Drivetrain r53 Super Charger lag after 17% pulley?
Old Jan 7, 2015 | 05:05 AM
  #26
minsanity's Avatar
minsanity
Check this thread: Post 13
https://www.northamericanmotoring.co...ed-at-80k.html
Old Jan 7, 2015 | 08:19 AM
  #27
Steffen.Johnson's Avatar
Steffen.Johnson
Originally Posted by minsanity
Thanks, I have 125,00 on the clock and no issues but I am going to look into doing this soon!
Old Dec 6, 2015 | 08:23 AM
  #28
zakindi's Avatar
zakindi
Hi Steffen,
I stumbled upon your post after searching long and hard. I too have exactly the same problem with my cooper s, it is a 2005 model with auto transmission. Since having the 17% pulley kit fitted I am getting the same symptoms as you, almost like a momentary pause/cut in power at about 4000rpm till just after, then bang pulls hard again. I drive in manual sport mode all the time so I know this is not kick down. I've recently had a remap to see if that would sort it but no luck and I've just fitted a new bypass valve but still no luck. The car has only covered 41,000 miles so I cannot see this being a transmission problem. I am running out of ideas. The autos are much less common in the UK so I am having trouble reaching out to anyone over here with any kind of answers. Did you manage to get to the bottom of it? I would really appreciate and kind of help.
cheers
Zach
Old Jan 5, 2016 | 08:24 PM
  #29
Deej Ledingham's Avatar
Deej Ledingham
Originally Posted by Steffen.Johnson
Ill try tmrw to paddleshift it into second and check from there and let you know.
As far as plugs go I installed them as well with the kit I used the factory gap out of the box if that makes a difference? I also have a MSD coil pack, and brand new wires to install tmrw. The wires and coil pack on there now are both stock and I have about 124,000 miles on them..
Try gapping your plugs @ .55, then try it at .60, then last @ .65. When you do this run your car for a day or so just to get the feel of each. With the MSD pack, .60 is where you might have your best luck. But every car is different.
gmonde
Sep 8, 2015 06:37 AM
mackedmini
Aug 20, 2015 02:35 AM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
