Drivetrain Help with ECU part number
Old Aug 15, 2013 | 04:58 PM
Gaspar Crespo's Avatar
Gaspar Crespo
HI
Would you please tell me if this part is the 12147601756 from realoem?
I dont know how to read this bosch label and i need an ECU for my R56 N14 2008 turbo automatic.
Thanks!!!!
Old Aug 16, 2013 | 08:06 AM
Hello,
DME have the same group part number based on related ECUs of that model. Based off that 1214 is the beginning and 7586132
I could not find that part number on The DME 12147586132 , the closet part number is 12147586137. It must be an old part number that was cancelled or something.
But there is hope . I can see the DME is marked with the last 7 digits of the VIN it came out of. " TV35729 "
That ECU was from a 4/2008 Production R56 MINI Cooper S N14 engine
And it was a Pepper White / Black Roof / Black Mirrors / Glass Roof : Automatic Transmission MINI
Does that sound like the MINI it came out of ? Thats what I get for that VIN.
Old Aug 16, 2013 | 09:46 AM
Gaspar Crespo
Thanks so much ECSTuning!!
This are the ECU compatible with my car from realOEM:
12147631101 ENDED
12147590858 ENDED
12147601756 CURRENT
So based on your label read i should get one that has print 7601756 right?
Thanks btw how do you get all the info from those vin numbers_
thanks again
Old Aug 16, 2013 | 10:11 AM
You are welcome,
Yes the Part number does not come up for the one stamped on the unit. But it might be older and realoem does not show the older part numbers that I can see. When they update that site some of the oldest part numbers fall off. The part number on that unit is just an older part number. Same part number auto and manual trans. I can get some information from the VIN. " TV35729 " is that you car ecu or another?
12147631101 older superceded
12147590858 older superceded
12147601756 newest
Newest ECU that is available.
http://www.ecstuning.com/Search/SiteSearch/12147601756/
Old Aug 16, 2013 | 01:32 PM
Gaspar Crespo
Thanks again!! Really good info!!
OK here is my info:
THis is my vin TV33778 supposed to be a N14 R56 Turbo S Automatic 6 speed, xenon, sunroof. Thats all i know so far.
THe picture that i posted before is an ECU that has the same number as the one in my car. The one in my car is not working, i dont have the funds to buy one new, so my best guess is to get one from ebay, but i dont know which one to pick.
Please check the following links and maybe you can tell me which one is good for my car:
this is the one that i really like and can afford:
http://www.ebay.com/itm/400324922339...84.m1436.l2649
Supposed to be from TW84687
And this one too:
http://www.ebay.com/itm/390551795415...84.m1436.l2649
TT88831
Thanks!!
Old Aug 16, 2013 | 01:56 PM
You are welcome,
I can help you with the VINs and the part numbers. When its get to the older part numbers there is some many that are not on the visual sequence.
Your Vin TV33778 1/2008 R56 MINI Cooper S N14 newest part number 12147601756
TW84687 1/2009 R56 MINI Cooper S N14 newest part number 12147601756
TT88831 2/2008 R56 MINI Cooper S N14 newest part number 12147601756
They all have the same past part numbers sequence.
Hope that helps make sense of it. And good luck with the part search, if you need any new parts let me know.
Old Sep 16, 2013 | 07:28 AM
Gaspar Crespo
Hi
IF i bought a new ECU from ECS, will it come preprogrammed with my VIN?
Old Sep 16, 2013 | 07:51 AM
PM'd.
Old Jun 30, 2020 | 12:55 PM
Bigjohn70's Avatar
Bigjohn70
2007 mini s ecu
I have a 2007 mini s, 6 speed, chili hatchback, and the ECU has been diagnosed as BAD.MY VIn is TT81591. Will the same number 12147601756 work on my car. I noticed that the question from Cesar re his automatic car needs the same part number is this correct. Also, it appears that part numbers 12147586132, and 12147586137 were the original part numbers, and ...756 replaced them. Since when does a car company change the part numbers on their parts?
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
ryGuyMCS
Oct 20, 2015 02:24 PM
absolutcamper
Aug 24, 2015 12:27 PM
vanhick
Aug 19, 2015 09:03 AM
xraycat
Aug 15, 2015 06:43 AM
