Drivetrain New RMW meth trunk kit mounting "cover"
Old May 19, 2009 | 10:35 PM
Longboard Mini's Avatar
Longboard Mini
Well for those that saw my last trunk set up in the raw here is the new set up all texture coated to match the trunk. The old mounting plate left the top exposed showing the tank and the pump. This new set up covers the top cleaning things up even more. The texture coat really looks cool and lets it blend right into the boot
Longboard
Old May 19, 2009 | 10:40 PM
Revolution Mini Works's Avatar
Looks great as usual
now get it to Buttonwillow
Old May 19, 2009 | 10:43 PM
ThumperMCS's Avatar
ThumperMCS
Nice Bryan!
Does the pretty cover mean you have even more horsepower now??
Old May 20, 2009 | 09:57 AM
DarrenO'sideCA's Avatar
DarrenO'sideCA
Come on Bryan! You know red is a faster color. You probably could have gotten one or two more horses if it were.
BTW, it does really make it clean looking.
Old May 20, 2009 | 12:48 PM
craigsmiller's Avatar
craigsmiller
Very classy looking, Bryan. Any data on methanol consumption yet? Does the methanol cool the charge at the IC internally (and is burned as fuel) or externally (and is evaporated)? Is it on all the time or only on with boost?
Old May 20, 2009 | 11:06 PM
Longboard Mini
Well hey Mr. Miller .
I'm running a one gallon tank. I'm getting about one gallon to every two fill ups depending on how hard I drive the car. The system runs off injector duty cycle and only starts spraying when it needs to. I spray directly into my intake manifold which both cools the charged air and burns as fuel adding HP.
LB
Old May 21, 2009 | 08:03 AM
curv872's Avatar
curv872
Looks good, you should add a window slit on the side so you check the fluid level at a glance.
Old May 21, 2009 | 08:37 AM
//MZero's Avatar
//MZero
It keeps looking better and better, but I'd still rather see using the headlight washer tank
Old May 21, 2009 | 10:45 AM
Longboard Mini
That's a great idea . I have a light on the gauge but I like your idea as well.
Longboard
Old May 21, 2009 | 10:48 AM
Longboard Mini
It has been done using this system. They actually connected both tanks. The pump was in the cowl next to the ABS.
Longboard
Old May 21, 2009 | 11:08 AM
blackX5's Avatar
blackX5
looks really clean man!
Old May 21, 2009 | 11:38 AM
newbs49's Avatar
newbs49
LB is it OK to comment here!!!!!!!!!!!!!!!!!!!!!!
Very nice setup. Get that thing to the track. I want to know how much meth you use there. Nice job as always.
Old May 21, 2009 | 12:29 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Longboard
I've been thinking about connecting both tanks in my system. I'm curious - do you know if whoever did this (a) actually tied the tanks together across the bottom, to make effectively one bigger tank or (b) ran feeds from the pump to both tanks - drawing from the two tanks in parallel?
Old May 21, 2009 | 02:24 PM
Longboard Mini
Hey Blimey,
To my understanding they tied the two tanks together making effectively one large tank. Sound like a cool idea.
Longboard
Old May 21, 2009 | 07:21 PM
BlimeyCabrio
Yep - I traded PMs with Jeff and he gave me the details. Thanks!
Old May 21, 2009 | 07:37 PM
craigsmiller
So why methanol and not ethanol? Is the performance enhancement that much better? With ethanol being routinely added to gasoline, I would think that ethanol availability and cost would be considerations. Is methanol readily available? Has anyone looked at the possible problems with methanol attacking seals, gaskets and such? Are there any seals or gaskets that the methanol comes in contact with? Curious ....
Old May 21, 2009 | 08:47 PM
big howe's Avatar
big howe
In short, methanol is more readily available, cheaper in the small quantities used in this type of application, and most of all cools much better than ethanol. Folks have been know to use methanol, ethanol, de-natured alcohol and other products. Each has it's pro's and con's, methanol evolving to the one used most in these applications.
Methanol is usually available where ever race gas is sold. Many speed shops, motorcycle/jet ski/boats shops etc. If you buy it mixed, you can even mail order it in.
The way the fluid is injected into the engine, it usually goes straight into the intake track and then into the cylinder. In light concentrations and usage it would generally pose no problems. In race engines that run on 100% methanol( no gasoline) the cylinder walls can get washed and cause excessive wear, so top-end lubricants are added to the methanol. In secondary injection systems it is generally preferred to use 99.9% pure methanol, but some systems are more tolerant to impurities than others.
Yes, methanol is a dangerous substance, you should avoid getting it on your skin and treat it as a hazardous substance.....but then again so is gasoline and many other items we deal with everyday. Hell, too much water will kill you but that's another story........
Old May 21, 2009 | 09:21 PM
Longboard Mini
Thanks for education Mr. Wizard .
I re-mounted my high speed valve to a little better location. It's now screwed onto the ECU cover. The hose no longer hit the hood Jeff .
Old May 21, 2009 | 09:29 PM
big howe's Avatar
big howe
Looks like it's meant to be there. You just need to add the second nozzle now and up the ante a bit. There's more power in it.
Old May 22, 2009 | 05:17 AM
newbs49's Avatar
newbs49
Damn LB
Theres a mark on your strut bar!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 22, 2009 | 06:06 AM
BlimeyCabrio
Yep. That car has totally gone to crap.
Old Aug 18, 2009 | 08:14 AM
Moh's Avatar
Moh
Would Really like to Install This Unit On My Mini
Very Interested in your Trunk set up design, Longboard Mini, Can we get one to Las Vegas?
Old Aug 18, 2009 | 08:58 AM
Longboard Mini
Call RMW (Jan) for one. With you living a LV it's the best mod you will could ever add to your car.
Here is the new cover with LED back lighting so you can see the fuel level.
Old Aug 18, 2009 | 09:21 AM
newbs49's Avatar
newbs49
LOOKS LIKE MOOD LIGHTING TO ME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Again you come up with another first.
Old Aug 18, 2009 | 09:23 AM
actually Jeff did it
