Drivetrain Dash Command data log graphs
Old Nov 24, 2013 | 09:15 PM
  #76
wzabrouski's Avatar
wzabrouski
Originally Posted by pepperwhiteknight
Are the R56 and R60 different? I use CALC.AFR_ACTUAL. Have you validated the PIDs and set the fuel type in scanxl?
Validated but did not set fuel type.
Old Nov 24, 2013 | 09:16 PM
  #77
wzabrouski's Avatar
wzabrouski
Originally Posted by cerenkov
Do you have a licensed version or just the unregistered version? Can you scan other PIDs like speed? I can only get RPM to work, on the console log, for the other PIDs it says something like "not scanning unlicensed PID". So that leads me to believe that I'll have to purchase the licensed version.
Full version.
Old Nov 24, 2013 | 09:18 PM
  #78
cerenkov's Avatar
cerenkov
Originally Posted by wzabrouski
Full version.
Can you post a graph?
Old Nov 25, 2013 | 04:33 PM
  #79
wzabrouski's Avatar
wzabrouski
If I had data logged.
Old Nov 25, 2013 | 04:49 PM
  #80
wzabrouski's Avatar
wzabrouski
I can if someone had data to send me.
Old Nov 25, 2013 | 07:58 PM
  #81
pepperwhiteknight's Avatar
pepperwhiteknight
Do you want me to send a data file from dashcommand iOS?
Are you trying to use a laptop with scanxl to talk directly to the car?
Old Nov 25, 2013 | 10:36 PM
  #82
wzabrouski's Avatar
wzabrouski
I can log with ScanXL. I just can't get the AFR to log.
Old Nov 26, 2013 | 10:31 AM
  #83
cerenkov's Avatar
cerenkov
Before I buy the full version, I just want to know the quality of the graphs with ScanXL, i.e. are they stair-stepped? The one I did (as posted above) was RPM only and turned out great but does this remain true when scanning 8 PIDs?
Old Nov 26, 2013 | 04:32 PM
  #84
wzabrouski's Avatar
wzabrouski
Response time does get slower the more pids you add but if I can remember correctly you can set priorities to them. I have had it for almost 5 years as it was recommended when I was remote tuning my R53.
Old Nov 26, 2013 | 04:55 PM
  #85
wzabrouski's Avatar
wzabrouski
If you want to email be a log, I can throw in a graph. I also think I have a log on my laptop from my R53 I can post.
Old Nov 27, 2013 | 07:38 AM
  #86
cerenkov's Avatar
cerenkov
Thanks, but it won't work if I email you one of my logs because ScanXL does not record the data from the PIDs (other than RPM) with the trial version. I think I'm just going to purchase the license, I'll use it no matter what and it's on sale for $79.
Actually, I just ordered it, used coupon code "mp3car" for an additional 15% off.
Old Nov 27, 2013 | 11:25 AM
  #87
pepperwhiteknight
That is a great deal just to get rid of the nag screen. I still prefer to use my phone to log data.
Old Nov 28, 2013 | 04:16 PM
  #88
cerenkov's Avatar
cerenkov
I have the full version now and I can't get AFR, boost or AAT to work??? It has to be a simple fix because DashCommand works. I'll work on it and report back.
The data rates are awesome though.
Old Nov 28, 2013 | 07:37 PM
  #89
cerenkov's Avatar
cerenkov
ScanXL PID problem solved.
1.) Click on the "settings" tab
2.) Click on "PID Config"
3.) Check the PIDs that you want to monitor
You should be good to go!
All mine are working now
Old Nov 28, 2013 | 08:08 PM
  #90
wzabrouski's Avatar
wzabrouski
That's awesome! Which PID did you select for the AFR? I remember there being a few.
Old Nov 28, 2013 | 08:11 PM
  #91
cerenkov's Avatar
cerenkov
that's awesome! Which pid did you select for the afr? I remember there being a few.
calc.afr_actual
Old Nov 28, 2013 | 08:22 PM
  #92
wzabrouski's Avatar
wzabrouski
Thanks!
Old Nov 28, 2013 | 09:14 PM
  #93
wzabrouski's Avatar
wzabrouski
How did you edit the names on the pics shown on the graph. I can change everything else but the name.
Old Nov 28, 2013 | 09:28 PM
  #94
cerenkov's Avatar
cerenkov
Names on the graph are:
1.) Graph settings
2.) "Text Areas" tab
3.) select Title PID1 (or whatever number you what to change)
4.) type whatever you want in "Format String"
Old Nov 28, 2013 | 10:01 PM
  #95
wzabrouski's Avatar
wzabrouski
Thanks. That was driving me nuts!! All set to log some runs tomorrow.
Old Nov 29, 2013 | 08:55 AM
  #96
wzabrouski's Avatar
wzabrouski
Another quick questions. How did you get it to identify .5? For example boost at 11.5 or AFR at 12.5. Mine are on whole numbers.
Old Nov 29, 2013 | 09:04 AM
  #97
cerenkov's Avatar
cerenkov
To adjust the decimal format:
Under graph settings
Text areas tab
Select the "value PID"
Format String
%.Xf
Where X is:
0 = no decimal places
1 = one decimal
2 = two decimal
etc
Old Nov 29, 2013 | 09:23 AM
  #98
wzabrouski's Avatar
wzabrouski
You rock!!
Old Nov 29, 2013 | 09:26 AM
  #99
wzabrouski's Avatar
wzabrouski
Here is what I got on a 3rd to 4th.
Old Dec 2, 2013 | 06:12 PM
  #100
Mindspin311's Avatar
Mindspin311
I can confirm that this device works flawlessly with DashCommand, received it today and it connected just fine.
