Drivetrain What SC pulley do I have?
Old Aug 28, 2013 | 11:00 AM
AlphaFox's Avatar
AlphaFox
I recently bought an 03 MCS with 57,XXX miles on it. The original owner changed the SC pulley, but it doesn't have any identifying marks. Can anyone identify this pulley? I want to make sure I can order the right belt when Inspection II rolls around.
Old Aug 28, 2013 | 12:17 PM
ZippyNH's Avatar
ZippyNH
Look for a stamp for a reduction amount....
A typical 535 length, 6 rib belt from the local autoparts store will fit a 15% or a 17% fine....cost you $25 or so....maybe less.... At that price you could get a 532 belt too....fits a 17% better...see what fits better.....
Old Aug 28, 2013 | 12:20 PM
c0op3r's Avatar
c0op3r
I can tell you that its not like my Alta.
But it should use a regular belt, just the size smaller, that is correct for the 15% pulley.
Old Aug 28, 2013 | 01:17 PM
AlphaFox's Avatar
AlphaFox
I'm not seeing any stamping whatsoever. Where might it be? Is there any other way to tell what size it is?
Old Aug 28, 2013 | 01:20 PM
MIKESGREENMINI's Avatar
MIKESGREENMINI
looks like my helix pulley no markings on mine either. Just get the belt for the JCW or a 535 or 532 should work
Old Aug 28, 2013 | 05:52 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
He is correct that is a Helix pulley, looks to be a 15% pulley.
Old Aug 28, 2013 | 06:35 PM
AlphaFox's Avatar
AlphaFox
Thanks for the responses!
Old Oct 27, 2013 | 01:12 PM
AlphaFox's Avatar
AlphaFox
I am finishing up my tensioner & ATI install, and I've gotten to the point of installing my new belt. I got a 535, and despite every four-letter word I can come up with, I haven't been able to get it on. It turns out my old belt was a 539. Is the 535 too short, or am I being a wuss?
Old Oct 27, 2013 | 01:45 PM
ZippyNH's Avatar
ZippyNH
If your crank pulley is a +2%...the 539 might be right...
A 535 is doable (with a 15%, stock crank damper size)with somebody pulling back on the tensioner with the tool...simply locked In place the belt will be too tight...so have a helper pull back on it...should be able to thread it on fine.
A 539 should be fine though...might slip at higher rpms when it is a bit older...
Old Oct 28, 2013 | 02:41 AM
AlphaFox's Avatar
AlphaFox
I fought this thing for a long time yesterday. I had the tensioner tool in the second hole, and the belt was just too short. I ended up putting the old 539 back on so I could drive the car today. The ATI is standard size. Does this suggest the SC pulley could be something other than a 15% reduction?
Old Oct 28, 2013 | 07:59 AM
ZippyNH's Avatar
ZippyNH
Read my above post....
To get s 535 on...it usually requires a 2nd person to pull back on the tensioner...you can't do it when it is pinned....
Old Oct 28, 2013 | 08:05 PM
GreekDrifter91's Avatar
GreekDrifter91
try leaving the idle pulley last. you should be able to get it on even with the tensioner pinned in the second hole. a lot of people say you need help but i got my 532 belt on by my self by leaving the idle pulley last and walking it on. it took a little time but got it on.
just 17% pulley and stock crank pulley
Old Nov 1, 2013 | 05:17 AM
AlphaFox's Avatar
AlphaFox
Originally Posted by ZippyNH
Read my above post.... To get s 535 on...it usually requires a 2nd person to pull back on the tensioner...you can't do it when it is pinned....
You were correct, which seems to be awfully common. Thanks for the advice!
bahman
Feb 14, 2016 10:29 AM
Debi's Coop S
Oct 3, 2015 08:19 AM
fkrowland
Sep 30, 2015 10:30 AM
audio131
Sep 28, 2015 02:21 PM
daviday
Sep 25, 2015 01:31 AM
