Drivetrain MC-S Top-End Torque Specs
Old Mar 22, 2009 | 07:01 AM
civilwarhero's Avatar
civilwarhero
What are the torque specs for the S's cylinder head and cam gear?
Also, having seen the recommended procedure for aligning the crank/cam gear (via timing cover removal); is there a more sensible (re: old-fashioned way) OF aligning the TDC mark on the crankshaft pulley?
Thank you!
Old Mar 22, 2009 | 07:39 AM
lhoboy's Avatar
lhoboy
cam gear 75 ft-lb 102 nm
10 headbolts 30 ft-lb 40 nm
2 cyl.head to timing cover bolts 21 ft-lb 28 nm
Old Mar 22, 2009 | 07:46 AM
jhiggs26's Avatar
jhiggs26
Check your Mini Mania message board thread Civilwarhero.
Jeremy
Old Mar 22, 2009 | 07:52 AM
jhiggs26's Avatar
jhiggs26
Just rotate crank pulley bolt untill triangle on cam sprocket is at 12 o'clock in relation to cylinder head not the ground. Then bust off the cam sprocket bolt.
Jeremy
Old Mar 22, 2009 | 09:32 AM
civilwarhero
Jeremy,
That's great intel--thanks for posting...on BOTH sites.
I'm in more of a bind w/regard to the cam though: I'd already DISassembled w/o knowing about the "mark the chain" technique. Stupid me...how do you set timing on a car w/o external timing marks, right? Needless to say, I now (seem) to have no way of determining TDC, then setting the cam shaft/gear accordingly.
I did notice a small orange circle on the crank pulley though...is there a way to line them up that way?
Old Mar 22, 2009 | 12:18 PM
jhiggs26's Avatar
jhiggs26
If I were in your shoes I'd remove plugs rotate crank pulley(only after you've popped on cam sprocket and timing chain-your timing chain should still be on crank sprocket) until #1 is at TDC bolt up everything up with the intake lobes not touching rocker arm followers. Re-engage tensioner with breaker bar and rotate crank pulley(remember only after timing chain is engaged with crank and cam sprockets) to see how the valves are moving in relation to each piston. Have somebody else rotate the pulley slowly so you can see what's happening with each cyl and valves. That's the best you can do I figure. You'll be within a tooth or so. With the timing chain off 1 tooth you'll know your cam timing is out with the way it's running. Good luck!
Jeremy
Last edited by jhiggs26; Mar 22, 2009 at 12:29 PM. Reason: Didn't want his timing chain dropping off his crank sprocket....
Old Sep 25, 2009 | 11:04 AM
VIT's Avatar
VIT
need help on 2009 mini cooper
I got a 2009 mini cooper base model 1.6l engine
i cant find torque specs and sequence for cylinder head bolts and cam bolts
also need to know how the timing markings are aligned
any help would be appreciated
and diagrams
thanks
Old Sep 19, 2011 | 01:13 PM
ghostone's Avatar
ghostone
Headbolts = 30ft-lb in sequence then 90 degree additional turn in sequence. That is what the BMW TIS CD states.
Old Sep 19, 2011 | 03:57 PM
Mike@Tech Division's Avatar
Mike@Tech Division
and diagrams
thanks
Bentely just released their service manual for 07-10. Pretty sure waymotors has it.
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
Willafb
R55 :: Clubman Talk (2008+)
Nov 6, 2015 08:08 PM
Fordgt4
Oct 10, 2015 10:42 AM
MGBill1186
Oct 2, 2015 06:54 AM
gnhovis
Sep 28, 2015 10:56 AM
