Drivetrain m7 heat shield installed
Old Jul 22, 2008 | 05:22 AM
drno's Avatar
drno
installed the turbo heat shield last night. nicely made and a good fit. a few suggestions for installation.
do not remove the tape covering at first, fit the cover and partially screw in the bolts. after you are sure everthing is lined up remove the tape cover strip buy reaching under with the bolt in place and stick down . then remove one bolt at a time , put a drop of lock tight on and reinstall the bolt all the way-repeat on the other side . takes 10-15 min at most. looks great ---now to see how well it works as soon as the rains stop here.
Old Jul 22, 2008 | 07:01 AM
benfica09's Avatar
benfica09
does the shield replace the stock upper heat shield over the turbo, or does it sit over the oem heatshield? does it still allow access to the O2 sensor?
a photo would be great when you get a chance.
thanks.
Old Jul 22, 2008 | 07:27 AM
drno's Avatar
drno
it sits on top-you just remove the 2 outer top bolts from the oem shield and replace them with the supplied bolts. you would have to remove it to work on the turbo. there is a venting hole but you couldn't do anything through it. pictures are on their website
Old Jul 22, 2008 | 08:28 AM
benfica09's Avatar
benfica09
thanks.
yeah, the pics on M7's site dont show it from straight on and above.
hard to see how it sits....and if there is access to the O2 sensor.
Old Jul 22, 2008 | 09:30 AM
drno's Avatar
drno
it sits directly on the black valve cover ( if that's what it is ) and the turbo shield on the drivers side. with plenty of room for flow of air. forget any chance of working on any part of the turbo-the hole or any other access is to small/ tight to work.why the concern about the o2 sensor- it's really easy to take off the shield and put a strip of 2 sided tape back if work is needed. only have to unscrew 2 bolts
Old Jul 22, 2008 | 10:06 AM
benfica09's Avatar
benfica09
my concern isn't so much getting access to the O2 sensor.
its that the O2 sensor wires are now sitting between the oem shield and the M7 shield. just curious about the heat in that area and the wires to the 02 sensor.
i was curious if there is a hole for the wires to stay above that area.
Old Jul 22, 2008 | 11:55 AM
drno's Avatar
drno
the hole in the lower passenger side is directly over that area ( you can see and touch them within milimeters of the opening. ) i spoke to peter at m7 and he stated that the hole was specifically designed to vent heat from that area
Old Jul 22, 2008 | 01:57 PM
benfica09's Avatar
benfica09
cool, thanks for the info.
let us know how it works
Old Jul 22, 2008 | 02:06 PM
matty125's Avatar
matty125
pictures?
Old Jul 22, 2008 | 07:45 PM
got.pho?'s Avatar
got.pho?
sounds interesting test your hood temps after the shield? im debating if it will be a good add on, looks nice tho
Old Jul 22, 2008 | 09:57 PM
Nimcosi's Avatar
Nimcosi
Same here. Looking forward to updates..
Old Jul 23, 2008 | 05:30 AM
drno's Avatar
drno
i can probably get some photos later today but i have no idea how to post them-----so if some one will post them post their email address and i will send you the photos
Old Jul 23, 2008 | 07:07 AM
JCR1960's Avatar
JCR1960
If you want to see what it looks like here is a thread in Coupe Talk (2007+) posted by MeloR56 with pictures of the M7 heat shield installation with before and after temperature readings.
Link:https://www.northamericanmotoring.co...d.php?t=148677
Old Jul 28, 2008 | 07:38 AM
JAS76's Avatar
JAS76
I just installed mine this weekend as well, looks great and it is good to see a reduction in under bonnet hood temps
one issue, mine is rubbing on the hood though in one little area...
Old Jul 28, 2008 | 03:24 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
WE have these coming in stock ASAP. I will also do some independent testing for everyone to view.
JAS76: where is it hitting? Pics? Let me know if I can help!
Old Jul 29, 2008 | 08:00 AM
drno's Avatar
drno
just looked and i'm rubbing in 2 spots
Old Jul 29, 2008 | 08:47 AM
white rocket's Avatar
white rocket
Any pics? I'm looking at getting this piece.
Old Jul 29, 2008 | 09:05 AM
JAS76's Avatar
JAS76
I will get some pics up tonight
Old Jul 29, 2008 | 10:50 AM
drno's Avatar
drno
spoke to m7---they have a fix in the works (redesign to allow the shield to sit closer to the firewall . they will be sending me a new shield and a prepaid fed ex return in around a week. so-------if you have the same problem , just contact them and they will take care of it
Old Jul 29, 2008 | 12:17 PM
ADAMSALTAMINI
Oh K! I just got off the phone with Peter @ m7. 10 minutes after a 6.0 earthquake!
Anyway, he said any units now shipping will have addl. adjustment to the mounting holes.
Old Jul 29, 2008 | 12:27 PM
joshK's Avatar
joshK
i'm interested in this piece as well. I already have the WMW turbo shield which does a great job at controlling the heat but the M7 one really cleans up the engine bay. Looking forward to the testing Adam!
Old Jul 29, 2008 | 06:55 PM
ADAMSALTAMINI
Will do! Just up to Peter and Shelly to get them to me now!
Old Jul 31, 2008 | 09:38 AM
pillar's Avatar
pillar
the only interest i have for the heatshield is to prevent my silly hoodscoop from melting...
but it also looks like m7 raised their prices to 200 dollars... i am getting another hoodscoop under warentee but can easily sell that and get the m7 vortex hoodscoop... question is... heat shield or scoop?
Old Jul 31, 2008 | 10:42 PM
ADAMSALTAMINI
Uhm BOTH duh
Just kidding! Do the scoop! At least then people can see it! Then get the shield later!
Old Aug 1, 2008 | 01:29 AM
joshK's Avatar
joshK
They raised the price? ugh...well looks like I won't be buying it now. I already have the WMW heat shield and 200 bucks for essentially a piece of underhood dress up is pretty steep. I guess I'll have to learn to love the look of that OEM heatshield.
