Drivetrain Anyone use the Shark Injector flasher?
Old Mar 18, 2011 | 04:17 AM
BlueR53Terror's Avatar
BlueR53Terror
Anyone on here have any experience with this ecu flash tool? Im looking to get more out of my r53, So far were running the 15% alta pulley, Alta Air intake, Invidia catback, plugs, plug wires. Im looking to take it up a notch, here the flashing tool im looking at, http://www.sharksales.com/products/2...-Injector.html
Old Mar 18, 2011 | 07:59 AM
checkmate2006's Avatar
checkmate2006
Don't get the shark .... Do a custom tune either remote or on location at a dyno.
Old Mar 18, 2011 | 08:14 AM
MNCRYSS's Avatar
MNCRYSS
I'd invest in either RMW or Mynes remote tool for custom tunes. That way if you make changes they can send updates via email to your tune later.
Old Mar 18, 2011 | 08:19 AM
cmt52663's Avatar
cmt52663
you might touch base with Marco at Turner Motorsport.
Turners has a great deal of experience with the Shark system, and Marco will not try and sell you - just tell you their experience.
I'd most likely have used this system, except that I'm running the Works software which Shark has not tackled as far as I know.
978-388-9595
http://www.turnermotorsport.com
Cheers,
Charlie
Old Mar 18, 2011 | 04:01 PM
BlueR53Terror
Does anyone have a link to Mynes, everything Ive search came back with a forum or a dead end website
Old Mar 18, 2011 | 06:24 PM
Soni's Avatar
Soni
http://mynesperformance.forumotion.com/forum
Old Jul 19, 2011 | 10:19 AM
eatsleepautox's Avatar
eatsleepautox
Running Stock S injectors, pulleys to 14PSI, CAI, Large TM intercooler, stock header, 3" straightpipe, supertrapp.
The sharkinjector has a much better throttle response than the "cartune" file that was on there before.
obviously the torque and hp curves weren't perfectly smooth, as it's a canned tune.
If you've got headwork, cams, a different charger, or 10:1 pistons then def get a dyno tune. Otherwise you should be happy with the SI.
Old Jul 19, 2011 | 08:48 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Save your money DON'T get the Shark Injector. It only changes timing and rpm limiter.
We offer remote tuning modules, or you can send us your ECU for a tune and end up with something much better.
Old Jul 20, 2011 | 06:17 PM
ZippyNH's Avatar
ZippyNH
A tuner can do much more than just get you more power...
they can adjust the traction control/dec, and much more importantly adjust you gas pedal sensivity so it will feel like you have a sprintbooster.....so for the price of a tune, you get much more....
If you are going to spend the $$, get a good tune, custom or canned.
Old Jul 21, 2011 | 09:13 AM
JumpingJackFlash's Avatar
JumpingJackFlash
+1 to custom tuner. They completely remap the entire program as if at the factory. I've heard and read many stories of the ECU "learning" the Shark injector's mapping (or similar tools) and overlaying them, which thus puts you back at a stock ECU program.
IQRaceworks
53
Jun 28, 2024 07:29 AM
NYMADMINI
Dec 14, 2016 02:33 PM
randeez
Oct 5, 2015 09:23 AM
WhinyR53
Sep 30, 2015 07:36 AM
dutchhome
Sep 30, 2015 07:17 AM
