Drivetrain R56 Noisemaker Revealed!
Old Jul 12, 2013 | 09:13 AM
  #151
ltjpunk7's Avatar
ltjpunk7
I used the 1 1/4" expansion plug too, and I wonder if a smaller size wouldn't be easier... I had to modify it quite a bit to get it to fit. I wonder if the next size smaller would make it easier. Then you could just tighten it down to get it to expand and fit. Just a thought. Mine took awhile to get to fit. Didn't put sealant on it...hopefully it stays.
Old Aug 31, 2013 | 04:06 PM
  #152
Ian Landesman's Avatar
Ian Landesman
I bought the two suggested sizes. I used the smaller plug, but the metal washer from the bigger plug. This made placement easy, but physically impossible for the plug to be sucked into the boost tube. I wouldn't have felt comfortable if I'd used the smaller plug washer as I'd be concerned it could be sucked into the engine later on.
I didn't want to over-tighten and crack the plastic Y tube. It's possible that if I didn't tighten it adequately it could be pushed into the noisemaker tube and simply act as a loose plug. Even then it'll be doing a better than OEM job. I will check down the road.
Old Sep 26, 2013 | 09:48 PM
  #153
pepperwhiteknight's Avatar
pepperwhiteknight
2012 MCS OEM without noisemaker
So I was driving a 2012 MCS dealer loaner and it was unusually quiet. So I popped the hood and it was noisemaker-less
The previously posted photos of the OEM noisemaker-less mini did not work.
Here are 10 photos and a 39 second video.
https://www.dropbox.com/sc/yxhehwy601iln9k/Nr4v7OgeO0
Attached Thumbnails R56 Noisemaker Revealed!-2013-09-26-20.51.35.jpg   R56 Noisemaker Revealed!-2013-09-26-20.51.45.jpg   R56 Noisemaker Revealed!-2013-09-26-20.57.17.jpg
Old Sep 28, 2013 | 07:12 AM
  #154
pepperwhiteknight
Update:
I would not recommend the plastic oem replacement. Mine popped off last Tuesday (09/07/2015) while I was highway driving and sounded like a gunshot under the hood. The end that attaches to the throttle body is the bad end. The rubber gasket and the ribs that keep the gasket clamp from sliding off are damaged.
Mini had this part. 13719806688-03
At $85 it is much cheaper than the NM Eng replacement tube but a lot more than sticking a plug in the tube. From what I read above the plug solution is working but I wanted a manufactured part.
I am having trouble understanding the cowl space. Does water get in there when it rains? It that where the A/C gets air?
https://www.dropbox.com/sc/wdpnxxk9s8x6nou/w0QtekIkpw#/
Attached Thumbnails R56 Noisemaker Revealed!-2013-09-27-16.42.56.jpg   R56 Noisemaker Revealed!-2013-09-27-16.20.59.jpg   R56 Noisemaker Revealed!-2013-09-28-09.02.37.jpg
Last edited by pepperwhiteknight; Sep 11, 2015 at 04:24 PM. Reason: Advising against this part because it failed me on the highway.
Old Sep 28, 2013 | 09:08 AM
  #155
BMBULBE's Avatar
BMBULBE
Noise maker? A P.O.J (piece of junk) to be sure. The sad truth is that Minis would profit from being quieter inside. I understand the factory added more sound deadener as part of the "freshening" they did in 2011.
Old Sep 28, 2013 | 10:29 PM
  #156
pepperwhiteknight
Definitely a PPOJ, fake engine noise. Even after removing the noisemaker it seems like the loaner was quieter. Could be the amount of sound deaden-er, it was an auto, tire size, tire brand, and door seal wear and tear. I think it slightly tweaked the sound a little in the area of 3000 rpm. Seems a little less in your face. Still get the sound of the engine revving and exhaust which I like a lot. If I wanted a boring and super quiet driving experience I would have got another Cadillac.
Old Apr 5, 2014 | 08:20 AM
  #157
coachvminis's Avatar
coachvminis
Far-Out! I'm new to the Mini World (09' S R56) coming from the Audi World...
Just read all the posts about this and will do today or tomorrow! Sounds like a Sunday project.. Thanks Fellas! And Gals if there is a Female tuner in the Mini World..
Nothing like a Female Tuner... My ex helped in installing my DP on the TT!..
Old Apr 5, 2014 | 08:46 AM
  #158
MattyKHZ's Avatar
MattyKHZ
Thought it might be worth linking to the thread I made with the oem pipe replacement
https://www.northamericanmotoring.co...er-delete.html
Old Sep 21, 2014 | 05:11 PM
  #159
ajje1's Avatar
ajje1
Originally Posted by tominizer
I've heard speculation that this removal (mod) adds at least 10% better performance due to the weight reduction and better balances the vehicle to a more neutral 50/50 weight distribution left to right ..................... !!
Ha
Old Nov 16, 2014 | 12:24 PM
  #160
Moire's Avatar
Moire
I was looking at the noisemaker delete kit from WMW http://www.waymotorworks.com/noise-m...5-r56-r57.html
it says that it's for 2007-2010... does the 2011 not have this noisemaker or is it just this part won't work for it? is there another part somewhere that does work?
