Drivetrain Installing 17% pulley - problem!!!!
Old Mar 13, 2010 | 02:56 PM
Kmill's Avatar
Kmill
So my roommate and I were to the point of taking the OEM pulley off. We put the pulley removal tool on and started the process of removing it. The end of the bolt started to go into the threads, so we stopped and removed it. The threads are basically shot at this point. Does that mean I am too? I'm going to sears to buy a pulley removal tool with a swivel head, which I read in a different set of instructions after seeing this happening.
Help?
Old Mar 13, 2010 | 03:10 PM
chubbycheddar's Avatar
chubbycheddar
I believe you are actually supposed to put a bolt in there. Then when you go to use the pulley remover it grinds on the bolt's end instead of the threads. One of the bolt you had to have taken out in order to get to the pulley actually fits in that place perfectly. Hope this helps
Step 17 shows you exactly how you are suppose to do it.
http://www.minimaniauk.co.uk/web/SCa...2/ArticleV.cfm
Old Mar 13, 2010 | 04:05 PM
Kmill's Avatar
Kmill
thank you. so i did this and then as the pulley removal tool was "working" it bent the stock pulley. this is basically giving me a panic attack haha. even with damaged threads will the bolt still work? i'm about to go out and try it now...
Old Mar 13, 2010 | 05:08 PM
Fatherdeth's Avatar
Fatherdeth
This is a common occurance with the stock pulley. The stock pulley usually can't be reused. Mine is currently being used as a paperweight.
Old Mar 13, 2010 | 05:35 PM
Kmill's Avatar
Kmill
so we have the alta v2 pulley removal tool on and a new pulley puller from sears ... how do we stop the pulley from spinning without damaging other things?
Old Mar 13, 2010 | 05:42 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Here are Alta's pdf instructions for your V2.
http://www.altaperformance.com/share...205v2210v2.pdf
Old Mar 13, 2010 | 06:27 PM
Kmill's Avatar
Kmill
yeah. i have 4 sets of instructions printed out. the pulley is off. thank the car gods. now, we are short one adapter for my inch/lbs tq wrench... awesome
Old Mar 13, 2010 | 06:55 PM
chubbycheddar
It's all goin to be worth it in
the end. I did my own aswell and it was a little fustrating but the new found power afterwards is worthy it many times.
Old Mar 14, 2010 | 09:47 AM
Kmill's Avatar
Kmill
we finished. it only took 7 hours, but we finished. that thing screams!
squawSkiBum
Oct 2, 2015 09:21 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
