Drivetrain Spark plugs
Old Apr 15, 2016 | 07:41 PM
AFN704's Avatar
AFN704
Spark plugs
I want to buy spark plugs that are one heat range colder. I'd like really good ones as I've had some stumbling issues on cold days in the morning. Can I buy these at auto zone? If so what's the model number or name. If I can't get them in a store like that can someone give me a link. Also what's the best material? My car only has 35,000 miles on it. Do I need to change coil packs or and wiring? I'm going for Manic stage two and I'm only a catless downpipe away from getting it.
Old Apr 16, 2016 | 05:44 AM
cerenkov's Avatar
cerenkov
Get the ones listed in my signature (it is what Manic recommends). And typically you cannot buy these at your local auto parts store.
Old Apr 16, 2016 | 06:34 AM
AFN704's Avatar
AFN704
Thankyou but I don't see any signature. Any chance you could copy paste it here?
Old Apr 16, 2016 | 09:36 AM
bcriverjunky's Avatar
bcriverjunky
Originally Posted by afn704
thankyou but i don't see any signature. Any chance you could copy paste it here?
ngk ilkr8e6
Old Apr 16, 2016 | 10:19 AM
Indimanic's Avatar
Indimanic
You might want to gap them down a little depending on boost
Old Apr 16, 2016 | 10:38 AM
AFN704's Avatar
AFN704
What would you reccomendation for that? Also what would be the benefits of doing so vs not doing that? Also what kind of tool would I use?
Old Apr 16, 2016 | 10:56 AM
cerenkov's Avatar
cerenkov
A good gap Is 0.6 mm
Old Apr 16, 2016 | 12:18 PM
AFN704's Avatar
AFN704
So I'm about to order these plugs. Is anyone else using them and reccomendation them? I'm really close to the manic tune and I want to address this before I get it. They said to make sure my ignition system is good to go and I stumble on cold mornings a little bit. Now that it's warmer I don't have any problems though. So pull the trigger? Advanced auto parts has autolite ones that are the same specs. I feel like I should get these though since these aren't the stock plugs and Imore taking your guys word. I don't know much about plugs but if you run and reccomend them ill go for it
Old Apr 25, 2016 | 06:55 PM
Flyinace2000's Avatar
Flyinace2000
Don't use the autolights. Use NGK or the MiniOEMs. Don'e mess about with "off brands". See my thread here
https://www.northamericanmotoring.co...-r55s-n18.html
Old Apr 26, 2016 | 06:16 PM
oldbrokenwind's Avatar
oldbrokenwind
NGK ILKR8E6 --- aka NGK 1422 (the stock number). Manic recommended them for my stage 4 too. Apparently these plugs are good for most of their stages. I'm still on OEM coil packs and these plugs are a big improvement over the OEM version. The "6" in their part number translates to "0.6mm" (or 0.024") gap. The "8" indicates it's one range colder than the OEM version --- ILZKBR7A-8G (heat range 7, gap at 0.8mm).
Be advised that you'll need a different spark plug socket --- ⅝" hex and thin walled, for the NGK 1422 --- hard to find. I got mine from a Snap-On truck --- cost as much as a set of the plugs. My plug source was Amazon --- big selection of vendors.
Old Apr 27, 2016 | 03:12 AM
cerenkov's Avatar
cerenkov
oldbrokenwind is correct about the 5/8" socket. I went to Walmart and found a cheap Stanely ($5) that was thin walled enough to fit. Kobalt from Lowe's would not work nor would a Craftsman.
Whatever you do, do not force the socket down into the hole. It can get stuck. If you feel resistance, stop and remove the tool.
Old Apr 27, 2016 | 04:08 AM
AFN704's Avatar
AFN704
Hey guys thanks for the help. I'm about to order them right now. What is the socket for the regular ones?
Old Apr 27, 2016 | 07:52 AM
cerenkov's Avatar
cerenkov
14mm thin wall (12 point)
Old Apr 27, 2016 | 07:20 PM
Indimanic's Avatar
Indimanic
If not too late....go with the Brisk 8 or 12.
Burning fuel properly and efficiently is important and given my personal test results and the fact that silver conducts the charge with 580% more efficiency, the Silvers just make sense to me.
Old Apr 27, 2016 | 08:02 PM
oldbrokenwind
Brisk MR14YS is equivalent to NGK heat range 7 --- OEM.
Brisk MR12YS is one heat range colder --- equivalent to NGK heat range 8.
I could never get the 12's to work at high RPM's. Tried different gaps --- nothing but misfires.
I've also read that our ignition coils are designed for Iridium, and may not perform properly with a silver plug. Contradicts Indimanic, but my results indicate NGK 1422 is worth keeping.
Old Apr 28, 2016 | 01:19 PM
miniwpbear's Avatar
miniwpbear
Spark plugs
I use these https://www.amazon.com/gp/aw/d/B00UDK59F8
Gap .022
Burger tuning gives the recommendation but are cheapest at Amazon. I did buy their custom socket since it is good price and magnet.
http://www.burgertuning.com/N54_BMW_...t_adapter.html
I used these plugs on many MINI. Worked well on all N18 turbo engines. I read they work on all N14 and N54 and N55 as well.
Old May 2, 2016 | 06:43 AM
Indimanic's Avatar
Indimanic
Interesting the Brisks gave you some issues. I've read that silver is some 500% better at conducting electricity with way less resistance.
Logic would say that OEM coils would like that.
I do run the IP coils though.
The only issue I had w/ Brisk was the center electrode would melt
Old May 2, 2016 | 07:35 AM
AFN704's Avatar
AFN704
If people are having issues with silver then I'll probably stick with the NGK. I found them online for $40. No stores around here seem to have them though.
Old May 2, 2016 | 10:00 PM
renchjeep's Avatar
renchjeep
NGK 1422 seems like the way to go. Just installed mine. So far, so good. 30k miles later, we shall see.
Old May 8, 2016 | 07:45 PM
Indimanic's Avatar
Indimanic
The 1422 never gave me an issue but I feel the throttle response and power was noticeably better and with my tune I felt they are worth it.
When a driveability issues does arise, first thing I do is install the 1422 to rule out secondary ignition problems
Cannot go wrong with 1422 for the average Mini
Old May 8, 2016 | 07:48 PM
Indimanic's Avatar
Indimanic
I run the Brisk QR12LS not the MR as recommended by Brisk
Great smooth power delivery.
Old May 8, 2016 | 08:14 PM
AFN704's Avatar
AFN704
When a driveability issues do arise, first thing I do is install the 1422 to rule out secondary ignition.
Yeah I'm sold on the 1422 plugs. I just sold my JB+ since within the next month or 2 I'll have manic stage two so I'm using that money for that. I'd imagine it's still safe to go with Colder plugs though right?
ti22fjc
Aug 11, 2022 01:31 PM
allaboutdaz
Dec 14, 2020 04:33 AM
Biglove82
Nov 11, 2020 04:18 PM
Fooj GP
Apr 20, 2016 07:18 AM
penguinhomey
Apr 9, 2016 04:32 PM
