Drivetrain Twincharged MCS
Old Oct 18, 2004 | 06:15 AM
  #251
greatgro's Avatar
greatgro
Originally Posted by WildcatKC
For $5-6k that's a killer deal. I've just created this account but I've been following this thread since the beginning. If you think about it for just a little bit more then the JCW kit and have this incredible HP/TQ curve.
A little more? THe JCW kit IS $5500-6000 depending on the dealer.
Old Oct 18, 2004 | 07:09 AM
  #252
minimc's Avatar
minimc
Originally Posted by jlm
those ss lines are oil to the turbo bearings
You sure about that J?
We're not talking about the SS line that loops in a coil (against the firewall) in 'stills' near the start of this thread. We're looking at the now relocated OE coolant tank. In the video its got SS hose attached.
Old Oct 18, 2004 | 07:19 AM
  #253
USAMINICOOPER's Avatar
USAMINICOOPER
jlm:those ss lines are oil to the turbo bearings
Jlm: That connection to the coolant tank, can you explain how it is oil to the turbo bearingsthat needs this connection. I'm not that sure.
Old Oct 18, 2004 | 10:20 AM
  #254
jlm's Avatar
jlm
sounds like I'm wrong. I wasn't aware of any coolant tank changes.
Old Oct 18, 2004 | 10:30 AM
  #255
Pocket_Rocket's Avatar
Pocket_Rocket
Fix no.. help yes.. and if it is too bad then I personally will just add a dual stage boost controller.
Originally Posted by mlebeau
I don't think an LSD is going to fix the wheelslip on a FWD 2700 lb car with 265whp.
-mike
Old Oct 18, 2004 | 12:11 PM
  #256
USAMINICOOPER
Thanks Jlm.
Does anyone know or have an idea why there is a tube coming from the coolant tank.
Did anyone notice a connection to the coolant tank (stainless tubing)? Maybe we have little help to keep the heat from building up caused by the turbo..
Though that doesn't sound correct because the water in a Mini s is 190 degrees
Old Oct 18, 2004 | 12:34 PM
  #257
Bisch's Avatar
Bisch
Originally Posted by USAMINICOOPER
Thanks Jlm.
huh.
They all have that tube. SPI just used a braided tube as a replacement...probably just as a dress-up.
Old Oct 20, 2004 | 08:42 AM
  #258
ukbyoung's Avatar
ukbyoung
I know there is work on selling this "kit." Prices seem to be saying 5k to 10k. Just wondering how much fabrication is necessary to do this yourself????
I mean the garret t20 is 1500. There is also one on ebay for reg coopers selling total package for 2000.
link:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7927827039&fromMakeTra ck=true
Old Oct 20, 2004 | 09:08 AM
  #259
mlebeau's Avatar
mlebeau
This isn't using a T20, I believe it's using the Garrett GT28r.. Correct me if I'm wrong.
-mike
Old Oct 20, 2004 | 09:28 AM
  #260
El Diablito Rojo-N20Mini's Avatar
link:
here is a pic of it
[size=2]The main components of the kit include the following items:
Custom 8 gauge stainless steel tubular exhaust manifold and 3" downpipe. Garrett GT28R ball bearing turbo with custom actuator. Custom top mount intercooler and aluminum 2.5" turbo piping and intake system Custom 440cc injectors and APEXi S-AFC II Fuel Computer HKS SS Blow off Valve Power Steering/Coolant reservoir relocation kit All necessary lines, hardware, fittings, connectors, instructions
[/size]
Old Oct 20, 2004 | 10:33 AM
  #261
ukbyoung's Avatar
ukbyoung
-mike
yes, you are right, I meant that the t28 is only 1500. the one on ebay is the t20.
Old Oct 20, 2004 | 10:37 AM
  #262
Super_MINI's Avatar
Super_MINI
Actually a quick search on the Internet yeilded G28 turbos new for $899 from several different vendors.
Old Oct 20, 2004 | 03:37 PM
  #263
ukbyoung's Avatar
ukbyoung
do ya ever get the feeling the whole world is out to getcha? :smile:
yes, I was thinking of the t30 (1300) b/c that is what I originally planned on putting in another car and am planning on putting in the mini
Old Oct 20, 2004 | 06:10 PM
  #264
how long have you lived in Lincoln? I have family in Lincoln and surrounding areas.... in fact... I grew up in Auburn, NE
Old Oct 20, 2004 | 06:55 PM
  #265
Mark@Helix's Avatar
Mark@Helix
Helix/Psi-Fi TurboKompressor(twincharged)kit preliminary specs...
We are really making headway with the kit and are a go for production(all jigs etc are done and ready to go) here are some preliminary specs of the kit:
-Garrett GT28rs disco potato turbo 360hp potential
-cast exhaust manifold w / 5 year warranty
-Helix increased diameter pulley to lower S/C boost and parasitic drag and increase turbo charger boost.
-stainless steel 2.5 inch downpipe with integral 300 cell metal matrix cat.** this DP can be flanged at a full 2.5 inch or tapered to 2.25 to match the factory exhaust.
-custom silicone charge pipe
-cowl induction cold air intake system
-Turbosmart eboost boost contoller/boost gauge and pod
-Turbosmart BOV
-Psi-Fi Powerpaq engine management (fuel/timing/aquamist controller) w/ street and race maps
-500 cc direct drop in injectors
-Porsche quality fastening hardware
-all lines and fittings
-Aquamist water/alcohol injection ***Optional(lowers charge air temps approx 30 degrees F and allows 2 more psi boost on pump gas)***
-2.5 inch high flow exhaust system ***optional in testing, will have before and after dyno data vs stock exhaust***
-Depends diaper for the initial test drive
we will have both dyno and track #'s up very soon...Keep your eyes peeled for pics of the installed kit in the next few days
Any interest please contact Eric at Helix as he will be handling all orders and installs.
Old Oct 20, 2004 | 07:05 PM
  #266
MImcs's Avatar
MImcs
Sounds very tempting....any preliminary specs on price? Thanks!
Old Oct 20, 2004 | 07:06 PM
  #267
how about a price????
Old Oct 20, 2004 | 07:07 PM
  #268
Mark@Helix's Avatar
Mark@Helix
Erics setting pricing but I believe he was striving to be competitive w the JCW.
Old Oct 20, 2004 | 07:10 PM
  #269
how much boost are you running to get 360hp? and is that at the wheels
Old Oct 20, 2004 | 07:13 PM
  #270
Mark@Helix's Avatar
Mark@Helix
NOOO not at 360 hp that is the turbo's output potential.
Old Oct 20, 2004 | 07:35 PM
  #271
TheBlackBrian's Avatar
TheBlackBrian
Ooooooo! This is good. The two companies will hopefully put pressure on each other to better there product! WINK WINK!
Old Oct 20, 2004 | 07:45 PM
  #272
Mark@Helix's Avatar
Mark@Helix
and we're both in New Joisey this could be fun ...Competition brings out the best
Old Oct 21, 2004 | 05:45 AM
  #273
Redleg13's Avatar
Redleg13
A really dumb question...
is this sytem designed to replace the supercharger or augment it, i.e. I've heard of cars with turbos and cars with SC's but not both
Old Oct 21, 2004 | 05:54 AM
  #274
05JCWS's Avatar
05JCWS
Redleg,
This is both.
Old Oct 21, 2004 | 06:20 AM
  #275
Super_MINI's Avatar
Super_MINI
So we are going to have two different companies offering "Twincharged" systems? SPI and Psi-Fi/Helix? That would be good news for us buyers anyway....
