Drivetrain Post your 2nd gen dynos!
Old Aug 11, 2014 | 08:25 AM
  #76
johntotah94's Avatar
johntotah94
Originally Posted by Grizld700
Question on your "stock" run. Does that still include all your bolt-ons? Or is that 100% stock set up?
Yes all bolt ons. Sorry I meant stock map.
Old Aug 11, 2014 | 09:03 AM
  #77
Grizld700's Avatar
Grizld700
Ahhhh, gotchya. I thought the 'stock' run was extremely good, better than factory actually . That explains it!
Old Jan 23, 2015 | 06:33 PM
  #78
johntotah94
Stage 3 Manic Tune.
N18
261whp 271wtq
Mustang Dyno
Attached Thumbnails Post your 2nd gen dynos!-screen-shot-2015-01-23-at-6.31.27-pm.jpg
Old Apr 2, 2015 | 03:35 PM
  #79
liljimbo03's Avatar
liljimbo03
Almost 300BHP
Dyno details:
Weather/Atmospheric conditions:60 degrees with 29% humidity
2010 Camden R56 N14
[IMG][/IMG]
Max WHP:238 (291BHP)@crank (Had to put this: makes me feel good)
Max Tq:271 (331Ftlbs Tq) @Crank
Modifications:Franken Turbo, 225%bigger inner cooler, AEM cold air scoop intake, racing cat down pipe-straight back to stock muffler, NM Engineering Air Charge Pipes, and a OS Giken GT Clutch. (less than 5k installed)
Old Aug 2, 2015 | 07:10 PM
  #80
dbak2005's Avatar
dbak2005
KMW 3 inch dp and exhaust no cats, and k&N cone air filter on stock intake tube.
N14
196whp 224tq
More mods to come, then we tune
Old Aug 3, 2015 | 08:15 AM
  #81
Grizld700's Avatar
Grizld700
N14
196whp 224tq
N14 S or JCW?
Old Aug 3, 2015 | 08:57 AM
  #82
rckrzy1's Avatar
rckrzy1
Dynojet , 90F 40% humidity , Manic Stage 1 ( still emissions legal with stock cat )
219HP 242 TQ at the wheels.
Old Aug 3, 2015 | 02:04 PM
  #83
dbak2005's Avatar
dbak2005
n14 s
Old Aug 3, 2015 | 02:21 PM
  #84
Grizld700's Avatar
Grizld700
n14 s
Thats pretty impressive for an S with minimal mods and no tune!
I've seen tuned S N14's make less power.
Old Aug 3, 2015 | 03:46 PM
  #85
dbak2005's Avatar
dbak2005
Yea thats what i keep hearing.. but i def feel the power difference ever since i got rid of the stock dp and exhaust.
Old Aug 9, 2016 | 07:03 PM
  #86
Tigger2011's Avatar
Tigger2011
Alliance Member
Dyno details: Dynojet 224x
95.51 °F, 29.82 in-Hg, Humidity: 53%
Max HP: 263
Max Tq: 236
Modifications: Manic Stage 2+ 100% Meth via Aquamist HSF-4, Custom 3" exhaust with WMW DP, Helix FMIC, DDMWorks RIS Intake. Stock engine and JCW turbo.
Torque curve stays pretty flat till ~5,700 RPM so I'm happy with that. The JCW turbo keeps 23 psi till about 5,500 but just runs out of steam thereafter.
Old Aug 9, 2016 | 07:38 PM
  #87
MarioKart's Avatar
MarioKart
Vendor
Originally Posted by Tigger2011
Dyno details: Dynojet 224x Weather/Atmospheric conditions: 95.51 °F, 29.82 in-Hg, Humidity: 53% Max HP: 263 Max Tq: 236 Modifications: Manic Stage 2+ 100% Meth via Aquamist HSF-4, Custom 3" exhaust with WMW DP, Helix FMIC, DDMWorks RIS Intake. Stock engine and JCW turbo. Torque curve stays pretty flat till ~5,700 RPM so I'm happy with that. The JCW turbo keeps 23 psi till about 5,500 but just runs out of steam thereafter.
