Drivetrain GT 28 RS in the MINI up and running
Old Apr 1, 2009 | 04:38 PM
mtuning3's Avatar
mtuning3
Old Apr 1, 2009 | 05:26 PM
old81's Avatar
old81
M6
So how much does this push in HP?
Saw your comment about having to cut the hood in another thread, internal bracing, open a hole? Pictures?
Old Apr 1, 2009 | 06:27 PM
Partsman's Avatar
Partsman
Legion_of_Doom
That's a nice looking setup!
How does it run? Does it trip any lights? Have you wound it up at all yet? How much more boost than stock?
Sorry for all the questions...you can't just post those pics without posting some info.
Old Apr 1, 2009 | 06:30 PM
iwashmycar's Avatar
iwashmycar
in
Old Apr 1, 2009 | 06:43 PM
fernflex's Avatar
fernflex
Is that on the right side a manual boost controller?
Wheres does the tube coming out from the valve cover connects?
It looks nice!!
Old Apr 1, 2009 | 06:52 PM
richi0207's Avatar
richi0207
Is that what solves the melting hood scoop problem?
Old Apr 1, 2009 | 06:54 PM
ThumperMCS's Avatar
ThumperMCS
Looks AWESOME!
But can you expand more on the "up and running" part???
Old Apr 1, 2009 | 06:57 PM
richi0207's Avatar
richi0207
Originally Posted by ThumperMCS
Looks AWESOME!
Its an April Fools joke.
Old Apr 1, 2009 | 07:06 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Doesn't look like a joke to me. It appears to be actually installed and functional.
Old Apr 1, 2009 | 07:09 PM
mtuning3's Avatar
mtuning3
right now im waiting for the tune im running only 8 psi on it, no check light yet,its an atp kit but you better off just buying the turbo and the adaptator plate ,because nothing fits!!!!!u have to make your own intake,but the car pulls verry strong ,the differance is 500 rpm in spool up time witch is nothing the gt 28 rs is great turbooh an you have to cut the inside of your hood
Old Apr 1, 2009 | 07:13 PM
Exhaust Depot's Avatar
Exhaust Depot
From: Orlando, my house is in fortlauderdale and im originally from da bronx
BERRY NICE!
A nice tune and your good to go.
Old Apr 1, 2009 | 07:17 PM
Ryephile's Avatar
Ryephile
The setup looks like a great start! I'll give those copper nuts 1 week before they loosen and they come off for stainless castle lock nuts and stainless studs. Keeping thermal expansion coefficients matching is critical to reliable longevity.
Are you using a traditional boosted open/sprung closed wastegate and pressure delta blow-off valve setup?
I can't believe there's no CEL yet! I'd think first time you'd go on-boost the fact the ECU can't control the boost or diverter valve would cause an instant limp-home mode, but it appears the ECU is dumber than we thought. Please keep us updated on how the ECU reacts.
Cheers,
Ryan
Old Apr 1, 2009 | 07:20 PM
mtuning3's Avatar
mtuning3
yes i do,well if you the same amount of boost or a little less the ecu is going to be fine ,but a check light will pop up soon for the dv im sure i less the stock one connected for now
Old Apr 1, 2009 | 07:23 PM
AkFarina's Avatar
AkFarina
pics of the hood closed? maybe a vid
Old Apr 1, 2009 | 07:32 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Ouch...any pics of that?
Kinda sucks that the ATP kit fits so poorly.
The Alta upgraded turbo setup appears to be roughly in the same location...
https://www.northamericanmotoring.co...5-post487.html
...which would probably also require some trimming of the underside of the hood. I wonder what's going on with their setup.
Maybe a custom manifold to place the turbo a little lower?
Old Apr 1, 2009 | 07:34 PM
Oxybluecoop's Avatar
Oxybluecoop
{YouTube}insert video here{YouTube}
Old Apr 1, 2009 | 07:36 PM
M3This's Avatar
M3This
Subscribed
Old Apr 1, 2009 | 07:42 PM
mtuning3's Avatar
mtuning3
alta is using a smaller turbo but i dont know about there fit,the max they can pull is 280 at the wheel,the gt 28 rs with an f1 trim will spool faster i make 375 hp at the wheel ,im puttlng bigger injector in ,and a 3 inch mass air flow sensor,and hope about 2 weeks for the tune,its not to bad what you need to cut for the hood coulded be worst !!!!but the kit is not a great fit at all
Old Apr 1, 2009 | 07:44 PM
AkFarina's Avatar
AkFarina
you really need to get forged pistons, rods, crank, all the stock ones are cast
Old Apr 1, 2009 | 07:54 PM
mtuning3's Avatar
mtuning3
the engine will take 350 hp ,the rods and crank are forged so are the pistons that why that engine makes so much noise when its cold
Old Apr 1, 2009 | 07:57 PM
AkFarina's Avatar
AkFarina
ive seen the pistons and rods you can c the line where they pull the mold apart. but that would explain the noise
Old Apr 1, 2009 | 08:32 PM
richi0207's Avatar
richi0207
375whp on stock prince engine? I gotta see that dyno! That would be very impressive if it can pull around that number and still be reliable.
Old Apr 1, 2009 | 08:33 PM
a96bimmerm3's Avatar
a96bimmerm3
No, a 28rs will not make 375whp... Good luck getting to the low 300s. What injectors are you putting in, I hope they're FSI ones this time... And you still wont answer how you know the stock injectors will be maxed out, there are no tunes yet so we don't know IDCs!
And forged rods and pistons have nothing to do with the noise on idle. The FSI injectors are really loud anyway, more likely that and a slight lack of oil to the head when cold.
Don't hate on cast parts, forged isn't necessarily necessary. People going 9s on VW AEG cranks that are cast. Supras have cast pistons. 1.8ts have cast pistons and there are several people in the 600whp range with oem pistons.
Old Apr 1, 2009 | 08:39 PM
richi0207's Avatar
richi0207
Nicely said Josh!
Old Apr 1, 2009 | 09:20 PM
scott48's Avatar
scott48
sweet setup!!!....how you gonna tune?
