Drivetrain shifter play
Old Feb 27, 2013 | 11:04 PM
chicolean83's Avatar
chicolean83
shifter play
I would like to know if a short shifter kit, such as the one by craven speed would alleviate excessive side play?
I was thinking about this option since i know the car has 150k mileage
http://www.ecstuning.com/Mini-2004-C...ifter/ES47324/
Old Mar 4, 2013 | 01:33 PM
Did you check the OEM base unit for play at the snap in point first?
Old Mar 4, 2013 | 01:56 PM
leaf_fan_1988's Avatar
leaf_fan_1988
What to you mean excessive side play?
Like when it's in third gear, you can move it side to side as if it were in neutral (except not as much as in neutral).
Old Mar 4, 2013 | 02:16 PM
00zero's Avatar
00zero
i had the problem when i installed a taller shift ****.
it was the selector brushing on right side of the housing (visible when you remove the boot).
A short shifter only effects the forward backward shortness.
As far as i know they do not sell a replacement brushing (mine is older and has a plastic brushing in a metal arm) I made a new one out of a brass brushing.
-Jonathan
Old Mar 4, 2013 | 02:18 PM
chicolean83
@ ECS no i have not checked that i just feel excessive play when i have it in gear and move it left and right. @ Leaf 88 exactly! I drove a friends 06 mcs and it had a much tighter feel
Old Mar 4, 2013 | 02:25 PM
There is a nylon white collar that snaps in over the pivot ball, it can show play in that area, which is in all in one unit with the base that comes pre-greased. There are two bases.
Condition A and Condition B
You have a picture of the item from the condition B on our site. Just make sure you have the right one.
Old Mar 4, 2013 | 03:56 PM
chicolean83
Thanks a lot. I will check when I do my clutch an LSD install in about a month, as that's when I plan on changing the Shifter unit.
Good$$Mendez
Old Mar 4, 2013 | 04:06 PM
Melangell's Avatar
Melangell
chicolean83, which LSD? I'm going to have the Quaife LSD installed on the 15th. As short shifters go, I don't think that it will solve your problem but I am seriously digging (loving for the youngsters) the Helix.
Old Mar 4, 2013 | 08:00 PM
chicolean83
Whaz up Melangell. Iam going to have the same installed next month. What clutch do you have in your car? I was thinking about act clutch and flywheel. Iam getting everything installed at Helix in Philly!
Good$$Mendez
Old Mar 5, 2013 | 08:07 PM
Melangell's Avatar
Melangell
Yo! I have the OEM clutch and will have one installed along with the LSD. Way of Way Motor Works (who is doing the work) says that it is the most reliable so.... I am going to pick up a set of Koni Sports and spacers and hopefully.... this will be it for mods for awhile!
Old Mar 5, 2013 | 08:27 PM
chicolean83
That's great! Way is a great guy. Ive bought a lot of stuff from him. Oem is always good for clutches, I just plan on doing a lot more power mods. Also had Act clutches in my past two vehicles, and they were great. Let me know how the LSD feels in the corners!
Good$$Mendez
Old Mar 5, 2013 | 08:31 PM
Melangell's Avatar
Melangell
And off the line! After the tune, I have a hard time not spinning (a) tire!
IQRaceworks
53
Jun 28, 2024 07:29 AM
RobbyD
Jan 29, 2019 01:22 PM
02miniSguy
Nov 17, 2015 10:29 PM
vetsvette
Oct 1, 2015 12:59 PM
MINI Stupor
Oct 1, 2015 11:36 AM
