Drivetrain Shredded another serpentine belt! Help
Old Mar 7, 2013 | 04:35 AM
03miniS's Avatar
03miniS
Hey guys i have done some searching on here I have not found quite what im looking for. I have a 2003 mini s r53. This is the 3rd time I have shredded a belt I replaced 2 tensioner within 5000 and belts. I have a reductioner supercharger pulley I do not know what size. This morning the belt shredded again . It seems to happen in higher rpms. Whats causing this any help would be great. Also if anyone has an outside dimensions of pulley sizes that would be great so I know what I have.
Old Mar 7, 2013 | 04:37 AM
JAB 67's Avatar
JAB 67
Your pulley is probably not properly mounted.
Old Mar 7, 2013 | 04:46 AM
03miniS's Avatar
03miniS
The pulley seems to be spin straight and inline with everything else. Also what size belt for reduction pulley I broke down on my way to work I want to be able to grab another belt I forgot the sizes.
Old Mar 7, 2013 | 05:41 AM
Braminator's Avatar
Braminator
Check the crank pulley and idler pulley all line up straight on the belt. Depending on your pulley(you don't what size) you can try a Gates K060539 if that is too big got to a K60535. How much tension has been on your previous belts? Sounds like a lot.
Old Mar 7, 2013 | 05:49 AM
03miniS's Avatar
03miniS
Im not sure of the tension I will buy both belts and see what works.
Old Mar 7, 2013 | 05:57 AM
Braminator's Avatar
Braminator
Take a picture of your SC pulley and post it as we might be able to help you identify it.
Old Mar 7, 2013 | 06:03 AM
Helix13mini's Avatar
Helix13mini
This. The most common reason for belts to fail is that they are too big. This is especially true for high-RPM failures. Check that all your pulleys spin freely and get the right belt (squeeze a 535 on there).
Old Mar 7, 2013 | 07:16 AM
03miniS's Avatar
03miniS
Ok well I just picked up a 535 belt , unfortunatly the tensioner is toast. Ill be ordering a new one along with tensioner stop.
Old Mar 7, 2013 | 07:19 AM
Braminator's Avatar
Braminator
So this will be your third tensioner? WTF
03miniS's Avatar
03miniS
Picture of pulley sorry its difficult to see
Old Mar 7, 2013 | 07:31 AM
03miniS's Avatar
03miniS
3rd tensioner yes. :/.
Old Mar 8, 2013 | 06:13 AM
bean's Avatar
bean
have you looked at your crank pulley/damper? you might have damaged it during an earlier belt failure. it might only have a burr that eventually cuts your new belt.
Old Mar 9, 2013 | 02:24 PM
Debi's Coop S's Avatar
Debi's Coop S
Without a picture of your pulley setup or some measurements of the pulley, we really can't do much to help you.
VanisleRyan
Sep 30, 2015 08:35 PM
eliseo1981
Sep 30, 2015 07:57 PM
fkrowland
Sep 30, 2015 10:30 AM
dragonby
Sep 25, 2015 08:10 PM
daviday
Sep 25, 2015 01:31 AM
