Drivetrain The Official ALTA AccessPORT Thread
Old Jul 24, 2011 | 08:09 AM
  #1901
Verithas's Avatar
Verithas
any further information about EU cars?
Old Jul 25, 2011 | 04:09 PM
  #1902
ALTA_Chris's Avatar
ALTA_Chris
No new info, sorry! We are not yet committed 100% committed to this yet.
Old Jul 25, 2011 | 09:34 PM
  #1903
Porthos's Avatar
Porthos
Bought one the other day. Got a couple more questions though. If I install the stage 3 take it to a dyn have it dynoed, will you guys tweak the tune? And my other question is does the AP work for base Coopers? I don't have one but just wondering. Thanks
Old Jul 26, 2011 | 06:20 AM
  #1904
Raymazing's Avatar
Raymazing
No AP for Justas' AFIK. If your tuner has the protune software for the cobb they will tweak the existing map.
Old Jul 26, 2011 | 11:08 AM
  #1905
Porthos's Avatar
Porthos
I don't have a Cooper. I have an S. I was just checking to help those who own Coopers.
Old Jul 26, 2011 | 02:35 PM
  #1906
ALTA_Chris's Avatar
ALTA_Chris
If you put your car on a dyno, we're not going to be able to tune it unless we are there.
The AccessPORT does not work on base Coopers, just the MCS and JCW.
Old Jul 26, 2011 | 09:11 PM
  #1907
Porthos's Avatar
Porthos
Well thought I would ask.
Old Jul 30, 2011 | 04:45 PM
  #1908
Grimnebulin's Avatar
Grimnebulin
Hey Chris (thanks for the email support) and Adam - I finally (due to my own lack of time) got the beta software to work with my '11 JCW - uploaded Stage 1 91oct tps map and it runs amazing. Your TPS program is smoother and better than the stock JCW Sport mode. Love it. Thanks!
Old Jul 30, 2011 | 08:36 PM
  #1909
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
That is exactly what we love to hear! Thanks for the feedback and enjoy the POWER!!!
Adam
ALTA Performance
Old Jul 31, 2011 | 09:30 AM
  #1910
Grimnebulin
Adam
ALTA Performance
Yes! Obviously a lot more power too - that is clearly noticeable. Thanks!
Old Jul 31, 2011 | 04:45 PM
  #1911
rockridge's Avatar
rockridge
If I have a JCW tune with the JCW CAI and JCW exhaust, can I run a stage 2 tune without negatively effecting the car?
Old Aug 1, 2011 | 10:24 AM
  #1912
ALTA_Chris's Avatar
ALTA_Chris
Rockridge,
For your car, you will have to run a stage 1 tune. Stage 2 is for a car with a 2.5" catless exhaust, or 3" high flow cat turbo back car.
Old Aug 1, 2011 | 10:46 AM
  #1913
DneprDave's Avatar
DneprDave
Chris,
What will happen to a car that is running a higher tune than it is equipped for?
Dave
Old Aug 1, 2011 | 02:00 PM
  #1914
ALTA_Chris's Avatar
ALTA_Chris
Dave, it could cause excessive wear on the engine, turbo and cats. Definitely not something you want to do!
Old Aug 4, 2011 | 05:34 PM
  #1915
minizenga's Avatar
minizenga
Really? Can't stage 2 w/ 60mm downpipe back? Booo.
Old Aug 4, 2011 | 05:53 PM
  #1916
MiniBOL's Avatar
MiniBOL
After much reading (ok, maybe not), I'm ready to get one. I don't have any engine mods but will do so within the next few months. Would I be okay running the AP with just stock engine for now?
Thank you.
Old Aug 4, 2011 | 09:46 PM
  #1917
Porthos's Avatar
Porthos
Wait I thought the JCW factory exhaust was 2.5" and high flow. If not looks like I will not be able to run stage 3. I will also have a catless DP.
Old Aug 5, 2011 | 08:41 AM
  #1918
ALTA_Chris's Avatar
ALTA_Chris
60mm is 2.3 inches. That's pretty small. The stage 2 map is for a turbo back exhaust only. If you're looking for more power than our maps provide, you can always get a protune.
Thank you.
The stage 1 maps are made specifically for a car that is stock, or with basic bolt on parts, so you will be totally fine.
The stock cats are not high flow cats. The only way to run a stage 2 map is by running a catless turbo back 2.5" or 3" high flow cat turbo back exhaust. If you have any stock exhaust parts after the turbo, you have to run a stage 1 map.
Old Aug 5, 2011 | 08:52 AM
  #1919
minizenga's Avatar
minizenga
So a 2.5" catless downpipe back won't qualify for stage 2?
Old Aug 5, 2011 | 10:09 AM
  #1920
Porthos's Avatar
Porthos
JCW exhaust I got is catless so I should be good to go then?
Old Aug 5, 2011 | 11:04 AM
  #1921
ALTA_Chris's Avatar
ALTA_Chris
2.5" catless turbo back can run a stage 2 map.
If you're running the stock JCW exhaust, then you have a cat. The JCW and MCS exhaust sizes are the same, about 2.25". So to run a stage 2 map, again, you have to have a 3" turbo back with a high flow cat, or a 2.5" turbo back with no cats.
Old Aug 5, 2011 | 04:27 PM
  #1922
dez's Avatar
dez
so the only thing you would need to do is, replace the cats on a jcw factory exhaust to get to stage 2?
is that just a downpipe basically?
Old Aug 5, 2011 | 04:41 PM
  #1923
ALTA_Chris's Avatar
ALTA_Chris
Dez,
To run a stage 2 map, you need a 2.5" turbo back exhaust with no cats.
The stock JCW exhaust is not 2.5". You have to go with an aftermarket turboback exhaust.
Old Aug 5, 2011 | 06:13 PM
  #1924
ThumperMCS's Avatar
ThumperMCS
Dez,
The stage 3 tune is only for a car that is running a 3" turbo back or a car with a 2.5" catless turbo back exhaust.
Customers will be able to go stage 2 or stage 3 with a catless 2.5" turbo back exhaust. Only if it's catless though. If it has a cat, you will have to keep on using the stage 1 map.
Any setup using the stock cats require a stage 1 tune.
Any exhaust that has a cat but is less than 3" requires a stage 1 tune.
Any exhaust that is 3" either it being catless or high flow cat can use a stage 2 tune.
Any turbo back that is a 2.5" that is catless can use a stage 2 tune. But it has to replace the whole exhaust. If there's any OEM downpipe or catback exhaust parts being used, a stage 1 is required.
Just in case people STILL DON'T get the idea or understand.....here you go, made it easy for everyone.
Old Aug 5, 2011 | 11:19 PM
  #1925
sooper_cooper's Avatar
sooper_cooper
The official ALTA AccessPORT Thread Cliff's Notes!
