Drivetrain 130whp dyno results...
Old Sep 17, 2009 | 12:02 PM
mgwatson's Avatar
mgwatson
Hey guys, so I'm kinda surprised at these dyno results... mods on my car are: 15% pulley, Alta CAI, RMW header, RMW tune, and 2.5" ALTA catback. Can anyone tell me HOW my results are lower than stock after these mods? And also, what would be the next greatest mod for boosting power (apart from a new head)? Thanks!
Attached Thumbnails 130whp dyno results...-dynp-hp.bmp   130whp dyno results...-dyno-afr.bmp
Old Sep 17, 2009 | 12:11 PM
ninjlao's Avatar
ninjlao
Ninja Mini
What is your before and after? Do you live in a high altitude area?
Old Sep 17, 2009 | 12:12 PM
mgwatson's Avatar
mgwatson
well, before the header and tune, on the same dyno i ran exactly 130whp. So apparently I gained nothing from the header and tune
Old Sep 17, 2009 | 12:21 PM
Thumper460's Avatar
Thumper460
Ouch!! The next power boost...?? You need to get what you have corrected..yes?? You should be close to a 200-210 WHP with what you have.. A Head will pull it all together and allow more power..also a Camshaft, but I agree there is a LOT incorrect with what you have!!
See Link. Autoxcooper.com might be something there that will help on you gains.. AFTER you fix what you have now..cool??
Just me.............................
Thumper
Old Sep 17, 2009 | 12:24 PM
ninjlao's Avatar
ninjlao
Ninja Mini
My guess is the dyno isn't calibrated correctly? Isn't it pretty impossible to run two exact numbers on two different days? I thought the graphs people posted of their dynos was the highest reading of 3 pulls.
Old Sep 17, 2009 | 12:27 PM
newbs49's Avatar
newbs49
and we're off!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
mgwatson's Avatar
mgwatson
what about 380cc injectors?
Old Sep 17, 2009 | 12:37 PM
Oxybluecoop's Avatar
Oxybluecoop
Old Sep 17, 2009 | 12:50 PM
mdbsat's Avatar
mdbsat
You had this tuned AFTER all these mods I assume? I can imagine you are bummed. I am sure you will get this worked out and as long as you have fun driving your car you should be ok
Does seem real low. I do not know enough about Dynos to make any sort of hypothesis. This thread ought to be exciting.
Thread destruct in 5.....4......3.....2............
Old Sep 17, 2009 | 12:55 PM
mgwatson's Avatar
mgwatson
haha, yep, it was RMW tuned AFTER all the mods were intalled... 130whp
Old Sep 17, 2009 | 01:19 PM
SweetPeaBlue's Avatar
SweetPeaBlue
What are other MINIs making on this dyno? or some reference number to other cars b/c dyno numbers by themselves don't mean a whole lot. DD are lower-reading dyno's b/c they put a load on the vehicle similar to the Mustang Dyno's...
Nonetheless, 130 seems really low... especially with all your added parts, at least there should be some kind of 'delta'...
Questions:
- Is your car getting boost?
- Did your mechanic notice anything out of the ordinary?
- What did your tuner say about your car's lackluster performance? don't tell me 'bad gas'
- did u pay the full amt for the tune? is there a free retune once your stuff is fixed?
Not to put more damper on things, but that's the power of a 'non-S' so i'm going on a limp and assume that you're experiencing mechanical issues...
Just my 2 cents...
Old Sep 17, 2009 | 01:24 PM
mgwatson's Avatar
mgwatson
I've never officially checked if the car is getting boost, I just assume it is.
Mechanic never said anything bad about the car.
Jan said that 2003s were notorious for having bad maps out of the factory but he said he fixed it.
Old Sep 17, 2009 | 01:30 PM
thulchatt's Avatar
thulchatt
Have you checked for boost leaks?
mgwatson's Avatar
mgwatson
how do i do that?
Old Sep 17, 2009 | 02:15 PM
Chase's Avatar
Chase
have a compression test done too
i think that maybe the dyno wasnt calibrated
Old Sep 17, 2009 | 02:21 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
1) did your butt dyno tell you these mods added any power.... ?
2) If so, this dyno test was a bust, go somplace else for a second opinion before doing any more mods, then go back to the guy from this test and get your money back.....
Old Sep 17, 2009 | 02:23 PM
mgwatson's Avatar
mgwatson
It definately does feel faster but I still cant beat my friends IS 250 (204hp, soo about 164whp) and hes 800lbs heavier, leading me to think this dyno MIGHT be correct??? reading everyone elses charts I should be at like 190+whp...
Old Sep 17, 2009 | 02:31 PM
minimarks's Avatar
minimarks
Is this the dyno sheet that Jan did from the tune or was this a later dyno?
Old Sep 17, 2009 | 02:32 PM
mgwatson's Avatar
mgwatson
Later dyno when I got home, Jan didnt have time to dyno my car, he just street tuned it.
Old Sep 17, 2009 | 02:40 PM
SweetPeaBlue
so what are other cars putting down on this dyno? that would give a better idea of what the dyno is reading.
Old Sep 17, 2009 | 02:43 PM
mgwatson's Avatar
mgwatson
well, i saw an 135i with the M package put down 319whp and a 335i at 309whp..
Old Sep 17, 2009 | 02:46 PM
minimarks's Avatar
minimarks
Something must be wrong with the dyno, if the car was that far off Jan would have known it then.... Is the car running the same to your butt dyno now as it was when Jan finished?
Old Sep 17, 2009 | 02:53 PM
SweetPeaBlue
Those numbers are consistent so we know the dyno is reading right. My stock 335i did 270whp on a Mustang Dyno in AZ so those are realistic number....
mgwatson's Avatar
mgwatson
felt torquier but still.. my car should be able to RAPE my buddies IS250. this is sooo disheartening
Old Sep 17, 2009 | 02:56 PM
lanevomr's Avatar
lanevomr
i have a low dyno result too 150 whp untune.
my mods at the tune was
1. 15%
2. CAI
3. IK22 plugs
4. catback
all these with standard AUTO transmission. and dyno at 2nd gear of my car.
Now, do you have a AUTO or STICK , which gear was dyno took place? and how hot was the weather?
