Drivetrain The Official ALTA AccessPORT Thread
#1926
You mean to tell me that if I remove my neighbor's cat from the downpipe I can then run a Stage III tune? This has been bugging the sch!t me for months! She knocked on my door about 2 months ago and asked me if I'd seen her cat lately. Of course I responded no. But, now that I think about it, my exhaust *did* seem to have a _funny_ smell to it - Eau De Little Friskies is the best I can think of....
#1930
#1931
on
I have a question regardfing the 2012 JCW. Forgive me if it has already been asked. Will the Access Port be compatible with the 2012 JCW engine? I am planning to buy a 2012 JCW Roadster in the spring and I am trying to determine if my existing [unmarried from my totaled R56] AP will work or if I should just sell it.
#1933
#1935
#1939
#1940
The number you're seeing is a number the ECU uses for intake MAF calibration, that isn't in a standard unit that we would normally see. Cutting numbers in half is close to grams per second, but not quite. It's not super important though, since it isn't used in any tables that we modify in the tunes.
#1941
Just received my Accessport in the mail today. Hooked it up to the computer, downloaded and updated the firmware, and ran out to the car to play. Once I connected the unit to the car, It displays an error on the screen that its incompatible with my car, and to call support. It did allow me to backup the ECU, but would not allow me to complete the install.
#1942
on
Vehicle Not Recognized, Need to Dump my ECU data and email to ALTA:
As MINI releases new cars and new ECU data It may be necessary to dump the vehicle information stored in your ALTA AccessPORT. New ECUs and Vehicle may be released to the public before we can get them to our shop for R&D. Please follow these instruction if your vehicle is not recognized by your ALTA AccessPORT.
- If you see the screen "Doesn't recognize Vehicle, don't worry, click the button and proceed to the USER TOOLS section. Click on the Save ECU data button and follow the on-screen instructions to save ECU data.
- When ALTA AccessPORT is done saving data, it will return to the install screen. Simply unplug ALTA AccessPORT.
- Open ALTA AccessPORT manager software and plug in your ALTA AccessPORT.
- Verify ALTA AccessPORT connects to software, if not click the little AP Connect button.
- Click Filter drop down menu, then choose ECU Data.
- Click on the saved ECU file and save file to computer user the "Save Selected Files" button.
- Click on the Backup tab, select all files and either right click and save, or drag files to your desktop.
- Compose and send an email with these files attached to maps@altaperformance.com
- Please make sure to includes your name, car you have and build date.
- With in 1 to 2 business days we will add the new vehicle/ECU to our database and get you an update.
MAPS@ALTAperformance.com
hope that helps...
#1943
#1945
#1947
I had just about the same type of error message on mine when I first tried to use it on my '11 JCW and Chris told me to use the beta version of the ALTA software. After I upgraded the ALTA unit to the beta, it found the car, I was able to install the new map, and it works great now.
#1949
Sorry to be a little late on this, if the beta update isn't working, email me a copy of the ECU. The AP will give you the option of dumping the ECU after it doesn't recognize the car.
The AccessPORT comes preloaded with all the maps you're going to need.
Since you're in California, it will take up to 3 days once it leaves our warehouse. We have them in stock, so it should be going out very soon!
