Drivetrain Building my own exhaust
Old Dec 5, 2014 | 07:12 AM
whrisk's Avatar
whrisk
I have found all the parts i am looking for, except for one. Does anyone know where i can get the piece that attaches to the downpipe? I dont even know what you would call it.
Old Dec 5, 2014 | 07:58 AM
ridinDirty's Avatar
ridinDirty
This is to bolt up to a stock down pipe ? what size exhaust pipe are you going with ? are you adding a flex connection ?
Old Dec 5, 2014 | 08:41 AM
whrisk's Avatar
whrisk
i am going to use a catless downpipe that will bolt to the stock exhaust so yes it would have to be compatible with that. 2.5 inch with flex pipe.
Old Dec 5, 2014 | 09:15 AM
CornerCarver's Avatar
CornerCarver
Are you talking about the metal flange?
Old Dec 5, 2014 | 09:18 AM
whrisk's Avatar
whrisk
no, that is not it. let me find a pic.
Old Dec 5, 2014 | 09:26 AM
whrisk's Avatar
whrisk
it is the part just in front of the flex pipe that the v-band clamps to.
Old Dec 5, 2014 | 09:29 AM
ridinDirty's Avatar
ridinDirty
oh , I miss read. I thought you said exhaust , as in exhaust system. If your just adding a DP then who ever sold you the dp should have the adaptor to fit the metric exhaust.
JM turbo sold me the adaptor with their dp that could fit the stock exhaust or 3"
You might could contact them and see if they sell just the adaptor.
Old Dec 5, 2014 | 09:44 AM
ridinDirty's Avatar
ridinDirty
below is the adaptor in the plastic bag
Old Dec 5, 2014 | 09:47 AM
ridinDirty's Avatar
ridinDirty
https://www.northamericanmotoring.co...afr-bunge.html
okay, says my pic is all ready attached from an earlier post... I can never figure out how to post pics....
the link has a few pics of the adaptor.... hope this helps
Old Dec 5, 2014 | 09:49 AM
whrisk's Avatar
whrisk
no, i am going to be building a downpipe back exhaust and need the piece that connects to the downpipe.
I am going to be using a downpipe that fits the stock exhaust, so i just need the piece that attaches to the downpipe.
Is that more clear. its the piece on the exhaust picture i posted that is before the flex pipe.
EDIT: Basically i am building what is in the picture i posted (downpipe back exhaust system), and i need to find the piece that is before the flex pipe in the picture.
Old Dec 5, 2014 | 02:31 PM
ridinDirty's Avatar
ridinDirty
I take it you want to save your stock exhaust ? I would just cut the end off the stock and weld it to your new system.......you can always weld it back on your stock if you go back to stock....
Someone here might have their old exhaust they can cut it off.....
Old Dec 6, 2014 | 08:16 AM
sbninja's Avatar
sbninja
@ Whrisk - You need a V-Band flange (weld).comes in different sizes (diameters) you can reuse your factory V-band clamp or buy a new one. Jegs or Summit Racing should have what your looking for.
Old Dec 6, 2014 | 09:18 AM
ridinDirty's Avatar
ridinDirty
I think its metric tho
Old Dec 7, 2014 | 03:02 PM
whrisk's Avatar
whrisk
Yes I do not want to hack into my stock exhaust.
Thank you for letting me know that name. I will see what I can find.
Old Dec 7, 2014 | 03:06 PM
whrisk's Avatar
whrisk
http://m.summitracing.com/parts/vpe-1490s
Just doesn't look the same. Does anyone know if it will work?
Old Dec 9, 2014 | 08:30 AM
whrisk's Avatar
whrisk
well, i bought that v-band flange from summit, i guess i will see if it work or not.
Old Dec 9, 2014 | 01:34 PM
sbninja's Avatar
sbninja
Seems I was wrong. Looks to be a "ball joint" type connection?
Old Dec 9, 2014 | 02:23 PM
Mini Union's Avatar
Mini Union
try this....
http://www.summitracing.com/parts/fl...FdGCfgodgVMAkw
Old Dec 9, 2014 | 04:38 PM
sbninja's Avatar
sbninja
Originally Posted by Mini Union
But the clamp on the factory system looks more like the v-band clamp.
More like this....
http://www.ebay.co.uk/itm/EXHAUST-JO...-/261200084309
Old Dec 10, 2014 | 06:17 AM
whrisk's Avatar
whrisk
More like this....
yes it does look more like that. i have already ordered the one i posted from summit. i am going to see if it will work. if not i may try the one that one.
Old Dec 15, 2014 | 08:50 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
I bought a 2.5" stainless pipe with a 3" flare similar to this one.
http://www.ebay.com/itm/PFAB-2-5-to-3-304-Stainless-steel-Flare-pipe-16-gauge-/261423568471?hash=item3cde0f1657&vxp=mtrThen coupled it with an exhaust doughnut and the original v-band clamp. Worked like a charm. An exhaust shop can also probably flare the piper for you.
Old Dec 17, 2014 | 08:44 AM
whrisk's Avatar
whrisk
thanks for all the help everyone, but my how plans change quickly.
Just bought an Invidia Q300 DP back exhaust. I could not pass up the great deal.
Old Dec 17, 2014 | 11:51 AM
sbninja's Avatar
sbninja
Lol I had thought about doing my own exhaust , but there are some really nice bolt in systems out there.
Old Dec 17, 2014 | 12:19 PM
whrisk's Avatar
whrisk
yeah, its just that most of them are so expensive. i could build one for half the price of most of the ones on the market. but i got this one used, still in real good shape for less then i can build an exhaust for, so i had to buy it.
Teh
Aug 22, 2022 04:37 AM
gmcnaugh
Oct 27, 2018 03:42 AM
mishanja
Jun 22, 2016 09:59 AM
xpunisherx
Nov 27, 2015 03:32 PM
embiggenedmini
Oct 15, 2015 12:36 PM
