Drivetrain To Belt or Not to Belt
Old Jan 19, 2009 | 01:34 AM
zipedoda's Avatar
zipedoda
This is has probably been asked many times before. When changing to a 15% pulley how many changed the belt too? And what did you use? I have ordered a 15% Craven which I will put on a 06 MCS manual with 27,000 miles on it. Bonus question- any thoughts on the tensioner strap?
Old Jan 19, 2009 | 04:23 AM
oxtox's Avatar
oxtox
napa 535 is the belt for you
Old Jan 19, 2009 | 05:53 AM
thulchatt's Avatar
thulchatt
+1, this is the shorter belt you need.
As far as the tensioner stop, not really needed if the belt does not go. But cheep insurance.
Old Jan 19, 2009 | 07:08 AM
chris.j.lamb's Avatar
chris.j.lamb
+2 shorter belt + strap = happy
Old Jan 19, 2009 | 07:19 AM
wildfamily's Avatar
wildfamily
Yes, go with the NAPA belt. The original belt is most likely stretched out anyway plus you'll want a shorter belt to compensate for your smaller diameter pulley. He is a good discussion on the topic...
http://www.psmini.org/forum/forum_posts.asp?TID=3644
Old Jan 19, 2009 | 07:26 AM
Professor's Avatar
Professor
Yup NAPA 535 is the best I have found so far.
Old Jan 19, 2009 | 09:01 AM
RedSkunk's Avatar
RedSkunk
+6.
Old Jan 19, 2009 | 09:13 AM
Dr Obnxs's Avatar
Dr Obnxs
Belts are cheap..
and you be surprised how many minis are slipping at high RPM with the owner not even knowing...
+N+1!
Matt
Old Jan 19, 2009 | 09:14 AM
Hwydsgnr's Avatar
Hwydsgnr
I've tried JCW, NAPA 539 and NAPA 535.
The 535 is a little tight but appears to be maintaining much more than half of the indicator hole the longest. With the others, they eventually stretched to where none of the indicator hole was visible.
VanisleRyan
Sep 30, 2015 08:35 PM
eliseo1981
Sep 30, 2015 07:57 PM
fkrowland
Sep 30, 2015 10:30 AM
dragonby
Sep 25, 2015 08:10 PM
daviday
Sep 25, 2015 01:31 AM
