Drivetrain im new here need some info please
Old Mar 15, 2012 | 04:41 PM
inkspot1967's Avatar
inkspot1967
ok call me dumb but i really want to know if my mini cooper s is turbo or supercharged? its a 2008 convertible how do i know if its turbo or Sc?
thx and sorry for the dumb question
also what mods are best to start with like a Cai, exhaust, suspension....?
also has anyone installed a double din nav system in theres?
and what is mine a r52 or r53 or??? kinda confusing
Old Mar 15, 2012 | 05:12 PM
killerfox's Avatar
killerfox
If you open the bonet(hood), and you see a big radiator sitting on top of the motor, then it is supercharged.
Old Mar 15, 2012 | 05:35 PM
inkspot1967
Ok thx heres what mine looks like.
Should i put a cai on it?
Any others mods to get more hp out it
Old Mar 15, 2012 | 05:48 PM
killerfox's Avatar
killerfox
yep, you have a supercharger.
There are a great amount of mods that can be done depending on how much money you want to spend. You could change your pull to increase boost, get larger injectors, big valve head, bigger supercharger, Meth injection kit, or even a full out stroker motor, coilovers, sway bar, better brakes
Some of those upgrades need a new ecu tune.
Check out this forum for some great ideas
http://revolutionmotorworks.com/forum/index.php
Old Mar 15, 2012 | 06:02 PM
inkspot1967
Thx i dont want to get really crazy just some of the bolt on types that i can benefit with getting a little bit more HP.
Things like these that will fit and where to get them
CAI
Exhaust
Any other suggestions
How to install a double din Nav/dvd in it. This i want the most to work out.
What is mine also a r52 or r53....?
Old Mar 15, 2012 | 06:16 PM
killerfox's Avatar
killerfox
i would just install a 17% pull upgrade and intake and exhaust.
Contact Eric at www.helix13.com or Way at www.waymotorworks.com
They are both very respected vendors and carry all the parts you could want.
Old Mar 15, 2012 | 07:20 PM
Fly'n Brick's Avatar
Fly'n Brick
You have an R52. The R57 came out in '09. One big easily identifiable change is the lower sitting automatically extended roll bars. Another gimmick is the "Open-ometer" that is supposed to tell R57 folk if they've been driving with their tops down. I've discovered that by looking up once in a while, I can actually tell for myself.
Welcome to the topless motoring club.
If you haven't already I would strongly suggest acquiring a wind deflector. You will be extremely glad you did. You can find them used on ebay at a pretty good price once in a while. OEM is pretty darn expensive. Just make sure it's for a R52 because the one for the R57 won't fit.
Old Mar 16, 2012 | 10:35 AM
astroBlackMetallic_Mini's Avatar
theres no way you can have an '08... they switched to turbos in '07 didnt they?... or is it different for the carbrios?
Old Mar 16, 2012 | 10:40 AM
killerfox's Avatar
killerfox
they did not do turbo for the cabrio that year.
Old Mar 16, 2012 | 01:14 PM
Fly'n Brick
This should settle the question.
http://new.minimania.com/web/Display...n/ArticleV.cfm
Old Mar 16, 2012 | 01:39 PM
inkspot1967
Thx guys I just gotta figure out what exhaust and cai to get now
Old Mar 16, 2012 | 02:00 PM
IMO, the "best" way to do a CAI is to:
1. get a decent intake hose (Samco / Alta )(Samco's will be cheaper, and are the same as the altas i think)
2. Leave the Stock Airbox, and get an Amsoil Nano-Filter (or similar high flow filter)
3. If you dont mind some "hands on", cut a larger hole in the back of your stock airbox to emulate the JCW box.
Because, what is really the sense in spending another 100$ on what is basically another plastic box? or even worse, Metal?!
As for exhaust,
I have a JCW car, but others seem to like the "one ball" mod, where you basically "chop" off the other side of your exhaust system.
Also, yes, get a Pulley upgrade! %17 is a lot, it may give you issues... %15 is considered "safe" i think, few issues ive seen reported on that reduction.
PS: if you do a pulley, its a "good idea" to do plugs, wires, coil pack... youll need the extra "juice" to burn off the extra fuel / air your pumping into the engine with the pulley upgrade
Alpha Motoring
Sep 7, 2020 07:34 PM
RobbyD
Jan 29, 2019 01:22 PM
vulkandino
Oct 31, 2015 08:29 PM
BackcountrySkier13_inAZ
Oct 14, 2015 06:00 PM
jumbojimbo
Sep 24, 2015 08:16 AM
