Drivetrain Camshaft Re-Grind
Old Sep 21, 2009 | 09:52 AM
  #426
Thumper460's Avatar
Thumper460
Originally Posted by jhiggs26
So Thumper what cam did you MINI love in the FL heat?
In the JCW injector/flash thread you mentioned going back to stock injection. Are you running your cammed MINI with stock map and/or stock fuel injectors now?
Jeremy
Yep!! ( Snow Performance water/meth keeps it right in the sweet spot!!)
Naz.. it has the +.5mm int and +1.0mm exh. Keeps a lot of the lowend.. and still screams to the 7500-7800 shift points!!
Just me...................................
Thumper
Old Sep 21, 2009 | 10:36 AM
  #427
Nazrin's Avatar
Nazrin
Jeremy
Bets are on...
I say the Crower/NS cam regrind
Old Sep 21, 2009 | 10:59 AM
  #428
jhiggs26's Avatar
jhiggs26
Thumper
Are you turning the stock cam too then? I don't see your sig updated.
I want to see your spark plugs in a 100 miles too.
Jeremy
Old Sep 21, 2009 | 11:03 AM
  #429
#Dragon#'s Avatar
#Dragon#
Any news Thumper.
Old Sep 21, 2009 | 01:55 PM
  #430
Thumper460's Avatar
Thumper460
Jeremy
????? I have over 2500 miles on the advanced cam.. ran the Dragon on the stock advanced cam, and the PLUGS are totally fine!! I changed them prior the the Dyno run this weekend. Only because I dont like to spend time and then find out I have a misfire due to a $2.50 part, I was going to put them back in, but I am a bit lazy vs the cost of a new set later.. I would show you pictures, however I left my camera in England..
My sig???
Thumper
PS I will start a different thread on my results...
Old Sep 21, 2009 | 06:27 PM
  #431
jhiggs26's Avatar
jhiggs26
I remember you were toying around with a vernier cam gear awhile back Thumper. We NAMers will wait for your results thread patiently.
Jeremy
Old Sep 22, 2009 | 02:38 PM
  #432
Longboard Mini's Avatar
Longboard Mini
Jeremy
Well you can find some interesting results here:
http://www.minitorque.com/forum/f24/...69/index5.html
You with your Shcrick will be really interested.
LB
Old Sep 22, 2009 | 02:43 PM
  #433
Thumper460's Avatar
Thumper460
LB
That is a good referance to an issue with the NS2 cam.. I am trying to see what the story is.. all I can say is...HHHMMMmmmmm....
LOL
Just me.....................................
Thumper
Old Sep 22, 2009 | 04:00 PM
  #434
jhiggs26's Avatar
jhiggs26
Ok I'll check it out Bryan. Thanks!
Jeremy
Old Sep 22, 2009 | 10:35 PM
  #435
Nazrin's Avatar
Nazrin
dats the first unfavourable review of the NS cam series....maybe need investigation as most NS2 owners reports it yields performance, performance, performance
Old Apr 20, 2010 | 03:52 AM
  #436
JCWGrover's Avatar
JCWGrover
OMG, I just read all 437 posts in this thread, yet no where does it actually show a source, or price, for a crower re-grind. WTH??
Old Apr 20, 2010 | 05:19 AM
  #437
cct1's Avatar
cct1
Google Werkin, you can get them there...
Old Apr 20, 2010 | 12:41 PM
  #438
goin440's Avatar
goin440
the "crower" also goes by the name of "NS1" and "NS2" - acronymn for something I don't recall anymore
Link should be in here somewheres.
Old Apr 20, 2010 | 12:54 PM
  #439
mdbsat's Avatar
mdbsat
Here you go. I had to use google, man it was so hard. Hope that helps.
Old Apr 20, 2010 | 09:17 PM
  #440
JCWGrover's Avatar
JCWGrover
that shows a base price of $265, not including a corecharge, Crower charges $130 or so to do a straight regrind of a cam, so what is the difference between them? Are Werkins PTFE coated or something?
Old Apr 21, 2010 | 10:33 AM
  #441
Dr Obnxs's Avatar
Dr Obnxs
They are available from several people
Werkin Mini - http://www.werkinmini.com/
Detroit Tuned - http://www.detroittuned.com/shop/
Mynes Performance
Thumper Performance - http://www.thumperheads.com/
Call your supplier of choice, and talk to them about price and the like.
The NS cams will shortly be available at more outlets as well.
And for those that want to go direct to Crower. Yes, you can get a basic regrind from Crower for not much money. The NS1 and NS2 grinds cannot be bought directly from Crower. If you call them to order one, they will direct you elsewhere. These grinds are proprietary.
Matt
Old Apr 21, 2010 | 03:39 PM
  #442
JCWGrover's Avatar
JCWGrover
I had originally posted to this thread interested in the Crower/NS, but now after re- reading the thread, and all the PM's I received, I realize that most just seem more interested in arguing than anything else. Thanks to those of you who did actually send me info.
The one post in the whole thread that now stands out to me is this,
Originally Posted by mdbsat
When are YOU making or designing your own cam? I mean not simply buying cams from Newman and calling them RMW cams and charging a %50 markup? It still cracks me up when someone says I have an rmw cam
How is this Crower/NS any different? Cam regrinding has been around forever, what the hell is so proprietary that it justifies a 100% markup?
