Drivetrain HKS SSQV Blow Off Valve
Old Apr 4, 2009 | 09:16 AM
AutobahnRat's Avatar
AutobahnRat
Hi I fit a HKS SSQV to my r56 cooper s , Will it make me loose power or have any negative effects? would it need specific custom tuning? Thanks
Old Apr 4, 2009 | 10:02 AM
Exhaust Depot's Avatar
Exhaust Depot
From: Orlando, my house is in fortlauderdale and im originally from da bronx
I know on the 07-08 i have not scene any ill effect with it on except the turbo recovering sooner after the shift.
Old Apr 5, 2009 | 02:57 AM
danielo's Avatar
danielo
Our MINI's OEM blow off vents the air back into the system, venting it into the atmosphere sounds 'wrong' esp when there is nothing to cater for that change.
Old Apr 5, 2009 | 06:53 AM
a96bimmerm3's Avatar
a96bimmerm3
Every turbo car sold in the US has to be a closed system. The HKS valves react very fast and shouldn't have any ill effects. Had one on my gti (much more maf based than I suspect the mini is) and never had a problem.
Old Apr 5, 2009 | 07:33 AM
JAceMin's Avatar
JAceMin
This has been gone over ad nausea, adding a BOV while at stock conditions does not cause any serious issues, at higher boost the engine does not enjoy it, it will cause problems.
There seriously is no reason to do it, unless you are changing out the turbo, and retuning.
Old Apr 5, 2009 | 08:22 AM
a96bimmerm3
Yep, the stock dv is fine. If you want the noise, get an intake. Same thing, no downsides.
Old Apr 5, 2009 | 11:01 AM
dtsoccer6's Avatar
dtsoccer6
I guess the only ill effect would be wasting the money
Old Apr 6, 2009 | 09:58 AM
DNadar's Avatar
DNadar
if you think that getting an intake will give you the same noise as an HKS SSQV, i'm guessing you've never heard a car with one. It is sex to my ears.
Old Apr 6, 2009 | 10:03 AM
a96bimmerm3
If you think sex to your ears sounds like a bird being castrated everytime you shift. I had one for quite some time... it wears on you.
Old Apr 8, 2009 | 07:47 AM
apudapus's Avatar
apudapus
I've installed BOVs on my Z and on my friend's cars. It sounds "cool" but the car doesn't drive as smooth anymore. My Z has been on the stock recirculation valves for a few years now and my friend went back to his recircs, too.
The old Apex'i SAFC-II air-flow converter has a deceleration setting to adjust the MAF to compensate for a BOV. This option is limited though since it adjusts the MAF setting at a particular RPM point and is not based on boost pressure change.
olson187
Oct 21, 2015 05:25 AM
honderpilot
Oct 11, 2015 06:35 AM
Fordgt4
Oct 10, 2015 10:42 AM
Southern Marylander
Oct 1, 2015 07:53 AM
Nicefeet
Sep 24, 2015 06:53 PM
