Drivetrain DIY Engine Cleaning (Intake Valves)
Old Mar 10, 2019 | 03:36 PM
  #176
Redhotz's Avatar
Redhotz
Same thing with me. It would crank, but not start. I had it towed to a shop. They said the engine/plugs were flooded. Changed the plugs and okay. I would take the plugs out for a while and let it dry out.
Old Aug 17, 2020 | 01:31 PM
  #177
Victor Gonzalez Rodriguez's Avatar
Tools bought
Originally Posted by NY_R56
Here's a update.
My tools just came in this morning. The BMW sprayer wand thing didn't work with my sandblasting nozzle. LOL
Attachment 66686
So I made my own. A valve and a couple of fittings I got from my local hardware store.
Cost = $6
Attachment 66687
Attachment 66688
As for the air compressor I used. It is a dinky little 4 gallon bositich compressor since my 20 gal air compressor and good shop vac are shot. Dam hurricane sandy flooded my uncle's basement along with a couple other tools he borrowed.
Attachment 66689
The media I used is fine crushed walnuts. 24 grit
Attachment 66690
I'm happy to say it went quicker than I thought Actually a lot quicker than I thought. To decently clean all 4 intake valves took me about 15 minutes.
About a minute to clean one cylinder pretty good and prolly a minute for my air compressor to charge/catch up. My little compressor came on 4 times so a 20 gallon tank would be easily capable of carbon blasting a Mini.
Before:
Attachment 66691
After:
Attachment 66692
As for the amount of walnut media used to clean the intake valves. About 5 pounds.
This is how much that was in my vacuum after the valves were clean. And to me the media still looks pretty clean so I can still reuse it for something else.
Attachment 66693
After I put my Mini back together. I did a test run. I can definitely feel the difference. I have the AP running stage 3 and usually in sport mode always I hit boost cut for some reason but, couldn't figure why it did that. Now no more boost cuts in sport mode.
All in all it took less than a hour to completely carbon blast my Mini. Now I'm going to stop wasting my money buying seafoam and deep creep for my Mini. Instead, since I have to BMW tools to carbon clean. Next time I do it should cost less than five bucks.
Now for the money I saved not going to the dealer is going towards a new air compressor since the old one shot. Debating if I should go for a nice 30gal portable belt driven or 60 gal belt driven stationary($50 difference)
Hey so hoping that you see this, what exactly did you buy to adapt the Mini walnut attachment to your sandblasted?
Old Feb 10, 2022 | 10:02 AM
  #178
DefoMini08's Avatar
DefoMini08
I saw it mentioned that the tubing needs to be .20 ID
I find .25 aluminum tubing online with a .034 which gives me a .18 ID Is this too small?
Did the tubing that you used off the Harbor Freight nozzle work fine?
Old Feb 10, 2022 | 10:49 AM
  #179
sani's Avatar
sani
It should be fine. If the ID is too big the walnut velocity is decreased and not as effective at cleaning.
sani
Old May 14, 2023 | 06:33 AM
  #180
U.S.A. Ranger's Avatar
U.S.A. Ranger
Adapter
This post is for PHXSTEELE. It's only been 10 years since your post so I hope you're still on this forum.
Your post has a bunch of pictures showing part numbers and how to make a blaster. I need one more piece of information. The last pic shows the "Finished" gun with the media pickup. Can you give me a part number and/or where to get this piece?
If anyone else knows where to get this, please chime in.
Old May 14, 2023 | 11:20 AM
  #181
phxsteele's Avatar
phxsteele
Yep still here. Are you referring to the "gun'. Not sure if the part number but I picked it up at harbor freight I believe.
Old May 14, 2023 | 11:55 AM
  #182
U.S.A. Ranger
I'm looking at the Part between the gun and the brass fittings. This is where you attach the tubing for the walnut pickup.