Old Apr 21, 2010 | 03:46 PM
  #443
Revolution Mini Works's Avatar
I had originally posted to this thread interested in the Crower/NS, but now after re- reading the thread, and all the PM's I received, I realize that most just seem more interesting in arguing than anything else. Thanks to those of you how did actually send me info.
you can get a stock cam reground for $50
everyone can now tell me who's making money?
and that cam "reground" will NEVER have the lift or performance of a base Newman
I have all of the data on the NS cam
I'll start a cam thread when we have time around here so people can see the truth about the camshafts
Old Apr 21, 2010 | 07:19 PM
  #444
Dr Obnxs's Avatar
Dr Obnxs
You can also get NS cams
from Way Motor Works.....
Matt
Old Apr 21, 2010 | 10:33 PM
  #445
JIMINNI's Avatar
JIMINNI
So if you put out a statement like this we all need to see your background in engine component design or are you just quoting what other people and your cam supplier are telling you? If you understood how the base circle and the lob lift are in relationship, you might not be making these colorful claims about regrind camshafts. May I recommend calling Newman cam's about cam design? In having personally talked to and met the designer of the NS series cams and having talked to the co-designer and maker of the NS cams, Dave Crower of Crower cams, I will definitely believe what they say. It may be possible to get Dave Crower to make a statement here? I can find out. Do you think we can get Dave Newman to make a statement here? That would be cool Here is an interesting statement right off of the Newman cam website,
" Be conservative! Don’t over-cam your engine. Choose your cam for the correct application. Consider! Fit a milder cam and increase
your power by 10 BHP at 3500 rpm."
Wow so Dave is saying to go "conservative"...hmmm
Oh and about, "I have all of the data on the NS cam", most reputable cam companies provide cam cards and are not afraid of what they sell.
And it's unfortunate that if you do start a thread on cam design, that the original designer of the NS series cams can not participate in the discussion, so there would only be one side of the story told
And the $50. regrind price....everyone knows that, yes you can get a "reground...refurbished", OEM spec camshaft from parts house's, but these are NOT performance cams, they are just cams that have been cleaned up and resold. No special or performance grinds.
Old Apr 21, 2010 | 11:00 PM
  #446
JCWGrover's Avatar
JCWGrover
Originally Posted by JIMINNI
And the $50. regrind price....everyone knows that, yes you can get a "reground...refurbished", OEM spec camshaft from parts house's, but these are NOT performance cams, they are just STOCK cams that have been cleaned up and resold. No special or performance grinds.
You are mistaken there. I've built numerous (V8) engines thru the years, and performance cams can be purchased OUTRIGHT thru-out the $50 to $150 dollar range, Even the pricier brands don't go over $200. So I ask, in all honesty, what exactly is so special about the MINI cam, be it Crower regrind, Newman, RMW, Schrick etc. that they have such a premium? Is there really that much difference in manufacturing and grinding of an OH cam vs a pushrod type?
What was the first sentence in this thread anyway?
Originally Posted by k-huevo
These are times of austerity for some of us; performance gain per dollar spent must start with fewest dollars spent from the get-go.
Old Apr 22, 2010 | 07:44 AM
  #447
JIMINNI's Avatar
JIMINNI
Obviously you have not been in the Mini performance scene very long? This has always been eye opening to non Mini people coming over from either the domestic or the Asian side of performance the market. The Mini market is VERY SMALL compared to these two markets, so almost everything is expensive in comparison. Unfortunately you can't just call Jegs..ect to get parts, most of the time you will need to go thru a Mini specific dealer, but there are a few parts you may find that you don't, but not many. If you want to play, you gotta pay....
Old Apr 22, 2010 | 08:46 AM
  #448
Dr Obnxs's Avatar
Dr Obnxs
You can also buy NS cams
at Custom Mini Shop - http://www.customminishop.com/
Matt
Old Apr 22, 2010 | 08:50 AM
  #449
Longboard Mini
Matt
Don't you have them on your website Matt?
Side note: I can not get my shift light to work . Do you take calls around 6pm?
Longboard
Old Apr 22, 2010 | 09:00 AM
  #450
Thumper460's Avatar
Thumper460
SOOoo......
the Nirtostick cams are a re-grind of the OEM cam! Correct!!
The Nitrostick cams are below the spec of the Newman/ schrick cams! Correct!!
The cost of the Nitrostick cam is less than the Newman!! Correct!!
If you are NOT a full on Racer, or a person that isnt into the 7500 shift changes, and drives mostly on the streets... the small spec ( grinds) of the two Nitrostick Cams are the future!! They power sooner!! Their mid range is stronger!! And the topend power is slipping away at 6800-7200 revs, as to where the Newman and the others will pull some more ponies up at those revs!!
r50s have been impressed with the power of the NS1 with no tuning issues !!
Add a ported Head and the NS1 or even the NS2 to the r50s and the power is even greater!! Again with NO tune!! ( although we all know the TUNE is a major key with any mod!!)
Now add the SC and again... good solid power gains!! Still very street friendly and yet very strong for the twisties or the occasional Track day!!
The grinds ( spec) are different!! the power levels are different!! the cost is different.... it is just another option for us drivers!! Quality?? it IS A BMW Core camshaft, and designed and cut by ONE of the BEST well known Cam grinders in the US!! Yikes... how difficult is that??
Thumper