Old Nov 18, 2014 | 02:18 PM
  #161
pepperwhiteknight
I have been told that the 2011 is not supposed to have a noisemaker. MINI probably had an ample supply of noisemakers so they installed them on the 2011s until the supply was exhausted. I bet the WMW kit will work. Other options are homedepot, replace the hose with a MINI part, or replace the hose with aftermarket part.
Old Nov 18, 2014 | 02:21 PM
  #162
JCW_Coupe's Avatar
JCW_Coupe
my 2012 has it :( but i swapped the 2013 GP one in for it when i put the NM in :P
Old Nov 18, 2014 | 02:33 PM
  #163
Here is the bypass part. 13719806688
http://www.ecstuning.com/Search/SiteSearch/13719806688/
Its up to 6/2010 N14 on the R56 R55 R57 Cooper S, ( 13712753078 part ) It was left on the N14 JCW all the way till 2012 models. That R55 R56 R57 R58 & R59 models.
Part # 13712753078
http://www.ecstuning.com/Search/SiteSearch/13712753078/
thanks
Old Nov 18, 2014 | 02:36 PM
  #164
JCW_Coupe's Avatar
JCW_Coupe
scary looking piece..lol
Old Nov 18, 2014 | 05:36 PM
  #165
DneprDave's Avatar
DneprDave
I am keeping my noisemaker. It doesn't affect performance and I like the noise it makes.
Heck, people put cold air inlets on their cars all the time and all they do is make noise, with no added performance.
Dave
Old Nov 24, 2014 | 02:43 PM
  #166
yes it does.
Old Sep 11, 2015 | 04:24 PM
  #167
pepperwhiteknight
Old Sep 12, 2015 | 06:47 AM
  #168
Grizld700's Avatar
Grizld700
Interesting. I wonder how many other people have had that issue? I haven't read about it anywhere else. I wonder if you have somehting else going on. Was that area worked on recently?
Old Sep 12, 2015 | 05:47 PM
  #169
pepperwhiteknight
In March about 9000 miles ago the evap drain was cleaned and heater core replaced by the dealership. After that I have done oil change, air filter, cabin air filter, front and rear brake pads. The Manic stage 1 tune has been on since November 2014.
3 weeks ago I drove from Dallas to Los Angeles. A few days ago I was motoring on 118 heading west and heavy on the throttle above highway speeds the hose came off. It was 107 outside and I was on an uphill section of the road. I believe my driving style is very stressful to my car so... just sharing my experience.
The codes:
Fault: :Mass or Volume Air Flow “A” Circuit Range/Performance – Air Flow Too High- Code: P00BD
Fault: :Interface EWS-DME: Hardware error- Code: 0032E3
Fault: :Lambda probe after catalytic, electrical open circuit lines / Air Mass- Code: 002D22
Fault: :Engine cut off time / Cyclical monitoring Fehlerabspeicherung / unknown failure / Air mass plausibility: air mass too high / Misfiring in shifts- Code: 002774
Here are a couple of pictures of the failed hose. It just not as robust as the original hose with the noise maker. It just simply slipped off. Either it was damaged by the tech working on my car or it failed. I used the clamp on the new hose that is why it isn't in the picture. The left picture has the rubber gasket inserted into the plastic hose.
After replacing the hose the CEL turned off by itself. Did some data logging and everything seems normal.
Attached Thumbnails R56 Noisemaker Revealed!-2015-09-12-16.14.31.jpg   R56 Noisemaker Revealed!-2015-09-12-16.14.41.jpg
Old Sep 14, 2015 | 07:46 AM
  #170
Yea, first I have heard. Looks i little mangled on the plastic side from install or over-tightened the worm clamp from the tech is my guess.
Old Sep 14, 2015 | 09:08 AM
  #171
whrisk's Avatar
whrisk
i have the forge cold side hose kit, has any one tried to just put a pvc pipe in place of the y pipe? the forge hose comes with a metal piece that that attaches to the oem y pipe connector. so i think i can just get rid of the metal piece and plastic y pipe piece and be done with it.
my noise maker is actually broken, it bleeds boost and makes a farting noise every time i shut my car off. i think i will be the first to try it if no one has.
Old Sep 15, 2015 | 07:15 AM
  #172
Grizld700's Avatar
Grizld700
Are you sure its your noise maker making that noise? If you could describe the noise as a kazoo noise it may be your pressure converter.
Check this thread HERE.
Hopefully that helps identify the main issue at hand.
Old Sep 15, 2015 | 08:31 AM
  #173
whrisk's Avatar
whrisk
yes it does sound like a kazoo. thank for the info on that. i guess i will be getting one of those.
since that is the real problem, the noise maker has to come out to do it so its the perfect time to delete it.
Old Sep 15, 2015 | 08:47 AM
  #174
Grizld700's Avatar
Grizld700
When you take it out you can install either of these:
NM Engineering kit that I have
http://www.waymotorworks.com/nm-air-charge-pipe.html
or
The WMW new delete kit:
http://www.waymotorworks.com/wmw-noi...5-r56-r57.html
Old Sep 15, 2015 | 08:58 AM
  #175
whrisk's Avatar
whrisk
yeah i just ordered the WMW delete. didnt want to spend that much, but its on the boost side and i just dont want to worry about boost hoses slipping off the pvc pipe i would have put in.
