Drivetrain r53 Super Charger lag after 17% pulley?
Old Jan 1, 2015 | 09:56 AM
Steffen.Johnson's Avatar
Steffen.Johnson
Hey all, I recently installed a 17% pulley on my 2006 r53 automatic. I love the power and the change I got from the pulley etc. But I have been wondering if anyone else has had a short lag when they put the pedal down to the floor. I can hear the supercharger whining so elegantly but it builds up takes off and then there is a short hesitation and then it really kicks in more and pushes me into the seat is this normal for a r53 or supercharged car? Sorry if this is a stupid question just want to be sure its not something wrong...
Old Jan 1, 2015 | 10:17 AM
Mib4840's Avatar
Mib4840
Maybe your belt is slipping? Check the forums and see what belt is suggested for your setup. As far as I know, and my experience, it should be almost an immediate response.
Old Jan 1, 2015 | 10:33 AM
Steffen.Johnson
Its hard to explain. The response is immediate and it is quick dont get me wront but it almost winds up and then kicks in for a second time and goes even faster if that makes sense..I got the kit from Alta and they sent me the correct belt I don't believe its slipping just almost like hitting a powerban on a dirtbike when I was younger is the best way to explain it
Old Jan 1, 2015 | 11:02 AM
bavmotors's Avatar
bavmotors
Did u change your belt tensioner?
Old Jan 1, 2015 | 11:05 AM
Steffen.Johnson
No I didn't I changed the pulley and the belt. The tensioner was in good working condition. This isn't normal then?
Old Jan 1, 2015 | 11:09 AM
bavmotors's Avatar
bavmotors
Doesn't sound normal, the power should feel linear. Perhaps your bypass valve needs replacement. Mine was ok before my pulley install, but the extra boost was too much for the tired out spring.
Old Jan 1, 2015 | 11:16 AM
Steffen.Johnson
Damnit, this is what I didn't want to happen. Well like I said I have the automatic so that's one thing to consider.. And secondly I will say that it only does this when I go from regular drive to sport drive. Is there some kind of test or inspection of the items I can look into the rule out what it is?
Old Jan 1, 2015 | 11:29 AM
bavmotors's Avatar
bavmotors
I'm sure there's a way to tell without removing it. I know if you remove the bypass valve and press the plunger, the spring won't fully shut the valve if it's not working properly. Not something that needs immediate replacement but it's certainly nice to replace regardless. Some change to the Detroit tuned version which is OEM with a stiffer spring, I personally don't like the "harsh" feeling of it so I replaced it with an oem from Ecs for $90.
Old Jan 1, 2015 | 12:39 PM
Steffen.Johnson
Hmmm I have been reading a lot on here all day and exactly like you said it seems the bypass valve is the problem. The supercharger should pretty much be instantaneous not laggy, or yoyo like it is now. I appreciate the help and hope some others weigh in with opinions or past experience they have had with this issue. Im gonna replace the bypass valve next week reguardless but hiw could i tell if the belt is slipping? I would like to rule this out first
Old Jan 1, 2015 | 01:14 PM
AndyPWR53's Avatar
AndyPWR53
Bypass valves were already improved in 05 and unless you were having issues like this before, there isn't really any reason to assume that adding a pulley made the bpv go bad. It sounds to me more like your transmission downshifting when you floor it? Thats what I'm getting from your description at least. If your just cruising along in an automatic its going to be in a high gear for mpg, but when you mash the pedal it will downshift first before it does anything. Perhaps you just notice this more now that you're making more boost?
Old Jan 1, 2015 | 01:35 PM
Steffen.Johnson
Oh ok well mines a 2006 so that shouldn't be an issue then, and I didn't notice much issue before I installed the pulley. I guess I didn't really know what to expect when I installed the pulley kit. Yes it has a good amount of power and response but it is hard to explain honestly. I'll be crusing around 35mph then I'll push the shifter over to sport mode. At that moment I push the petal to the floor and the supercharger gas power and is quick then for a second you can feel it build up and then kick in almost like more boost or more power band and then it pins me back in my seat. I guess I was thinking it would more or less be instantaneous as a supercharger should be. I drove a friends wrx sti for a month and I know what it is like to have the turbo build up and it honestly feels like that a little bit.
