Drivetrain shorter R&P for MCS?
Old Oct 26, 2003 | 11:27 PM
spdntckt's Avatar
spdntckt
Wondering if anybody is planning to make - or has already made - a shorter ratio Ring and Pinion for the MCS? Seems to me that the stock gearing is way too tall for the car.... this was also the case with my NSX (4.03) .. installing the shorter R&P (4.55) was the best mod i ever did (got the car into the 12s)
FWY milage might be compromised... but a worthwhile tradeoff i would think..
Old Oct 27, 2003 | 05:16 AM
eMINI's Avatar
eMINI
In my experience, changing the final drive can completely transform a car. I would not be surprised if an otherwise bone stock MCS thrashed JCWs and tuner cars w/ a 40-50 HP advantage. Throw in the right suspension and brake mods and you have a super reliable giant killer. Or, do it all and build a virtual super car.
So... This is a call to the tuning community. Please let us in on your plans. When can we have our numerically higher final drive?
Old Oct 27, 2003 | 08:46 AM
russko's Avatar
russko
Count me in.
Ever since the pulley mod I have been LUSTING after a limited slip diff, but I would hate to spend the $$ on all that labor only to find out a month later that some one offers higher ratio final gears.
example: The Subaru WRX STi redlines in THIRD gear at 75 mph!
Old Oct 27, 2003 | 09:06 AM
goin440's Avatar
goin440
I too think the right ratio would better the MCS and know of several autoxers who would agree.
What does the MCS rev out at?
_________________
-goin440 IB/IB MC
Old Oct 27, 2003 | 10:22 AM
Antranik's Avatar
Antranik
I remember reading somewhere on the boards a long, long time ago that a future LSD will also have different gearing for this purpose.
MCS finishes 3rd in 90 (2nd=70, 1=40), numbers vary marginally by upgraded ecu redline and diff tire sizes.
Old Oct 27, 2003 | 10:51 AM
ubercooper's Avatar
ubercooper
This the exact mod I have been waiting to do, if there is one thing this engine needs is a better final drive to mulitple the torque. It would totally make up for the lack of low end grunt.
Old Oct 27, 2003 | 11:58 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
The MCS has two final drives in the Getrag 6-speed. There are really only 4 forward gears, but through the combination with two different final drives, we end up with 6-speeds. Theoretically, we could have an 8 speed, but the extra gears would be ludicrously low. See this page for more info:
http://www.mini2.com/forum/faq.php?f...ansmission_faq
Old Oct 27, 2003 | 12:44 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Hey, I think the theoretical 16.88 lo-1st gear would be sweet for getting off the line in a hurry (or rock crawling!
Old Oct 27, 2003 | 03:00 PM
MSFITOY's Avatar
MSFITOY
Try this... http://www.quaife.co.uk/catalogue/download/41-42.pdf
That's the way to go
Anyone know how much this cost and what a "dog engagement" is?
_________________
Old Oct 27, 2003 | 11:56 PM
spdntckt's Avatar
spdntckt
Hmm. thanks guys for all the info.. interesting tidbit on the transmission. Ive never seen a design like that before. I guess to do a lower ratio final drive you might need to change two ring and pinions.. might be a bit pricy (I imagine those gears aren't cheap.. and probably also a bit more complicated to do.. changing the R&P in a honda is fairly straightforward if you have ever broken a tranny open...)
Old Oct 28, 2003 | 05:42 AM
paulmon's Avatar
paulmon
>>_________________
Dog engagement means no synchro. This isn't something you'd want for street driving, heck unless you're a master at shifting you wouldn't want this at all. Without the syncro you're literaly banging each gear in, this doesn't do much for the longevity of the gear box. That being said a "Dog Box" in the hands of a pro will be faster than a box with synchros, but in the hands of an amature would be painful.
I remember seeing an article on this a while back....Hang on, googling....<insert hold music here>....Ah ha! Check out:
http://www.minispares.com/ms/GEARBOX...ngagement_.htm
Paul
Old Oct 28, 2003 | 12:22 PM
fueledbymetal's Avatar
fueledbymetal
It appears Dinan is working on this (mentioned at the bottom of the page)
Old Oct 28, 2003 | 12:37 PM
MSFITOY's Avatar
MSFITOY
Oh yaaah...I remember those. Used to drive 10 speed semis for a short while. Double clutchn all the time. Hate it when I miss the match half way down. Usually means coming to a complete stop to start over
But, motorcycle gearboxes, I could up shift without the use of the clutch to matching delay timing....just lift off gas slightly between shifts and in it goes. Lots a fun
That's we learned heal/toe...absolutely nessesary for down shifting dog gears.
_________________
wildwestrider
Dec 27, 2015 08:20 PM
COOPT UP
Sep 11, 2015 04:59 AM
schwac2
Sep 10, 2015 07:24 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
