Drivetrain MegaMynes Header Dyno Results
Old Apr 27, 2009 | 04:19 PM
Mike@Mynes's Avatar
Mike@Mynes
Well, we took the MegaMynes Straight header off the 06 MCS and threw it back on the dyno, and here are the results:
Swapped the STOCK header in place of the MM Header, car LOST 10WHP & 8WTQE.
The tune of the car was not touched at all; all we did was removed the MM Header, installed the stock header, and strapped it back on the dyno. Temperature was actually about 20-degrees F cooler today than it was fours days ago. Car is running on 91 Octane with 15% pulley, MegaMini Cam shaft (Hubie1), 550cc Bosch Injectors and Invidia CAT-Back Exhaust.
Stock header = Solid lines
MegaMynes header = Dotted lines
Back when we first installed the MM Straight header, the gain was +9WHP & +9WTQE... So the delta of the header removal is within +/- 1 WHP/WTQE, which is within the margin of error. Original post listed below... The gains were obtained while running E85, but the DELTA was the same no matter what gas we're running - which is something we've been saying all along
https://www.northamericanmotoring.co...ur-mcs-20.html
Old Apr 27, 2009 | 04:35 PM
ED955S's Avatar
ED955S
I'll find that out using my butt dyno on Friday. 9 whp & wtq in Mustang Dyno and almost across the rpm is indeed very good.
Old Apr 27, 2009 | 05:56 PM
JIMINNI's Avatar
JIMINNI
How many decibels also were lost?
Old Apr 27, 2009 | 09:26 PM
Mike@Mynes's Avatar
Mike@Mynes
I'd say at least 10dbs... but with that loss, i also lost the quick throttle response of the MM header.
On a side note, this was the first time i got to drive the Mini home after the MM Cam (Hubie1) installation; boi, this things pulls a lot harder than the Newman where the Newman tappers off at 6500rpm, the MM cam just keep pulling until i upshift... if you let it, this cam will pull all the way thru 7500 it was soo smooth i didn't even know i had hit 7500
Ewwww, with the MM BVH, the MegaMynes stepped header and this cam... that's going to be one SICK combo
Old Apr 27, 2009 | 09:30 PM
JIMINNI's Avatar
JIMINNI
Hopefully in a few weeks I will let you know how my combo works out
Old Apr 27, 2009 | 09:56 PM
Fracky's Avatar
Fracky
Transwarp - Warp 10.0
Niiiice. Good lookin' out Mike & I'm psyched to get the MM stepped-header on my FPD.
Old Apr 28, 2009 | 10:52 AM
Luys's Avatar
Luys
Is the car tuneed after the header or with orijinal tune?
Old Apr 28, 2009 | 11:12 AM
Mike@Mynes's Avatar
Mike@Mynes
Answer below...
Old Apr 28, 2009 | 05:32 PM
Mini_Joe's Avatar
Mini_Joe
Very nice!
Now, to really be impressive... can you folks find a way to alter the shift points on the Aisin 6-speed auto, to take advantage of all that space up north of 6700?
JaysinStrife
Jun 3, 2016 09:19 AM
slash695
Apr 26, 2016 06:27 AM
Vaderm34
Sep 27, 2015 09:25 PM
Sep 18, 2015 02:44 PM
Mb460
Sep 14, 2015 05:50 AM