Old Jan 1, 2015 | 02:28 PM
bavmotors's Avatar
bavmotors
Well I have a 2005 with the updated bypass and my yoyo issue went away with a new bypass valve. Whether it's your issue or not, I have no idea, I'm just offering my experiences. Hopefully you sort it out.
Old Jan 1, 2015 | 06:14 PM
crazyworld's Avatar
crazyworld
Can you shift through the gears yourself and get yourself to second and mash the throttle and see if you experience the same thing to rule out downshifting?
Whens the last time you replaced plugs/wires? I ask because although I replaced my plugs with my pulley, I didn't realize how bad my wires were and noticed a hesitation after my install. Eventually it turned into a full-on misfire and was easier to diagnose once I threw that code.
Old Jan 1, 2015 | 06:39 PM
Steffen.Johnson
Ill try tmrw to paddleshift it into second and check from there and let you know.
As far as plugs go I installed them as well with the kit I used the factory gap out of the box if that makes a difference? I also have a MSD coil pack, and brand new wires to install tmrw. The wires and coil pack on there now are both stock and I have about 124,000 miles on them..
Old Jan 1, 2015 | 06:42 PM
bavmotors's Avatar
bavmotors
I also had to replace my wires after my pulley because of some bad hesitation but it sounds like your getting a boost yo-yo effect.
Old Jan 2, 2015 | 12:22 PM
Steffen.Johnson
UPDATE:
I took it out and shifted into second mashed the petal to the floor and it was solid power all the way till it shifted into third. I am honestly a little embarrassed that I didn't think of that first myself.
I am also going to recheck the plug gaps, install the coil pack, and new wires today to see if that rules out any slight hesitation. If theres still a little bit I think I am going to eventually just pick up the bypass valve and have that piece of mind.
Thank you all for the help, I love this forum and all the quick and valuable responses I got. You guys rock!
Old Jan 2, 2015 | 12:28 PM
crazyworld's Avatar
crazyworld
Sweet! Glad to hear all is well. Sounds like someone might be doing some more paddleshifting in the future :D
Old Jan 3, 2015 | 06:35 PM
Steffen.Johnson
Thats for sure. I actually got the feeling back today, it felt a little sluggish then at around 5000rpm seemed like it kicked in until it shifted at 6700ish rpms? I think my bypass valve might be off or something because I installed new plugs, wires, coil pack, and gaped the plugs properly and I am still getting a power ban feeling and sluggish almost behavior until 5000rpm?
Any thoughts?
Old Jan 3, 2015 | 08:49 PM
Steffen.Johnson
I installed the 17% pulley, and belt that was provided in the alta kit. I opted out of the alta tensioner stop and I am still running all stock parts. How would I test these options.. I was going to try the bypass valve next..
Old Jan 3, 2015 | 08:50 PM
Steffen.Johnson
Originally Posted by Dave.0
You don't get lag from a SC it's always running. You have a crap belt ofr a failing belt tensioner causing the belt to slip. It you still have the OEM crank damper on it may be failing also. If you crank damper fails you can F up your motor so just but the ATI damper and be done with it. Don't wa your money on the crap M7 or ALTA non dampened crank pulley they are junk. They are dampened for a reason, harmonics.
What's the crank pulley?
Old Jan 3, 2015 | 11:05 PM
minsanity's Avatar
minsanity
Listen to the wisdom of Dave O. & the guys from the Alliance of Motoring.
If your crankshaft pulley(main drive from engine) is starting to fail, go ATI Super Damper.
Check your belt tensioner's lil strut/shock. If it offers no resistance, Get a new $80 Gates tensioner (same as OE) off Amazon or Rockauto.
Old Jan 4, 2015 | 11:55 AM
crazyworld's Avatar
crazyworld
I believe some people have zip tied their bypass valve to test it so you can search around more here and maybe try that.
Old Jan 6, 2015 | 10:10 AM
Steffen.Johnson
Ill give that a try, I have been told recently its the automatic transmission and the ECU reset trying to learn the new pulley I am going to give it some time before I go crazy it seems to be mellowing out now too!
Old Jan 6, 2015 | 08:27 PM
minsanity's Avatar
minsanity
Take care of that AISIN tranny by religiously following recommended fluid change intervals. It's not as delicate as the ticking timebomb CVTs, but neither is it as bulletproof as Getrags.
Old Jan 6, 2015 | 09:07 PM
Steffen.Johnson
Where could I find the interval information is there a site for this?
