Drivetrain Burger Motorsports (BMS) Tune(s)
Old Oct 14, 2013 | 07:38 AM
  #576
Sly Cooper's Avatar
Sly Cooper
Originally Posted by borderwave2
I agree that linear throttle map is ideal, but I don't think it's worth the $$$ for something that just changes the "feel" of the throttle.
Yes the throttle response will seem better, but the same results could be achieved by simply pushing the accelerator further, or pushing the sport button if you're lazy. I believe that 100% throttle with sprint booster and 100% throttle stock will produce exactly the same power.
Much like the sport button, sprint booster will make your car feel faster, but it won't actually be any faster than quickly mashing the gas, which doesn't cost anything.
This could actually solve one of my biggest gripes, which is that the revs don't rise quickly enough when you blip the gas on downshifts. Booster users, what do you say?
Old Oct 14, 2013 | 10:38 AM
  #577
borderwave2's Avatar
borderwave2
Have you tried the sport button? It essentially does the same thing.
Old Oct 14, 2013 | 10:39 AM
  #578
Sly Cooper's Avatar
Sly Cooper
Putting it in sport is the first thing I do after starting it. Still can't match the response of a car with a mechanical linkage.
Old Oct 14, 2013 | 11:28 AM
  #579
iminir56's Avatar
iminir56
something about putting the pedal to the floor when wanting to pass someone as appose to just halfway makes it seem like you're not pushing the car to hard
Old Oct 14, 2013 | 11:30 AM
  #580
cerenkov's Avatar
cerenkov
I found a place (Mayhem Motorsports) in Raleigh to dyno my car with and without the JB+. The charge $100 for 3 pulls. Which sounds about average. I'll try and get it scheduled in the next week or so.
What is the proper procedure in dyno'ing the car. Traction control on or off? My car is an automatic, do I do it in manual mode, what gear etc? Any advice would be great.
I'll be doing both sets (with and without JB+) back to back to factor out ambient affects as much as possible.
Old Oct 14, 2013 | 11:40 AM
  #581
yetti96's Avatar
yetti96
So are you going to get it on the car and adapted and do a run, take it off and see or what was your plan? It takes about 100 miles to get the full adaptation going to the tune. Also, the dyno shop will worry about the car and gear.
Manual mode will help keep it in gear, but if they go up to 3rd or 4th and floor it at a slow speed it can downshift and at redline it will shift so there isn't much you can do to control the tranny.
Traction control on or off, it wont matter as the car will be getting full traction.
Old Oct 14, 2013 | 11:56 AM
  #582
Chandler5192's Avatar
Chandler5192
Traction control will have to be off! The car will sense that the front wheels are moving and the rears are not, giving it the illusion that you are doing a nasty burn out!!! Turn traction off! I had this happen to me when I had 16's on the rear and 17's up front for tire swapping purposes.
Old Oct 14, 2013 | 12:00 PM
  #583
jomama's Avatar
jomama
what yetti suggested - dyno with jb+ on first, and then take it off and dyno w/o the jb+. that way, you don't have to wait for the car to adapt for 50-100 miles to get the actual readings for the jb+. i was planning on dynoing some matrix of an evolve dp on/off, and jb+ on/off, but haven't gotten around to it yet.
Old Oct 14, 2013 | 12:59 PM
  #584
cerenkov's Avatar
cerenkov
The JB+ is already installed and has been for about 1000 miles. So I'll definitely do that first. Then I'll remove it and compare. I'll also turn off traction control.
Old Oct 14, 2013 | 05:29 PM
  #585
PenguinOnTheTelly's Avatar
PenguinOnTheTelly
My JB+ Update
OK today 60 deg F and sunny. 250 miles since installation. Using 93 octane Shell V-Power with 10% ethanol blend. Cleaned the K&N on my DDM Works Race Intake (it was due). Boost peaked at 16.25 psi on a hard run in third gear and stayed there. I have to admit as a born skeptic I was a little skeptical going into this...now I'm convinced. Wonder if I've hit the max or if it'll boost further on a hot day? Very happy.
Guess I have to start spending money on the suspension now.
Old Oct 14, 2013 | 06:46 PM
  #586
Dustypants's Avatar
Dustypants
After having a seriously fun 2 weeks running around 97 octane (100/91 mix) and the JB+ at 6 (if 5 is the stock setting), I backed it down to stock and am back to a full tank of 76 '91.
This morning at 530 am cruising down 101 on the way to work I got the 3 honk from a guy in an s2000. I backed out when over boost kicked in and hit 18psi and by then I was an exit away from work.
JB+ and some standard bolt-ons/suspension mods = smooth reliable power all day long.
Go get it.
Old Oct 14, 2013 | 09:56 PM
  #587
ChaiLatte's Avatar
ChaiLatte
Originally Posted by Mcameron
umm no, it doesnt.
it doesnt act as linearly as 25% = 45%, what it does is steepen the throttle curve
like this:
that way there is no "dead spot" in the pedal.
i have the D1 SPEC in my car and love it, makes the pedal much more responsive......ive driven with the stock mode, and ive driven with the throttle adjuster, and i can tell you just mashing the pedal is not quote the same.
Would it be safe to say the Sprint Booster gives you linear throttle response like that of a throttle cable?
