Drivetrain So the teardown begins
Old Jan 4, 2013 | 12:36 PM
  #51
Porthos's Avatar
Porthos
Originally Posted by laforze
You have a link to where i can pick up that mani?
No, I don't support that parts dealer anymore.
Old Jan 4, 2013 | 12:37 PM
  #52
Porthos's Avatar
Porthos
Originally Posted by MNIPWR
Could you measure the turbo inlet ports.
The topside of the manifold?
Old Jan 4, 2013 | 12:38 PM
  #53
calforhelp's Avatar
calforhelp
I think he got this one:
http://www.waymotorworks.com/turbo-e...5-r56-r57.html
Old Jan 4, 2013 | 12:50 PM
  #54
MNIPWR's Avatar
MNIPWR
The ports where the exhaust exits the manifold and enters the turbo.
Old Jan 4, 2013 | 01:07 PM
  #55
ThePenl's Avatar
ThePenl
Is there a link to the shield you speak of?
... from memory, I think you got the exhaust manifold from Way didn't you?
Old Jan 4, 2013 | 01:14 PM
  #56
ThePenl's Avatar
ThePenl
Originally Posted by Phobix
See, my JCW already had the newer type on it. Thats actually the EU type of manifold. It gives noticeable gains if you are moving over from the US version.
This exhaust manifold is the OEM fJCW part and everyone can find it in a local dealer...!!!
Noticeable gains??? what do you mean? How did you find that it gives noticeable gains? What tests did you do?
Old Jan 4, 2013 | 01:42 PM
  #57
Porthos's Avatar
Porthos
Hey this isn't a pissing contest thread of it works or not.
Old Jan 4, 2013 | 01:56 PM
  #58
ThePenl's Avatar
ThePenl
As I have tried all the available exhaust manifolds from 2007 till today both S and fJCW, I think I have the right to ask a simple question here...
If you think I don't, then again it's OK with me...
Old Jan 4, 2013 | 02:53 PM
  #59
MNIPWR's Avatar
MNIPWR
Mesure the ports
Old Jan 4, 2013 | 03:15 PM
  #60
Phobix's Avatar
Phobix
Why do you think its a JCW part? Because it gives gains.
I know because a buddy of mine has an '09 JCW and had the older fat version. We put this part in and the butt dyno could definitely tell a difference.
Old Jan 4, 2013 | 03:23 PM
  #61
ThePenl's Avatar
ThePenl
Hmm...ok then.
Old Jan 4, 2013 | 06:02 PM
  #62
Porthos's Avatar
Porthos
I am not worried about asking a question. I just don't want you guys arguing about stuff that isn't really that big of a deal.
Old Jan 4, 2013 | 06:08 PM
  #63
Porthos's Avatar
Porthos
Mesure the ports
They looked exactly the same size. The runners are smoother and a little bit longer though.
Old Jan 4, 2013 | 08:30 PM
  #64
Porthos's Avatar
Porthos
Old Jan 4, 2013 | 11:35 PM
  #65
NewCooperFanatic's Avatar
NewCooperFanatic
Almost pulled the trigger on one of those manifolds.....just can't warrant completely tearing down the front end just for that part unless it makes a huge difference...which I have no idea if it does or not.
At least in this case it works out for you since the turbo HAD to be removed.
Thanks for all the photos
Old Jan 4, 2013 | 11:38 PM
  #66
NewCooperFanatic
Double post
Old Jan 4, 2013 | 11:46 PM
  #67
Porthos's Avatar
Porthos
It really is an easy install it is just time consuming. Stop being a pansy go for it.
Old Jan 5, 2013 | 01:59 PM
  #68
Porthos's Avatar
Porthos
There are no updates today, I am going to be working on my buddy's Mark iii Supra.
Old Jan 6, 2013 | 10:10 AM
  #69
Phobix's Avatar
Phobix
Agreed. I did it with having absolutely ZERO experience working on cars. I have done it twice now. Just take your time, label all of your parts in plastic baggies, and take pictures if you need to. A Bentley manual helps as well. And it DEFINITELY makes a difference.
Old Jan 6, 2013 | 10:14 AM
  #70
Phobix's Avatar
Phobix
Porthos, an easier way to have gotten the new mani back in would be to attach the turbo prior to putting it in so that you can easily get the torque right. This is why service mode is so useful. My turbo/mani went in all as one piece. All of the studs are still accessible so there really isnt much of a reason NOT to do it this way. Also, make sure you remember to use thread locker on the mani/turbo bolts. I forgot and had 3 of the bolts back themselves off causing a massive exhaust leak. It wasnt pretty
Old Jan 6, 2013 | 11:29 AM
  #71
Porthos's Avatar
Porthos
There in lies a problem, I don't have a turbo right now. Also I have crows feet so getting the turbo back on won't be a problem. Noted on the thread lock.
Old Jan 12, 2013 | 07:54 PM
  #72
Porthos's Avatar
Porthos
Well halfway done with the HFS4 install. The turbo will come in next Thursday for a Friday install and hopefully a Saturday tune. Wiring is a little crazy so I had my wiring guru friend come over and do it up for me. All in all it was a short day same with tomorrow.
Here is a picture of my Braille battery if anyone is interested in what it looks like installed.
Old Jan 12, 2013 | 08:08 PM
  #73
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
How did your intake valves look when you had the manifold off?
The meth will keep them nice and clean if they where already, but it wont remove a whole bunch of built up carbon.
Old Jan 12, 2013 | 08:09 PM
  #74
Melangell's Avatar
Melangell
Wha?
Old Jan 12, 2013 | 08:15 PM
  #75
Porthos's Avatar
Porthos
I didn't take the intake manifold off. I took the exhaust manifold off and replaced it.
I had the valves cleaned about 1000 miles ago.
