Drivetrain The Official ALTA AccessPORT Thread
Old 09-09-2011, 08:56 AM
SMOG's Avatar
SMOG
SMOG is offline
ThumperMCS:
I thought that was the case and in reality the only reason to get better performance out of a Justa would be to get better gas mileage and perhaps a bit more low end umph
The "S" model is soooo much more performance/power oriented that if that was your goal then go buy one and end up saving time and money in the long run.
S.
  #2027
Old 09-09-2011, 09:40 AM
ALTA_Chris's Avatar
ALTA_Chris
ALTA_Chris is offline
Originally Posted by Tank571
Received and installed my AP tonight. WOW! That is about the only way I can sum it up. I put off this purchase for a while due to cost and now wish I would have done it sooner. I am so very impressed with the quality of the product and the tune. Now I need to upgrade the suspension and brakes to match. I also can't wait to see what the addition of Alta's FMIC will do. Thanks again to the guys at Alta, keep up the good work.
That's awesome, thanks for the feedback! The FMIC will help quite a bit.
Originally Posted by Digitys
Does gas mileage suffer after a tune?
Gas mileage is going to be similar to stock, unless you get crazy after installing it and turn into a lead foot!
  #2028
Old 09-09-2011, 11:49 AM
ThatMiNiGuy's Avatar
ThatMiNiGuy
ThatMiNiGuy is offline
Yes, tt will retain stock MPG. Once you do pulls and start flooring it, just using OTS Stg1 map, it will consume lots of fuel. 18-18.5psi is worlds of a different over stock.
  #2029
Old 09-09-2011, 06:47 PM
PinkMiso's Avatar
PinkMiso
PinkMiso is offline
I have a suspicion my hpfp is on its way out and was wondering if anyone running stage 1 has a datalog for a WOT pull they can send me and also their fp readings at idle? Thanks in advance
  #2030
Old 09-13-2011, 05:09 PM
ThumperMCS's Avatar
ThumperMCS
ThumperMCS is offline
Are the STFT and LTFT values that the AP displays expressed in percentages? Looking on Cobb's site it doesn't specify....
  #2031
Old 09-13-2011, 06:33 PM
Mike@Tech Division's Avatar
Mike@Tech Division
Mike@Tech Division is offline
It's a percentage.
  #2032
Old 09-13-2011, 06:48 PM
ThumperMCS's Avatar
ThumperMCS
Originally Posted by Mike@Tech Division
It's a percentage.
Are you sure its not a factor? 1.0 meaning no fuel trim adjustment...and then anything above or below 1.0 is the amount of trim?
Because it almost always dispalys 1.0....
  #2033
Old 09-13-2011, 09:53 PM
djdraddy's Avatar
djdraddy
djdraddy is offline
Just a quick question...
Am I correct in thinking that this product is applicable to 2007-2010 R56, R55, R57, S's and JCW's and the 2011 JCW, and that's it?
Yes?
No?
  #2034
Old 09-14-2011, 08:42 AM
dez's Avatar
dez
dez is offline
Yes, that is correct djdraddy.
  #2035
Old 09-14-2011, 09:00 AM
ALTA_Chris's Avatar
ALTA_Chris
Actually both of you are kind of right, anything over 1 is adding, but it's multiplied by 1, so 1.05 would mean that it's adding 5%, and .95 would be taking out 5%. 1.0 would not be adding anything. Hope that makes sense.
Yes?
No?
Pretty much, all North American MCS turbo models up 2010, and 08-11 JCWs.
  #2036
Old 09-14-2011, 09:53 AM
ThumperMCS's Avatar
ThumperMCS
Cool, that's what I suspected...thanks Chris!
  #2037
Old 09-15-2011, 04:22 PM
jlevy's Avatar
jlevy
jlevy is offline
how do I see the current release note history on AP
My AP has shown the same release note history for 1.6.3.0-607 for many months now. I'm currently on 1.6.3.2-2613. How do I see the latest notes? The AP was purchased new from Alta.
Also, all my maps show v0.00
-JL
  #2038
Old 09-15-2011, 04:43 PM
ALTA_Chris's Avatar
ALTA_Chris
JL,
That is normal, we haven't updated the notes since October I believe. The maps actually haven't changed in months now, the updates we've been doing since then have been adding new ECUs.
  #2039
Old 09-15-2011, 11:37 PM
pallym's Avatar
pallym
pallym is offline
2011 mcs?
I want to know if the AP works with the 2011 MCS, since one of the above post only shows that it works with the 2011 JCW.
Thanks,
Mike
  #2040
Old 09-16-2011, 07:24 AM
Porthos's Avatar
Porthos
Porthos is offline
No not yet they are working on it. Take it easy, you 11+ people are impatient as hell.
  #2041
Old 09-16-2011, 09:06 AM
SMOG's Avatar
SMOG
SMOG is offline
Still patiently waiting the debut of the MAPS for the 2011 MCSa
  #2042
Old 09-16-2011, 09:11 AM
SMOG's Avatar
SMOG
SMOG is offline
The impatience probably has to do with the statement on their web site that states for the 2011MCS , "2011 Cooper S / Clubman S (PENDING 01/15/2011)". "Pending" and specifying a certain date does imply that it will happen near that date.
  #2043
Old 09-16-2011, 10:07 AM
Achilles honor's Avatar
Achilles honor
Achilles honor is offline
I can wait. and i have a 2011.. im not impatient yayy... so now that im not impatient can i have my accesssport
  #2044
Old 09-16-2011, 10:40 AM
ALTA_Chris's Avatar
ALTA_Chris
You guys are funny! We're still working on 2011 MCS. When it's ready, we will let everyone know.
  #2045
Old 09-16-2011, 10:59 AM
Achilles honor
I feel like the access port for the 2011+ are like the mini communities iPhone 5.. We are soo impatient
  #2046
Old 09-16-2011, 05:15 PM
Porthos's Avatar
Porthos
Porthos is offline
  #2047
Old 09-17-2011, 03:03 AM
MotorMouth's Avatar
MotorMouth
MotorMouth is offline
no more impatient than we were in 2007.
  #2048
Old 09-17-2011, 07:39 AM
Porthos's Avatar
Porthos
Porthos is offline
True but, by the time I came around in 09 there really was not very many people talking about tuning.
  #2049
Old 09-17-2011, 06:31 PM
shawnam95's Avatar
shawnam95
shawnam95 is offline
I need help Accessport with A/T Problem.
I received my accessport 3 weeks ago and when i installed it all the stage 1 tunes cause the same problem. Everytime the car changes gear i lose all power and then i get a surge of power. It feels as if someone is repeadetly jamming on the throttle. Im not being picky the car is actually undriveable with the Accessport installed, and on top of that my Rpms are very unstable when the car is idleing. The car even does this when im using the tiptronic. I was wondering if anyone had this problem I have a 2009 clubman A/T with an alta CAI and Turbo Inlet. When I uninstall the AP my car runs beautifully. And ive had the car looked at by a MINI mechanic who also said everything is fine Mechanically. I Talked to Jeff at Alta but hes never heard of it before. So please any advice would be really appreciated.-Thanks
  #2050
Old 09-18-2011, 03:02 PM
djdraddy's Avatar
djdraddy
djdraddy is offline
Wow... Does this mean that the AccessPort only works properly with manual transmissions?
This surging throttle thing with the automatic sounds a little on the dangerous side!
So now I'm looking at AccessPort being compatible with North American MCS turbo models with manual transmission up to 2010, and 08-11 JCWs.
Yes? No?
Quick Reply: Drivetrain The Official ALTA AccessPORT Thread
