Drivetrain Hard time shifting into 2nd at WOT/redline
Since I have started making a little bit more power - I am having a hard time (read: Impossible) getting into second gear when coming from first at redline. I have a TSW engine damper already, so not sure what the next step would be.
Cheers
Cheers
Probably not related at all to the damper. Stock clutch? How many miles? Have you had the slave replaced yet? My suspicion would be worn clutch or a slave that is failing. More ominous causes could be a failing syncro.....
I would highly advise against that as that has the potential to destroy your clutch.....
The initial shift isn't slamming, but it is quick and thorough to the correct location. It is almost like it locks me out of the gear.
ive been having that probem a bit too now... id like to know, you can force it into second, but it almost seems to have a barrier at the gate, or if it does "go in" the shifter doesn't feel like it is always into gear, so ive never let the clutch out when this happens. mine is happening randomly though, not just in high rpm's, but only 1st to second gear shift. im hoping getting fluids changed will help, btu if now i fuess its time to look into other stuff :(. im at 76k miles though...
I had the same issue, exact same thing. You need to change your technique and things will work out. Try to guide it into place not slam it. The issue you are having is unconsciously pulling the shifter back and slighty to the left and on the verge of the reverse area.
I just asked a question - since you stated something that I didn't know. No need to roll eyes.
Your explanation is interesting and I've never heard of that.
What happens to vehicles that do not have as close of ratios in their gear boxes as our? The 1-3 shift in a Mini might be the same as something like a 1-2 shift in a Ford mustang.
Hate to bring bad news, but balkiness in a fast 1st-2nd shift is often the sign of failing synchros. And they typically fail because folks hurry this shift. Best shifting technique is to apply easy pressure to the 2nd gate and let the synchros do their thing without hurrying them. Speed shifting eventually takes its toll in accelerated gearbox wear.
2nd gear is the usually the one to go first because RPMs are higher and people are more likely at full throttle.
- Mark
- Mark
Now if you are going from WOT to ideal and releasing the clutch it certainly is going to load the flywheel and the clutch significantly, but who does that? Rev matching is clearly a requirement of high speed or high stress shifting and as the revs will be lower in 3rd the specific load will be less, so it isn't as if you need to rev to 7200rpm to load match......curious
It also does no good to wait to shift at redline, the proper shift point would be determined by the tq of the engine. And for a MINI that first gear shift point would be about 6500.
See DrO's post about his new shift light. He explains it and even has pic's.
Colt45Magnus
Aug 12, 2015 06:43 AM