Hi Lou,
Do you have a graph? Your HP looks really, good, just curious about your torque.
mQubed Motorsport, Manic Tuning Dealer
Old Aug 10, 2016 | 05:45 AM
  #88
Tigger2011's Avatar
Tigger2011
Alliance Member
Originally Posted by MarioKart
Hi Lou,
Hi Mario,
It's in the post above which displays fine on a PC. For some reason when you view the thread on the app you have to use the expand gesture for it to display on my iPhone. Not sure whats up with that. Did three pulls. The first two in 4th and the final in third. I was a bit disappointed in the first torque results. Second run I've also attached below which came in at 259 HP and 251 torque. The torque tappers a bit sooner on this one. Unfortunately, traction on the final run in third was a problem. I installed a mechanical LSD from Wavetrac when I installed the OS Giken twin disc clutch but both wheels still broke loose around 4000 RPM.
Old Aug 16, 2016 | 09:27 PM
  #89
MarioKart's Avatar
MarioKart
Vendor
Hi Mario, It's in the post above which displays fine on a PC. For some reason when you view the thread on the app you have to use the expand gesture for it to display on my iPhone. Not sure whats up with that. Did three pulls. The first two in 4th and the final in third. I was a bit disappointed in the first torque results. Second run I've also attached below which came in at 259 HP and 251 torque. The torque tappers a bit sooner on this one. Unfortunately, traction on the final run in third was a problem. I installed a mechanical LSD from Wavetrac when I installed the OS Giken twin disc clutch but both wheels still broke loose around 4000 RPM.
Hi Lou, I use Tapatalk APP, it can be quirky at times for pictures and other details, that are no problem for a PC. You HP seems right on target, but it does seem like your peak torque is low, I would expect your TQ to be around 275wtq. Is this the same Dyno you always go to? I'm sure the tune is strong, but maybe there is small physical glitch? I'm glad you are enjoying your R58 and saving the "third pedal revolution" mQubed Motorsport, Manic Tuning Dealer
Old Aug 17, 2016 | 08:08 AM
  #90
EuroTechsAZ's Avatar
EuroTechsAZ
Stock N14 S engine with a few bolt on's
100% stock N14 S engine. Stage 3 Manic tuning.
Old Aug 17, 2016 | 08:50 AM
  #91
EuroTechsAZ
Built N14 with big turbo etc etc Manic stage 4 361whp on( "low reading dyno" per another mini tuner who used the dyno earlier that day)
N14 GTX powered
Old Aug 17, 2016 | 10:16 AM
  #92
Tigger2011's Avatar
Tigger2011
Alliance Member
Unfortunately no. DST's dyno was down so I went elsewhere. Temps were up there at 95°-96° but I was still expecting better torque as even with the LSD it can be a hand full. If DST doesn't get theirs fixed soon I may try another shop as we have several local. Maybe I should just say the heck with it and buy my own... "Hmm... Now where did I leave that $60K laying around at?"
Old Aug 17, 2016 | 11:18 AM
  #93
randeez's Avatar
randeez
Lou, lemme know next time you schedule a dyno day I may wanna tag along :D
Old Aug 17, 2016 | 03:00 PM
  #94
Tigger2011's Avatar
Tigger2011
Alliance Member
Sounds like a plan.
Old Aug 17, 2016 | 06:53 PM
  #95
MiniMoic's Avatar
MiniMoic
Stock engine and Manic stage 3 !?!?!?? And how did you get the last one!!!! My graphs are no way close to this even with a 47mm turbo
Old Aug 19, 2016 | 03:11 PM
  #96
AndresR's Avatar
AndresR
266 whp stock jcw turbo, manic stage 2+
Still pending to install RMW head, looking for cams, any advice? And bigger turbo too.
Old Nov 26, 2016 | 08:38 PM
  #97
bobo1563's Avatar
bobo1563
I second this. Would like to know more details
Old Oct 11, 2017 | 01:27 PM
  #98
csllover's Avatar
csllover
Mini Cooper S (N14) - Manic Stage 2; intercooler, K&N filter, decat, iridium plugs.
Old Mar 1, 2018 | 06:44 AM
  #99
4mikebruns's Avatar
4mikebruns
NAM Community Team
Manic Stage 2 Map C, EBay intercooler, CTS intake, catless downpipe, custom exhaust, JMTC 42 turbo. 93 octane.
Old Apr 2, 2018 | 04:27 PM
  #100
4mikebruns's Avatar
4mikebruns
NAM Community Team
R55 N18 Automatic
Catless, intake, FMIC, JMTC 42mm,turbosmart DV, RPM Stage 3. The dotted lines are Manic Stage 2 with the same mods...kinda have to ignore them a little as I didnt find out until days later my Wastegate was too tight on the stage 2 pulls so the car was pushing 23.5 psi.
