again its going to be ATI or similar.
Old Oct 11, 2009 | 12:21 PM
okraD La's Avatar
okraD La
Wanted to log another Crank Pulley failure recently..Just had my OEM Crank Pulley shred at 80,000 miles, also broken tensioner.....(Bone stock 2002 MCS)....
