Drivetrain Burger Motorsports (BMS) Tune(s)
Old Sep 20, 2013 | 06:20 AM
  #251
MINI4LYF's Avatar
MINI4LYF
You guys are making me jealous. Stop. :(
Old Sep 20, 2013 | 12:37 PM
  #252
bmx045's Avatar
bmx045
Old Sep 20, 2013 | 05:13 PM
  #253
6thGear's Avatar
6thGear
Old Sep 20, 2013 | 05:46 PM
  #254
cerenkov's Avatar
cerenkov
Hopefully the postman will be kind to me tomorrow, fingers crossed!
Old Sep 20, 2013 | 07:05 PM
  #255
Beowoulf's Avatar
Beowoulf
Sorry if that has been asked and answered already but will this be available for 2013 JCW cars?
Old Sep 20, 2013 | 07:08 PM
  #256
cerenkov's Avatar
cerenkov
No. Not for the JCW or GP's.
Old Sep 20, 2013 | 07:30 PM
  #257
Coop-a-Loop's Avatar
Coop-a-Loop
MCS JB+ vs. JCWkit vs. fJCW vs. GP side by side Top Gear style 'match' would be really cool.....come on Hollywood.
Old Sep 20, 2013 | 08:40 PM
  #258
gerry2153's Avatar
gerry2153
I'm not aware that has been said officially . . .
testing is limited to MCS at this point . . .
(but I could be wrong)
Old Sep 20, 2013 | 09:01 PM
  #259
cerenkov's Avatar
cerenkov
Originally Posted by gerry2153
I'm not aware that has been said officially . . . testing is limited to MCS at this point . . . (but I could be wrong)
Terry posted back on Sept 11 that it is for cars that make 12-13 psi boost, so JCWs and GPs are out for now. I would say that is official.
Old Sep 21, 2013 | 01:09 AM
  #260
dhfreak's Avatar
dhfreak
Originally Posted by bmx045
LMAO...Awesome!!!
Old Sep 21, 2013 | 01:22 AM
  #261
johntotah94's Avatar
johntotah94
Originally Posted by yesti
Now that the JB+ is in production I'll comment as well. Non sport mode feels like 'sleeper' in that you have more power throughout the entire rpm range but after 3.5k the engine growl is downright addictive. It is simply easier to drive the car under normal conditions.
Sport mode is insanely fun. It can now be called 'beast' mode due to the factory throttle remapping on top of the power gains.
Everything moves up 20mph meaning going 80 is as easy as going 60 used to be and 60 -> not legal passing is stupidly easy. Keep tabs on your speedo; its too easy to ride the rush. Stock brakes are not overwhelmed, which is good.
Even with gains across the board, the power has moved up the rpm range a little but not too far as to turn the engine into an on/off (honda) switch.
Boost goes from 14psi peak to 16psi. Run meth/E85 and you can turn the boost up to 18psi via the pot in the JB+.
I've noticed peak coolant temp is now 107 C on the JCW gauge versus 105 prior, which is a fair trade-off for the power gain. Change your engine/tranny oil frequently. Hopefully the JB4 will have an option to run the car at 90-95 C all the time like the '13 guys have with sport mode on (or fulltime in the JCW).
Get the CAN tool if you can afford it, the speedo is useless as a speedo but great for watching boost pressure. Fuel gauge is good for watching timing. Hopefully the IAT and throttle gauges will be added soon.
I did the 50 mile 'adjustment' period the day I got it, mostly city, and peak boost goes immediately from 14 to 16 psi with more midrange power gradually showing up as you drive. Someone else noted it took up to 100 miles to feel the full effect.
2012 hardtop S auto
How do you turn up the boost on the JB+?
Old Sep 21, 2013 | 04:23 AM
  #262
bmx045's Avatar
bmx045
open the box, there's a blue pot(potentiometer) dial that you can rotate to different numbered levels.
Old Sep 21, 2013 | 05:56 AM
  #263
pidge1114's Avatar
pidge1114
Old Sep 21, 2013 | 09:05 AM
  #264
Terry @ BMS's Avatar
Terry @ BMS
The adjustment dial should generally not be changed. In some cases if cars on 91 octane pick up knock code we'll have you reduce it. If using methanol you could raise it a bit. For those on 93 octane I'd leave it as is unless you are skilled a monitoring boost, knock, afr, etc.
Old Sep 21, 2013 | 10:54 AM
  #265
johntotah94
Just got mine in the mail this second
Old Sep 21, 2013 | 10:59 AM
  #266
cerenkov's Avatar
cerenkov
I left the house for less than one hour and the postman came and left a note...now I have to wait until Monday, oh well.
Old Sep 21, 2013 | 11:24 AM
  #267
pepperwhiteknight's Avatar
pepperwhiteknight
I got one of those notes too but I got in my car and drove around the neighborhood. I got it now. Do I just plug the JB+ in with the car off or do I need to disconnect the battery first?
Old Sep 21, 2013 | 11:32 AM
  #268
cerenkov's Avatar
cerenkov
Ha ha, I drove around too, found a different postman and called the post office, they confirmed my carrier had already finished so I have to wait since the office closed at noon.
Yes plug it in when the car is OFF. Basically you pop and open the hood, close and lock the doors wait 5 min or so for the car to enter sleep mode then install it, Terry does describes the procedure a few posts up.
Old Sep 21, 2013 | 07:53 PM
  #269
MotorMouth's Avatar
MotorMouth
It certainly added more power when you step on it but still tame for normal driving.
I like it. For ~$300 it's worth it.
Old Sep 21, 2013 | 08:41 PM
  #270
GP0256's Avatar
GP0256
Ugh, mine came today and we were home and the post office decided not to drive up my 315' driveway and lazily put the notice that it was not delivered in my mailbox! How awesome! The suspense is killing me!
Old Sep 21, 2013 | 09:20 PM
  #271
johntotah94
Still in adaption process but it gained some power. Hoping I will get more power each day. But certainly hope they make a JB4 so we can get even more power. Jealous of the 3 series with JB4. Looks so damn fast on YouTube.
Old Sep 21, 2013 | 09:34 PM
  #272
wzabrouski's Avatar
wzabrouski
Give it 100 miles.
Old Sep 21, 2013 | 11:21 PM
  #273
johntotah94
Does anyone know exactly what the JB+ does inside? Does it convert a number into a higher number or something since it works only off the MAF sensor?
Old Sep 22, 2013 | 07:41 AM
  #274
bmx045's Avatar
bmx045
If you know what an Arduino is, this is somewhat similar.
Old Sep 22, 2013 | 07:56 AM
  #275
cerenkov's Avatar
cerenkov
I don't think he was asking what it is physically, but what parameter does alter and then pass to the ECU.
But this information is intellectual property so Terry might be a little evasive in answering this question. I'm interested also at least from a big picture point of view.