Old Oct 15, 2013 | 04:30 AM
  #588
Mcameron's Avatar
Mcameron
I can't say as I don't have a sprint booster, I'm running a d1 spec, which operates the same way.....
As for the d1 spec, I don't really have any way to measure if it makes it more linear...... But it definitely makes the pedal far more responsive. And the d1 spec has 9 sport mode settings to choose from.
To me personally, no drive by wire will ever feel like a mechanical connection, regardless if what booster system you use.
Old Oct 15, 2013 | 09:15 AM
  #589
Terry @ BMS's Avatar
Terry @ BMS
On the throttle boosters, I'm not a big fan especially on turbocharged vehicles. They already have a non-linear pedal input to torque output relationship (with full torque coming in around 75% throttle input at full spool) which makes the car difficult to control. Compressing the pedal input even further to say 0-40% as the pedal booster boxes do makes the car even less controllable. Not to mention, you can get the same effect by pressing the gas pedal down a bit further when you want it. I always joke with people to save their money and buy heavier shoes.
On fly by wire, keep in mind by separating pedal input vs. throttle movement the throttle can now also be used for other purposes. Like torque limiting, assisting with boost control, a soft rev limiter, etc. All good stuff.
Old Oct 15, 2013 | 09:40 AM
  #590
Mcameron's Avatar
Mcameron
I feel the 'control' issue is more a matter if personal preference..... I know for me, I feel more in controll being able to Adapt the car to my driving habits than having to adjust my driving habits to suit the car......
There are time when I'll switch setting while I'm driving to adjust for road conditions......for normal driving conditions, I'll keep my d1 spec set to sport mode..... However if I encounter hills or heavy rains or snow, I feel better with it in 'economy' mode to dull the throttle response......I've also found 'economy' mode is good for driving passengers as it makes shifting a lot smoother, that way my passengers aren't being jerked around.
I also like the ' super economy' modes, just in case someone want to borrow my car, I'll know they won't have too much fun in it.
Old Oct 15, 2013 | 10:38 AM
  #591
Terry @ BMS
I know many people love them. It's a product that is out there and widely used. While it's not my cup of tea personally the good news is they are fully compatible with the JB+.
FWIW the F chassis BMWs have added "econ", "comfort", and "sport" modes which also remap the pedal to torque in a similar way. I guess they stole sprint-boosters idea.
Old Oct 15, 2013 | 10:40 AM
  #592
jomama's Avatar
jomama
sounds like someone could have used a good patent atty. =)
Old Oct 15, 2013 | 12:21 PM
  #593
BackroadRunner's Avatar
BackroadRunner
I received my jb+ and can tool today. I can't get my car to recognize the can tool so that i can configure it. I connected it with the key in and then pressed and held the button on the can tool. Nothing happened. Tried the same with the car running with the same results. Also tried connecting the can tool before inserting key. Have tried holding the button on the tool and also press and release, all with no reaction from the car. What am i doing wrong?
Old Oct 15, 2013 | 01:40 PM
  #594
HorizonBLueN18's Avatar
HorizonBLueN18
So just to get my name in line on the list I went to bms and ordered a JB+. 20 min later I get confirmation order and a tracking number. It shipped!!!
Old Oct 15, 2013 | 02:16 PM
  #595
chrunck's Avatar
chrunck
I can tell you what I did though it sounds like you may have a bad unit. First, I connected to the obd port. Second, I started the car. Third, I held the button until the tach turned orange. Then from there programmed.
Old Oct 15, 2013 | 02:43 PM
  #596
BackroadRunner
Ok, my can tool is working perfectly now. Nothing i did while parked was able to recognize the tool. I drove a few hundred feet and, while moving, pressed and held the button and voila!, the can tool went into config mode. I parked and went through all the config settings for the mini and it is set.
As for the JB+, it made an almost instantly noticeable difference. I have driven about 20 or so miles and it feels great!
Question- I am running 93 octane gas. All of the pumps around here say that the gas contains 10% ethanol or may contain up to 10% ethanol. Does that have any affect on mixing in 10-20% e85?
Old Oct 15, 2013 | 04:04 PM
  #597
Roxspin72's Avatar
Roxspin72
JB+ CAN Tool
Dose this come with preset High-jacking modes. I got my stuff in today but there is no BMS USB cable. Am I going to need this IOT run the CAN tool. Or is it all plug and play. If so when would I need the BMS USB? help me out guys, Because I am so itching to plug and Play
Old Oct 15, 2013 | 04:29 PM
  #598
Brandonpt's Avatar
Brandonpt
you dont need any of that. Just plug it in, hold the button for a couple of seconds and look up the chart on the instalarion instruction. The speedo will display which gauge youre hijacking and the tach will display the setting
Old Oct 15, 2013 | 04:47 PM
  #599
Roxspin72's Avatar
Roxspin72
Awesome
Thanks. Currently waiting prescribed 15 Min with hood open and doors locked. Then the install begins
Old Oct 15, 2013 | 04:55 PM
  #600
ChaiLatte's Avatar
ChaiLatte
LOL. For a second I was going insane because I ordered mine 3 days ago and still didn't get a shipping code. But just to make sure I double checked my Email. It shipped...16 hours ago.
