Drivetrain Service Engine light after Detroit Tuned BPV
Old Jul 20, 2011 | 02:26 PM
stt816's Avatar
stt816
just installed the detroit tuned bpv. Service Engine Soon light came on...what can it be? i started the car a couple times and did a ecu reset 3 times, still wont go away.
Old Jul 20, 2011 | 03:16 PM
HRM's Avatar
HRM
Reading the code is of course the easiest way to narrow it down, but, my first guess is something is unplugged or disconnected. You need to go in and double check every hose and plug near where you are. Make sure there are no air leaks either.
Old Jul 20, 2011 | 06:57 PM
stt816's Avatar
stt816
read post below...
Old Jul 21, 2011 | 05:42 AM
soccerbummer1104's Avatar
soccerbummer1104
hop down to advance and have them read the code and post it up here.
Old Jul 21, 2011 | 09:31 AM
stt816's Avatar
stt816
When I first installed it, the car felt so much better driving it compared to stock, yoyo was gone, but the check engine light was on. I wanted to get rid of the check engine light so i went back, took everything apart again and made sure everything was tightened and connected. Sure enough everything was. This time the car barely started and stumbled. It was the intake tube to the bypass that was cracked, so i went to autozone and got a new tube, cut it to the length and the car started and idled fine. But now I have a check engine light still AND it feels like the car has no boost. It makes a lot of noise when i hit the gas but feels like the stock bypass valve again with the yoyo problem. Please let me know what you think this can be asap. Thanks!
Old Jul 29, 2011 | 03:28 PM
stt816's Avatar
stt816
Anyone?
Old Jul 30, 2011 | 02:25 AM
BlwnAway's Avatar
BlwnAway
Honestly without knowing the code it's hard to narrow down anything. If you bought the valve from Chad give him a call.
Old Jul 30, 2011 | 08:28 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
Sounds like a vacuum leak. If you need help call my cell...586.484.1158 but reading the code is the first step.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Jul 30, 2011 | 10:22 AM
stt816's Avatar
stt816
where would the leak be coming from? I'll bring it to MINI if I can't figure it out, but I rather try and fix it and save some money.
Old Jul 30, 2011 | 10:31 AM
stt816's Avatar
stt816
Old Aug 1, 2011 | 10:23 AM
stt816's Avatar
stt816
i got code P0122 (Throttle Position Sensor Low Voltage) I called Chad and he said to clean the connector to the throttle body, but that didn't work, any suggestions? It also sounds like a lot of hissing is coming from that area also, I don't know if it's normal and i never noticed it or what. Please help
Old Aug 2, 2011 | 03:31 PM
stt816's Avatar
stt816
FOUND THE PROBLEM! a hose is disconnected and you could hear the air sucking in from it! problem is, where does this hose go? its the only grayish hose i see, its the one sticking up in the picture...how can i fix this? thanks!
Attached Thumbnails Service Engine light after Detroit Tuned BPV-img-20110802-00003.jpg
Old Aug 3, 2011 | 08:37 AM
Eggburp's Avatar
Eggburp
Thinking of installing a DT BPV.
Sorry not to help your situation but am interested in your fix.
DT's support and your overall opinion of the BPV.
Cheers and good luck.
Old Aug 3, 2011 | 10:47 AM
mmaigret's Avatar
mmaigret
I'm almost positive that is the vacuum hose that is attached to the MAP sensor by the thermostat. The MAP sensor effectively samples the air coming out of the supercharger via that tube.
It's strange that it somehow pulled out of its bracket, but the other end of that hose does connect to the tube that runs between the supercharger and bypass valve...
-Mike
Old Aug 5, 2011 | 07:46 PM
Detroit Tuned
Vendor - 15 Years
it didn't pull out, it actually broke off. more than likely he is going to need a new one. that is the first time that i have ever seen that. i would say it was cracked before hand, but that is just a guess. once that is take care off it should be up and running no problem.
Old Aug 6, 2011 | 08:41 AM
batrugger's Avatar
batrugger
Yeah I broke that same tube when I pulled all of my engine parts for polishing. It is part number 11651504943. Luckily it is not too much to replace and an easy job. #20 at the link:
http://realoem.com/bmw/showparts.do?...35&hg=17&fg=05
Old Aug 6, 2011 | 09:00 AM
u68423's Avatar
u68423
That's the best idea
09R56
Nov 16, 2022 10:49 AM
Teh
Aug 22, 2022 04:37 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
