Drivetrain Caliper Bushings
Old May 2, 2011 | 05:17 AM
PierreLeona's Avatar
PierreLeona
Caliper Bushings
Just a quick question, does anyone know if replacing the Caliper bushings with the solid bushings require the removal of the actual caliper? Or can it be done with the the pads and calipers all still assembled on the rotor?
Old May 2, 2011 | 05:48 AM
Vollgas's Avatar
Vollgas
The caliper has to be removed.
This mod is usually done when doing pad replacement, SS brake hose installation.
Old May 2, 2011 | 08:59 AM
thulchatt's Avatar
thulchatt
Vollgas is correct you need to take the caliper off the rotor, but that is all you NEED to do. Once the caliper is off the rotor you can pull the rubber bushing off and put the brass bushings in.
Pad replacement and SS lines are not required (good idea but not required).
Old May 2, 2011 | 10:28 AM
PierreLeona
Yea I was thinking about going wwith the solid bushings just because I heard they are a very nice addition to the braking system. Can anyone personally comment?
PierreLeona
AAnd also, should I get a set for the rear too or just the front?
Old May 2, 2011 | 03:26 PM
apexer's Avatar
apexer
I installed the solid bushings several years ago. Already had done the SS brake lines and ATEblue fluid about a year earlier. It was very easy install and you'll notice a big improvement in initial bite.
On the down side you MUST clean and re-lube the slider pins at least once per year or you'll get binding. This is really not a big job as the slider pins can be removed, cleaned & re-lubed without removing the caliper. Just have to remove the wheel for easier access.
Old May 2, 2011 | 07:37 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes you have to remove the calibers to install the caliber bushing kits.
But don't worry it's pretty easy install, and you'll really see the difference when you go drive.
Old May 3, 2011 | 05:12 PM
MINI33342's Avatar
MINI33342
But once installed they do not need to come off for servicing. Been loving mine for 4 yrs now.
Old May 3, 2011 | 05:59 PM
apexer's Avatar
apexer
Turner Motor Sport sells the caliper kit for $59.95 which will do two front or two rear calipers. (the same kit fits either front or rears)
http://www.turnermotorsport.com/p-41...grade-kit.aspx
YaTuSabe
Aug 23, 2018 11:41 AM
pahg
Oct 5, 2015 11:50 AM
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
Oct 1, 2015 12:18 PM
Oct 1, 2015 10:38 AM
