Drivetrain Tuning (RMW or other), Dyno & AFR....
Old Apr 13, 2010 | 07:30 PM
Canuck's Avatar
Canuck
Hi Guys,
I've been searching around for info on the tuning process of our R56 and going through the dyno sheets. Lot's of dyno results are available but they never display AFR ratios.
Those of you who have been tuned by Jan (or others) can you walk us through the process? When your strapped into the dyno, you obviously get WHP & WTQ, but is AFR being measured? Where is it being measure on a stock exhaust system?
Just trying to understand.
Thanks!
Old Apr 13, 2010 | 08:06 PM
Sabes's Avatar
Sabes
I know my A/F ratio's were being measured, there was a tool clamped to my tailpipe, so i'm not sure if that was the source, or the info was taken from the ECU. But I know A/F's are definitely being watched
This was with Jan (RMW) btw
Old Apr 13, 2010 | 08:13 PM
Canuck's Avatar
Canuck
I hope it was from the ECU....it shouldn't be from your tail pipe. It needs to be before the main CAT.
I'm debatting doing a remote tune but I want to keep my car more of less stock. Especially the exhaust but there's no bung for a wideband O2 sensor. Although I keep reading that the mini has a built in wideband...just very little info on it.
Old Apr 13, 2010 | 08:17 PM
ThumperMCS's Avatar
ThumperMCS
They read it from the tailpipe and they are watched closely during tuning. There is nothing wrong with reading from a tailpipe sniffer...the readings will just be slightly leaner than they would be from an actual wideband reading. So if you are tuning off of those...you are going to be on the safe side, the motor will be running slightly richer than the readings.
And yes the R56 has an onboard wideband. I have my ScanGuage set up to read AFR's at all times.
Old Apr 13, 2010 | 08:30 PM
Canuck's Avatar
Canuck
Humm...so the on-board O2 is truly a wideband, that's good to know. I still haven't connected my Scangauge yet. I find the cable end get's in the way of my left foot.
As for the tailpipe sniffer, my local dyno shop will not dyno with a tailpipe sniffer. They insist that it's not accurate enough. They're a good shop and very well respected (tune Porsche, VW, Mitsu, Subaru and of course Honda).
When I was tuning my last fun car, this was a real issue and I ended up installing headers with the additional bung. Loved the performance gain but the car was annoying as hell to drive. The drone on the highway was unbearable. I always regretted the headers.
Old Apr 13, 2010 | 08:32 PM
ThumperMCS's Avatar
ThumperMCS
Feed the cable up through the compartment below the steering column. It will be out of sight and out of your way.
Old Apr 13, 2010 | 08:38 PM
Canuck's Avatar
Canuck
I've been a bit lazy on the scangauge....I need to get on it.
I just picked up a Forge intercooler and that's my next install. My engine will be staying stock aside from the Forge and Jan's tune.
Old Apr 13, 2010 | 08:40 PM
ThumperMCS's Avatar
ThumperMCS
Honestly that's all you need anyway!
Downpipe also, but it seems like u don't want to touch that
Old Apr 13, 2010 | 08:42 PM
Canuck's Avatar
Canuck
Downpipe needs to stay....it's a daily driver for myself and the wife...spousal approval needs to remain high.LOL
Plus I really don't want the exhaust any louder than it is.
Old Apr 13, 2010 | 09:06 PM
mellanor's Avatar
mellanor
Not to mention that none of the currently-available downpipes are CEL-free...
Colt45Magnus
Aug 27, 2024 05:03 AM
W0TM8
Dec 19, 2019 07:50 AM
mct
Nov 29, 2015 04:51 PM
blackie
Sep 2, 2015 09:16 PM
sungjk
Aug 5, 2015 08:23 PM