Old May 15, 2023 | 05:00 PM
  #183
geofox784's Avatar
geofox784
That part should come with the gun..tb_button {padding:1px;cursor:pointer;border-right: 1px solid #8b8b8b;border-left: 1px solid #FFF;border-bottom: 1px solid #fff;}.tb_button.hover {borer:2px outset #def; background-color: #f8f8f8 !important;}.ws_toolbar {z-index:100000} .ws_toolbar .ws_tb_btn {cursor:pointer;border:1px solid #555;padding:3px} .tb_highlight{background-color:yellow} .tb_hide {visibility:hidden} .ws_toolbar img {padding:2px;margin:0px}
Old May 18, 2023 | 07:18 AM
  #184
FrankMstein's Avatar
FrankMstein
It does not. None of them come with the gun. I had to go to lowes to "engineer" a fitting situation. It worked and I can post a pic of the setup later.
>>>This is the fitting that is needed: https://www.bimmerhelp.info/product-...-brass-fitting <<<
This is the tube I got but it will need to be bent to a 90deg: https://www.fcpeuro.com/products/bmw...-euro-b1100003
Old May 18, 2023 | 07:23 AM
  #185
FrankMstein
I highly recommend doing this process. Mine had 96k miles and it feels like a new car or I had just tuned it! Major difference. I can now bark the front tire from 1-2 gear change! If you have the time like 12-14 hours (depending on the thickness of deposits) you can use seafoam or "degreaser" or fuel = whatever else you choose to soak each of the valves in for hours while scraping and blowing out the residue. Luckily you can do 1-4 and 2-3 in sets.
Old May 18, 2023 | 09:51 AM
  #186
Lex2008's Avatar
Lex2008
96k!!! I put a new motor in my R56 and the valves looked horrible within 20k miles.
I usually take an entre day to do it too...soak, pick, soak pick, walnut blast...takes forever.
Old May 19, 2023 | 05:54 AM
  #187
FrankMstein
YEAH IT DOES and my back PAYS for it!
Old May 19, 2023 | 08:25 AM
  #188
Lex2008's Avatar
Lex2008
oh yes its an uncomfrtable position to be in. Im thinking of buying one of these, since I have 3 cars with direct injection could be worth it if it saves me hours and hours.
https://www.amazon.com/gp/product/B07N2LKH6Y/ref=ox_sc_saved_image_1?smid=A3W34R82EI8DS3&psc=1 https://www.amazon.com/gp/product/B07N2LKH6Y/ref=ox_sc_saved_image_1?smid=A3W34R82EI8DS3&psc=1
Old May 19, 2023 | 10:53 AM
  #189
FrankMstein
https://www.amazon.com/gp/product/B0...82EI8DS3&psc=1
I saw that and thought I can get a super compressor AND the sprayer for that price! I installed a catch can on the vacuum side. Pressure side was dry and clean. My wife can't stop driving it like a grandma.
Old May 19, 2023 | 11:04 AM
  #190
Lex2008's Avatar
Lex2008
ya I have a super compressor and a sprayer and honestly it only works so so and walnut sells end up all over.
ya my girl drivers like a grandma too.
Old Feb 27, 2025 | 05:11 PM
  #191
pkgmSu2000's Avatar
pkgmSu2000
Here's a update.
Attachment 66686
Cost = $6
Attachment 66687
Attachment 66688
Attachment 66689
Attachment 66690
Before:
Attachment 66691
After:
Attachment 66692
Attachment 66693
amen!
Old Feb 28, 2025 | 03:24 AM
  #192
Lex2008's Avatar
Lex2008
Looks awesome! I never had that much success with my cheapo harbor height blaster kit and an 80 gallon compressor
geofox784
How to
Mar 11, 2024 05:14 PM
Biggus
Mar 21, 2023 11:09 AM
Coz3z3
Oct 26, 2021 06:48 AM
chav
Dec 6, 2016 07:34 PM
bit_bucket
Aug 15, 2014 08:37 AM
