I think so but when I touched it some of it cam off on my finger, though it still was on the turbo also.
One of the issues I was having after firing the car back up was that a bunch of codes got thrown. I think most of it was the fact that it had been sitting so it needed to relearn everything. Also it threw a vacuum leak code which I narrowed down to the PCV hose from the valve cover to the intake manifold. The thing was completely busted up. So instead of going stock replacement I cut the rest of the hose off all the way to the connectors and went and bought rubber hose to fit over the connectors, then put some clamps on it, and reinstalled. My problem with that on was fixed but, I still had a cel with no code. After driving it for a little bit I found that the water/meth kit has to be all the time right now until I get a tune to run with and without.
You can change that in the settings of the kit. I have mine so i can turn it on and off. Mainly for long trips at night.
I am getting the car tuned by RMW on Feb 4th I can't wait.
is RMW located in laguna hills now? or is jan able to tune from just about anywhere? i live about 20 mins away from laguna hills and would love to swing by to check out your car and see jan at work, if it's not too intrusive of course. please let me know! thanks!
The shop that he works out of when he is at home is in Laguna Hills.
If you don't mind me asking, Porthos, what method (phone, e-mail) did you use to get ahold of Jan? I haven't had a ton of success getting ahold of him in the past. (I know he had some family stuff come up, so that no doubt had something to do with it.)
I see you have the HFS 4. I have the three so it might be a bit different. But I have the Failsafe off. I think thats it, and possibly the boost cut with no CEL switched.
