Drivetrain Question, turbo heat shield
Old May 28, 2011 | 06:46 AM
6speedwtneed's Avatar
6speedwtneed
I was looking into getting the m7 turbo heat shield and was curious if anyone knew if it was a plus or a minus on helping. I just wasn't sure if it was safe or not. It looks like it would obviously keep some of the heat away from the intake. But at the same time a turbo is precious and don't want to encase it with heat.
Old May 28, 2011 | 07:52 AM
sLy201's Avatar
sLy201
I do not have the M7 one but I just got the NM one and its hard to say but Ive notice that theres not a large amount of heat shooting up at you when you pop the bonnet after driving, and at the same time im not gunna touch the shield to see if its absorbing heat lmaoo but I think its doing its job and make the engine look overall neater cause the stock one is really ugly ... Hope this helps out a bit but i know someone will chime in with an M7 one and give you some advice
Old May 28, 2011 | 08:15 AM
Maugre's Avatar
Maugre
I have an NM heatshield and like it, although the bonnet still is warm to the touch after sitting a few minutes, I imagine the M7 may be the same although it has extra heat absorbing material. I think they all help no matter which one you choose.
On another note, I think Way Motor Works offers a blanket that covers the exhaust side of the turbo for a little less than the M7 shield, (not avail when I purchased my shield). The idea is, you want to keep the heat in the exhaust side, (they can get RED HOT). Gad, I think I'm talking myself into getting one to go along with my shield as well. Anyway, good luck.
Old May 28, 2011 | 10:35 AM
Ch28Kid's Avatar
Ch28Kid
http://www.ecstuning.com/Search/51482183986/ES2080964/
I think this is standard equipment on the new MCS. Cheaper than all the heat shield out there!
Old May 28, 2011 | 10:38 AM
MP1.6T's Avatar
MP1.6T
Why not just use the factory updated parts?
1. The small aluminum heat shield sold either by Way Motor Works or via the dealer. Helps protect hood scoop and to some extent seems to redirect some scoop air rearward. Cost is <$30.
2. The small clip-on oil line metal heat shield. Fitted to newer ones at the oil line bolt up point--covered in a prior Mini technical bulletin. Costs < #1 and should help avoid coking of the critical oil/ oil cooling line to the turbo bearing.
Neither would raise warranty issues like something encasing the turbo from above could in theory.
Search archives for part #'s or see if someone else posts; I don't have them handy.
Old May 29, 2011 | 01:07 PM
Carlisle's Avatar
Carlisle
I have the M7 aerogel turbo heat shield installed on my JCW and I love it. It's good value for your money... and it covers up that horrible mess of a "shield" (I use sarcastic quote marks) that comes with the car.
Best of luck!
Old May 29, 2011 | 06:42 PM
Dr.Fox's Avatar
Dr.Fox
I've got the NM shield, and I guess it does the trick...although it's hard to tell unless I took temperature readings. I think the main purpose of the design of the NM shield is that it serves as a secondary piece of metal fairly close to the turbo and stock heat shield which acts like a heatsink to dissipate the heat from the turbo. The M7 aerogel seems to work to absorb the heat.
Old May 30, 2011 | 09:31 AM
6speedwtneed
Thanks for all the input guys. I'll have to make a purchase later this week
Old Jun 1, 2011 | 09:54 AM
pheatton's Avatar
pheatton
Hmm my 2011 did not come with the part at ECS...
Old Jun 1, 2011 | 10:55 AM
bayareaspecialk's Avatar
bayareaspecialk
Nether did mine.
I'm on the hunt to resolve this issue as well. Currently I'm leaning on just slapping some reflective tape on the underside of the hood.
Old Jun 1, 2011 | 11:34 AM
highlander709's Avatar
highlander709
My 11 MCS doesn't have anything like the ECS part either. I am considering adding one. The top of my hood (bonnet for those insisting on British terms when referring to a quasi British car) gets pretty hot so a heat shield just might be the ticket.
Old Jun 1, 2011 | 03:21 PM
Melangell's Avatar
Melangell
NM just released their titanium heat shield for the 2011. It fits like a dream and definitely keeps the scoop from really hot. Last week I drove 3 1/2 hours to see Way in Atlanta (80 mph+) and immediately after parking I could rest my hand on the scoop!
Old Jun 7, 2011 | 11:30 AM
cesar418's Avatar
cesar418
Can you post pics? I can't find pictures of the updated shield
Old Jun 7, 2011 | 11:35 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The 2011 version is just ever so slightly different. On the back side it is curves down less, and you'll see it doesn't have the cutout on the drivers side the the pre 2011 does. The studs that mount it are also different.
http://www.waymotorworks.com/nm-tita...011-newer.html
Old Jun 7, 2011 | 12:56 PM
Speedin Bob's Avatar
Speedin Bob
Way,
Didn't notice the hot side turbo heat shield/wrap you used to offer. Any reason why?
Bob
Old Jun 7, 2011 | 06:14 PM
Melangell's Avatar
Melangell
I picked up my 2011 MCS in December and it did not come with this shield. I do know that Way from WMW sells an equivalent for the same price and think that if anyone wants to go that way that they should buy from him because of all his support for the MINI community. I know of one MINI owner that did and reports a much cooler hood scoop. As I said above, with the more expensive 2011 NM shield, after a 3 1/2 hour interstate drive, my hood scoop was cool enough to rest my hand on.
Old Jun 7, 2011 | 06:48 PM
slimjimtell's Avatar
slimjimtell
Found this on a site..it would be about 200.00 but would actually USE the scoop to push air to the turbo. I would trust this before covering my Turbo.
http://www.minigenuineparts.co.uk/mi...lengeVent.html
Old Jun 7, 2011 | 07:17 PM
WayMotorWorks
Vendor
Originally Posted by Speedin Bob
Way,
Bob
We still offer it, and it does fit the 2011
http://www.waymotorworks.com/wmw-turbo-heat-shield.html
Old Jun 7, 2011 | 09:27 PM
dboard7's Avatar
dboard7
Has anyone used the VIP heat shield? It’s a lot cheaper than the rest. But its steal wouldn’t that hold heat? And what’s your opinion on the holes it’s the only one that’s has them.
Old Jun 9, 2011 | 09:16 AM
cesar418's Avatar
cesar418
does any of you with heatshields have had a problem with the oxygen sensor cable melting because of how hot it gets?
Old Jun 9, 2011 | 11:59 AM
Medevack1's Avatar
Medevack1
I made my own heat shield and works like a charm... it cost me $5.00 bux
Old Jun 9, 2011 | 02:41 PM
claud's Avatar
claud
NM makes another hood scoop heat shield that sticks to the underside of the hood near and covering the scoop under the hood. Its $84. It ain't as purdy as the Titanium one, but works for me.
Old Jun 9, 2011 | 08:58 PM
Ch28Kid's Avatar
Ch28Kid
No one in the states sell this part right? Any after market company sell this part?
Old Jun 10, 2011 | 12:41 AM
cesar418's Avatar
cesar418
you can have it shipped to the us
Old Jun 10, 2011 | 08:04 AM
Medevack1's Avatar
Medevack1
Be Creative and make your own a heat shield, There is no science to make one, with the proper material and determination you can make one and spend the other $200.00 on performance stuff.....
