Drivetrain The Best Manifold
Old Jul 2, 2010 | 01:15 AM
Nelson Costa's Avatar
Nelson Costa
The Best Manifold
Hello!
What will be the best Manifold with CAT, for me to gain more power at low and medium speeds, for my R53 Cooper S?
Best Regards,
Nelson
Old Jul 2, 2010 | 05:30 AM
2mD's Avatar
2mD
my opinion:
modified oem ( if you have the tools and the time to do it yourself )
- increase the inlet ports if you have a modified head
- smoothen the part where the primary tubes connect to improve flow
original:
better:
- cut out the precat section and that weird restriction right before it and weld in a straight tube
above is the original, below the modified one notice the bend before the precat, and on the modified one: the precat is only show ( so it looks streat legal the pipe is going straight trough without any change in diameter ( that would produce turbulences -> restricting flow )
- i also changed the last pipe behind the main cat ( slightly bigger ) but i dont think thats needed
Old Jul 2, 2010 | 07:56 PM
R53Warrior's Avatar
R53Warrior
wow thats some pretty cool almost free modification
Old Jul 5, 2010 | 12:54 PM
CRoth's Avatar
CRoth
I noticed you plugged both o2 sensor holes. Are you using o2 simulators?
Old Jul 5, 2010 | 02:16 PM
2mD's Avatar
2mD
yes i use both, i just pluged them while working on it ( making sure nothing gets damaged or dirty )
and theres no engine light flashing
Old Jul 5, 2010 | 02:24 PM
CRoth's Avatar
CRoth
I've been thinking about removing my first cat but didn't want to throw any codes. Did you do anything different to avoid getting codes? I was under the assumption that if the first cat was removed I'd get a code.
Old Jul 5, 2010 | 02:35 PM
2mD's Avatar
2mD
depends on what kinda tune you have...
one, cooper, cooperS will probably trow a code, jcw usually doesn't
im using the jcw tune ( with a raised rpm limit and better adjusted dtc, otherwise stock jcw )
Old Jul 5, 2010 | 02:51 PM
CRoth's Avatar
CRoth
I have a RMW tune and my rev limiter is around 7400. I'm not sure what that has to do with the O2 sensor code though.
Old Jul 5, 2010 | 03:02 PM
2mD's Avatar
2mD
then you should ask rmw how the tune would react
Old Jul 5, 2010 | 03:23 PM
CRoth's Avatar
CRoth
I'm going to ask Jan when he re-tunes my car this month. I would have never thought to ask him about that until your post. Thanks
KinetechMW
Jan 22, 2016 09:04 AM
GAT
Oct 4, 2015 07:27 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
Adam Bradbury
Sep 24, 2015 08:30 AM
