Drivetrain The Official ALTA AccessPORT Thread
#1676
Hard to do though, because I really want to show people what may or may not be the result combined with poor quality manufacturing, possible lean conditions due to a failing HPFP, and 100+ ambient temps, and maybe some high boost...
Once more people start loosing pistons and breaking things they will begin to reconsider the amounts of boost we are all running. These are not the bulletproof VAG 1.8T's and 2.0T where you can run as much boost as you want and all will be fine....
And anyone who is running a bigger turbo or is planning to, really needs to consider building the motor if they want to play on the safe side...at the very least pistons. At least Alta has said they are running their billet turbos at about 20psi...which I think is a reasonable level. Someone mentioned they were running 27psi on their JCW with an alta billet turbo...you got to be out of your mind
And anyone running a tune needs to keep in their mind the possibility of things breaking one day...
#1677
#1678
Good post, thanks.
Saw your earlier posts around this too. Interesting to see your similar mention of lean condition, and agreed on others. I come from the Audi world, albeit larger displacement N.A. quattro; but certainly know back when the 2.7T popularized turbo's for them again after the original I5's, there were both quality issues and over tuned chipping feeding it, and 2.7T results and reliability weren't pretty--though with a more robust lower end apparently than here. I bought the 4.2 on that round fortunately. 1.8/2.0T off to a much better footing, though they also locked down the ECU better back in 2001 or 2. Feels like Mini is just getting to that around now (as in no Alta tunes for 2011 S's either thus far; maybe even outsmarted themselves w/ the seemingly vaporware JCW kit tune for 2011's??).
I have photos of pieces of my piston and can tell you all about what I think happened to mine...but I've chosen not to.
#1679
Agreed 27 PSI sounds...
way over the top w/out serious other motor mods, but I would expect the actual effective compression ratio to come up a fair amount less with turbulence issues, valve overlap and other things. Otherwise, that would be up there near diesel motors, with way more robustness right off the bat.
#1680
#1681
Keeping the best information flowing about mod's w/out intimidation
There is also another element to the story (with a variety of sharp words around it) concerning web posts on Boards like these; can raise ultimate questions about whether both tuning AND any posting about it are each risky. Unfortunately, that posting part may in turn drive down the quality of information out there if it chills the discussion.
#1682
#1683
I just got the Accessport a few weeks ago and, frankly, I'm struggling with it. I am running the Stage One tune, tweaked by Jan at a dyno day.
I have found that my boost is doubled, from 9-12psi to 18-22+psi and that is way too high for me. Is this others' experience, too? That seems way too aggressive for Stage One. I would like to be in the mid-teens. I can't figure out if it is the tune or if I have a mechanical problem in the turbo.
In addition, the ECT with the Stage One drops 20+ degrees, causing a P1028 code. When I go back to the stock JCW tune, the temp pops back up to 220+ and the code goes away.
I would like to get a feel for what you are all getting (boost and ECT) with the un-tweaked Stage One tune.
#1684
on
Thanks again!
#1685
on
#1687
#1688
#1690
Our cars are designed with a three stage cooling system. When the car is under load or it's hot outside etc. They are designed to open the third stage to maintain temp. Our cars try to keep the car at 217 for fuel efficiency. Click your ac on max and watch it drop too. As far ad the code I'm not sure, but that why the temp drops. I have got my car tricked into running open all the time as I live in Florida an it's already approaching 100deg on a regular basis.
#1691
Boost doesn't hurt motors it's improper fuel delivery and spark timing. Before the flaming starts please think about what I said. 27 psi at 10:1 and no spark advance is less stressfull than 20psi at 12.2:1 and 20 degrees of timing. Our bottom ends are pretty stout. If you look at other cars running the prince motors in Europe there are some surprisingly big numbers coming from stock shortblock cars. Like thumper said, you need to be prepared to break stuff. I can say that my car has been ravaged and I'm on my second shortblock (rings were toast but got a deal on a shortblock from mini) but it has taken A LOT!!!
#1694
(I own both and am partial to the 335, hence I'm defending it, hehehe)
#1696
Btw, just realised you have a JCW. That's a different ball game - I bet with an AP you're pushing 5 seconds, so easily a 335's time.
I once played around with an S5 in my 335 until eventually we came to a stop, he rolled his window down and demanded to know what I had under the hood
#1699
w00t!! Just ordered my AccessPort!
Man, I've never been so stoked to drop $900!! After reading virtually every post in this 68 page thread, I've decided that the AP is well worth the bux, Of course, I'll have to reserve final judgment for after I've installed the unit and flogged Monty for a day, but if it provides what everyone claims, this is the cheapest way to get a solid performance boost out of your Mini S.
I may end up adding an exhaust, CAI, and turbo blanket, but I'm gonna live with the AP for a while and see how it goes. Everyone asks me how I like my car and I invariably reply "I LOVE it, I just wish it had a few more ponies under the hood." Well, I'm about to see if that statement is true, wish me luck...
-RW-
-RW-
#1700
-RW-
-RW-
