Long end of it is that each track has it's own requirements. Exactly the same as how they treat it for using Nitrous, convertibles, and meth injection on the One Lap of America.
I have ordered mine RMW Meth kit from Jeff, I had great comunication with him . LB What is the level of fuild do you put? for example 50% meth and 50% water or .... . I hope Jan do the tune for me.
It looks like you're not using your rear seat so why not remove the seat belts, mounts and anchors.....
Jeremy
Because I expect that stuff to go back in at a moments notice. I miss driving it on the street. 2 Bolts, on the harness bar, 4 bolts on the passanger seat, 8 bolts on the driver seat (remove and replace) and clip the rear seat back in and this thing is back to full interior.
I will be running braided lines front to rear. Probably tonight.
The tank isn't all that big, the actual tank fits down in the battery hole. What you see is the cover sealing everything off, What's underneath is a smaller battery, Tank, and pump and lines.
